Dynavin info: D99 PLUS (D99+)......Fall 2012 - Page 14 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 03-19-2013, 08:42 AM   #261
E46Enthusiast20
My Ride: 2016 F80 M3 Sedan
Ordering one of these today!!
E46Enthusiast20 is offline   Reply With Quote
Old 03-21-2013, 11:32 PM   #262
E46Enthusiast20
Can tuesday come any quicker!
I miss having a dynavin in there. The oem cd player is soo bad!
At least I made $450 on the D90 on craigslist.
Old 03-22-2013, 05:41 PM   #263
anything german
My Ride: 330CIC
So the install is 99% finished, rear camera works great, navigation is fine with antenna under dash, still undecided about external microphone, but just in case I have wired the external microphone to the position behind the steering wheel and have left it unconnected for now. It is a convertible and I will need to drive it with the top down to test and the car is stored for the winter presently. The bluetooth seems ok, time will tell.
Overall sure has an OEM look, very pleased. I wouldn't say the install was easy, being a convertible there are a few differences, microphone and rear camera are 2 things, also mine had factory bluetooth, challenging the Dynavin bluetooth setup.
The only problem I have right now is setting stations on the radio. When I lock in a station it takes on the name of the song, so I disabled the RDS and that works but stations already named as songs won't change. Any thoughts? complete reset? Maybe a different radio setup?
anything german is offline   Reply With Quote
Old 03-22-2013, 06:44 PM   #264
bratliff
My Ride: 330i
Turn the rds back on and watch the display across the top change. When it shows the station name, press and hold the button.
'02 330i
'97 318i
'95 325 Vert
'76 280z
bratliff is offline   Reply With Quote
Old 03-26-2013, 09:35 PM   #265
E46Enthusiast20
Got her today and its incredible! Love it! Just having issues with the damn camera. It won't show up on the screen. It's just black. The reverse feature also doesn't work. I connected the red wire to the reverse on the Dynavin and the yellow cable to the brown camera cable on the Dynavin. What gives? :/
Old 03-26-2013, 09:48 PM   #266
jwbeck17
My Ride: 2005 330xi
If you wired it right, it may just be the settings.
Did you go into the hidden settings menu (Settings > System > Upper Right Corner (no button))?
When you do, there is a selection for REVERSE and you want to toggle it to CAM. Hopefully that is the issue and should resolve it for you.
jwbeck17 is offline   Reply With Quote
Old 03-26-2013, 09:58 PM   #267
E46Enthusiast20
It was already on CAM. Checked all the connections and everything checks out.
Old 03-27-2013, 04:47 AM   #268
g-rex
My Ride: Corvette, 330ci
Are you sure the green wire on the back of the Dynavin is the right wire? I did mine 2 weeks ago and I want to say I used a diff wire. The pink maybe? They were all labeled clearly in my case.
g-rex is offline   Reply With Quote
Old 03-27-2013, 07:53 AM   #269
E46Enthusiast20
Everythings where is should be bud. I have a weird feeling about the camera. Could possibly be faulty. I removed everything and plugged it again by the Dynavin and nothing still black. Shouldn't there be a power source for the camera? Theres just the yellow video signal wire. The reverse trigger wires are where they are supposed to be. It's just the camera that's not working. The Dynavin isn't recognising it.
Old 03-27-2013, 08:02 AM   #270
g-rex
On the harness that heads to the back of the car to plug into the RCA jack at the backup camera, you should have a power/ground wire with that that powers the camera.
I tapped the blue/yellow reverse wire behind the right side carpet cover and used an existing ground in that area as well.
Old 03-27-2013, 08:17 AM   #271
E46Enthusiast20
Same here. I used the blue/yellow reverse wire from the left reverse light and the brown wire for the ground at the same side. I'm using the same camera Jeff sells.
On the Dynavin side the yellow male to the brown female and the red wire to the green reverse wire. On the trunk side what I said at the start of this post.
Old 03-27-2013, 08:36 AM   #272
E46Enthusiast20
Okay this is weird it works now... lol. Now I have to run it all through again. I don't understand its connected all the same way... haha.
Old 03-27-2013, 04:22 PM   #273
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
bad connection somewhere.....
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 03-27-2013, 04:26 PM   #274
E46Enthusiast20
Alright this morning I tested everything and got everything to work after the camera issue. Now it won't read DVD's. It worked this morning but now it won't play. Just shows the cd spinning icon. When I remove the DVD its very hot. CD's work fine. Only issue as we speak.
Old 03-27-2013, 04:28 PM   #275
E46Enthusiast20
Fixed that issue Jeff. Probably was a bad connection. I love this thing! The NAV is fantastic!
Old 03-27-2013, 04:32 PM   #276
mark2727
My Ride: 2001 BMW M3 Vert
I've searched the forum and this thread but haven't found this answer specifically: will the Dynavin D99+ connect via direct cable (with adapter, presumably) to the iphone 5 for ipod functioning, charging, etc.? If not, is there a new cable that will work? Barring that... will there be a newer Dynavin anytime soon?
Thanks to Jeff and the other gurus here.
mark2727 is offline   Reply With Quote
Old 03-27-2013, 05:14 PM   #277
J&T Distributing
My Ride: BMW
Old 03-27-2013, 05:26 PM   #278
BigDRick323
My Ride: 2000 323i
Anyone have a dynavin working in DFW area???
Old 03-27-2013, 06:19 PM   #279
mark2727
Jeff: Thanks for the iphone 5 vid! Looks great. My D90 with lightning adapter does not work, unfortunately.
Old 03-27-2013, 06:34 PM   #280
J&T Distributing
My Ride: BMW
Another guy emailed me and mentioned that, the V5 ipod interface was totally different so it doesn't surprise me.....ill need to dust off an old unit and experiment a bit....
d99, d99+, dynavin, gps, navigation
