Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 07-03-2013, 10:55 PM   #401
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Mine was installed today and it's great. Thanks Jeff for the all help, he has been more than great with all the questions.
One issue is that the buttons don't light up. I have the D99+ Android edition and didn't have OEM Nav before so I don't think it's the issue that I have been reading on the fakra cables and splicing into the wires.
Any thoughts here?
AMG-ETR is offline   Reply With Quote
Old 07-04-2013, 07:46 PM   #402
AMG-ETR
NVM - Figured it out. It was the orange illumination wire that was not connected back to the harness.
Old 07-08-2013, 02:58 PM   #403
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Glad you found your issue...
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 07-16-2013, 10:11 PM   #404
J&T Distributing
My Ride: BMW
Originally Posted by mkdonald View Post
Thanks! Love the product and your assistance is appreciated!
good to hear you are enjoying it.
Old 07-17-2013, 07:29 AM   #405
mkdonald
My Ride: 330 Cic
I have the newest Dynavin unit in a 2002 330cic. Everything works great but the steering wheel buttons for the cell phone. The speak button will bring up the cell key pad on the dynavin, but the RT button on the steering wheel does not hang up the phone or make the key pad go away. Should it? Could it have something to do with the code buttons in the setup?
mkdonald is offline   Reply With Quote
Old 07-17-2013, 08:26 AM   #406
nicgala
My Ride: bmw e46 2004 318i
What is the female connection under the coin tray e46 318i 2004 Melbourne Australia
nicgala is offline   Reply With Quote
Old 07-18-2013, 01:33 PM   #407
J&T Distributing
My Ride: BMW
No, bluetooth can be used as a source for audio streaming so you leave it the same way you would leave any other source, press the MODE button and choose a another source.
"Long press" the talk button to answer an incoming call, "quick press" it to reject the call or hang up.
Dont know what you are talking about, did a previous owner install something?
Old 07-18-2013, 01:55 PM   #408
mkdonald
My Ride: 330 Cic
Thanks Jeff.
Old 07-23-2013, 02:53 PM   #409
mrpizat
My Ride: e46 m3
Hi there.
Got my android D99+ a few weeks back also had to get the farka cable (yay oem nav). anywho, everything installed well enough, very breeze like. Everything was perfect. love the unit it's wonderful but i have 1 question and 1 issue.
question that I have and can't seem to find the answer for. in the factor setting menu there is a "test" option and it comes back false, what is that and should it be false?
issue: Was driving with the top down with the sound up quite a bit on a long road trip. about 3 hours in I noticed that the volume seemed to be lower, then nothing. for a little while the rear speakers were outputting very quietly. after the car set for a bit I started to head home only this time there is absolutely no sound coming from the speakers, nothing at all, not even a scratchy noise.
Checked the fuses for "radio" and they both seemed just fine. I can't visually see that anything is wrong. verified my wiring. tried reseating the connections to the amp and nothing changed. Today i tested a known working amp and still nothing changed. at this point i wonder if there is a setting that got flipped some how? this is on a stock HK sound system.
thoughts?
mrpizat is offline   Reply With Quote
Old 08-05-2013, 05:37 PM   #410
J&T Distributing
My Ride: BMW
The most obvious thing would be to check the fader, if thats not it, its hard to say, the first thing I would do is use an old speaker or a multimeter, whatever you have, and check the dynavins speaker outputs to make sure they are working, to rule in our out the factory amp.
Old 08-05-2013, 05:52 PM   #411
mrpizat
My Ride: e46 m3
after spending several nights diagnosing the situation we finally tracked it down to the head unit itself. in doing some oscope work directly from the head it suddenly kicked on. best we can tell is that there was something loose in the HU that pushing reconnected. it's been working just fine ever since.
really weird but a least we are cooking again haha.
any thoughts on that test option?
Thank!
Old 08-10-2013, 12:44 AM   #412
69peternorth69
My Ride: civic
now that the d99+ has been out for almost a year, do you know if the next generation is coming anytime soon?
69peternorth69 is offline   Reply With Quote
Old 08-10-2013, 09:07 AM   #413
TRoc169
My Ride: BMW 325CI
I bought the D99+ plus from Jeff about a month ago with the HVAC relocation, USB, and E46 backup camera. I have been unable to do the full install due to summer graduate school classes. Thank goodness classes will end today. I did have some time to start the camera install on the rear decklid and have been unable to get the wires through without interfering with the license plate light and other wires? Any advice or know of a better camera for a 2001 325CI? I am also planning to flush mount the usb into the center console (small tray area). Does anyone know the ideal size for the hole? I measured 0.75". Any advice with the D99+ install?
TRoc169 is offline   Reply With Quote
Old 08-11-2013, 12:28 PM   #414
J&T Distributing
My Ride: BMW
regardless of what camera you use you are going to be putting a small hole somewhere for the wiring. With the camera you got from us, just drill a small hole in the top of the license plate light housing to get the wiring into the trunklid.
Yes the hole for the flush mount USB is 3/4" as I recall. A hole saw works best
Old 08-11-2013, 07:40 PM   #415
TRoc169
My Ride: BMW 325CI
Thanks for the information. I've completed the HVAC relocation and have run into an issue with the cigarette lighter. I can't get it to work. The light in the ashtray works. I did inadertently touch the metal with the screwdriver before removal the negative battery cable. There was just a little spark. Everything else works fine. I don't want to install the dynavin until Iresolve the cigarette lighter issue.
Old 08-11-2013, 09:18 PM   #416
TRoc169
My Ride: BMW 325CI
As stated above, I am trying to install the Dyanvin D99+. Besides the cigarette issue, I realized that I might have one additional wire after removing the the BMW Business CD. You will see two pictures attached. One picture has the antenna and the third wire and the second has the back of the BMW Business CD. I believe the third cable has something to do with the instrument cluster as I no longer have the time, mph, and something else. I do not see a connection in the dynavin for this third cable. Can anyone assist?
I do not know why the pictures are so big.
Old 08-11-2013, 09:52 PM   #417
J&T Distributing
My Ride: BMW
You popped a fuse when you shorted the screwdriver. Find and replace it.
The larger plug in the a I've pic is your antenna, you won't use the smaller plug (its also an antenna but not used)
Old 08-12-2013, 06:50 PM   #418
TRoc169
My Ride: BMW 325CI
Jeff,
Thanks for the information. I replaced the fuse today and it works fine. Will I have any reception issues with smaller plug not being used?
Do I need to connect the parking wire on the main harness to the parking brake? It is to my understanding it is needed to watch videos? Where can I get the pink wire and how do I connect the wires? I've seen a couple posts with a sheath over a connection point but I have not seen this sheath in the autoparts store. I haven't seen the wire either. I have done connections for household issues such as ceiling fans but no prior car audio experience.
There appears to alot of different guages, which guage should I be looking for?
Old 08-14-2013, 02:37 AM   #419
taylorscarter
My Ride: 2000 323CI
+1 on Satellite and HD radio. I would use it most for satellite. Was really thinking about this thing, but I was too quick to think it just came with Sat radio. No go!
____________
Cheap coding in Central TX via PA Soft... PM me!
+1: Roll tide.
taylorscarter is offline   Reply With Quote
Old 08-14-2013, 03:14 PM   #420
J&T Distributing
My Ride: BMW
Originally Posted by TRoc169 View Post
Jeff,
read my FAQ and install guide, its all there.
No you dont have to do anything with the pink park wire. There is a setting in the radio menu called BRAKE that makes it unnecessary.
d99, d99+, dynavin, gps, navigation
