Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 08-15-2013, 06:26 AM   #421
stalensnuitje
My Ride: '05 BMW 320D Tourin
Jeff, thanks for the info provided so far (in my own topic as well), but I have a question about the USB and SD connectors: I read a post somewhere from someone who had an issue with the Dynavin showing the files and folders on SD and USB in a weird order, I have that as well.
Your reply was to use DriveSort and I tried this, but still I get all my music mixed up. That's not really a concern when I'm listening to CD's with various artist, which I'd mix anyway, but when I play albums (i.e. Soundtracks) that have a certain order for a reason, it gets annoying.
Any other idea?
stalensnuitje is offline   Reply With Quote
Old 08-18-2013, 07:00 PM   #422
tommy1394
My Ride: Z3M Coupe
Help, I have the unit installed in a 528 wagon. For the most part I am happy with it, although I wish it had a xm/sirius option. Anyway, The thing that drives me crazy is that it will only connect with 1 Bluetooth device, once it is connected, I cannot figure out how to disconnect it. When my partner drives the car, we cannot get it to pair with her phone. Does anyone know how to solve this problem? If I can't sort it out, I will have to get rid of the unit as the bluetooth connectivity was one of the main reasons I bought it.
tommy1394 is offline   Reply With Quote
Old 08-18-2013, 10:49 PM   #423
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Just connect from the other phone....you don't do anything from the Dynavin.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 08-18-2013, 11:50 PM   #424
TRoc169
My Ride: BMW 325CI
E46 Backup Camera
I have seen a couple people mention that they have installed the E46 backup camera that Jeff sells. I purcased the camera but have been having trouble finding a path to run the camera wire through the license plate light housing (drivers side). There is an existing opening underneath the lightbulb but I think the heat generated from the bulb along with the wire touching the metal supports make this not an option. I've tried to drill a hole through the housing but I've hit wire and do not feel that the drill bit would make it though. Luckly I did not severe any wire. Can anyone provide some input?
TRoc169 is offline   Reply With Quote
Old 08-19-2013, 11:05 PM   #425
McDonald
My Ride: 2002 330i
Is there any Install guides for the flush mounts?
IM not really sure where the go. Ive seen some under the armrest in the coin holder, is that where it will go?
Is there a way to hide the iphone cord other than the glove box?
McDonald is offline   Reply With Quote
Old 08-20-2013, 01:04 PM   #426
J&T Distributing
My Ride: BMW
where and how you mount them is up to you, most people put them under the armrest as its hidden, easy to mount, and easy to access. Its not necessary though, the dynavin comes with a USB extension that you can simply run to the glove compartment.
For the ipod cord, on an E46 I prefer to run the cord to the area by the emergency brake boot, you can fold/tuck the wire down next to the ebrake when not in use and its pretty much invisible, but very accessible if you are plugging in a lot (like when using an iphone). You can then stick your phone in the cupholder.
Old 09-01-2013, 10:19 AM   #427
Johancab
My Ride: 330 Cic
Dynavin info: D99 PLUS (D99+)......Fall 2012
Hi guys
I bought a 99+ (from the South African agent) and just installed it after reading through this thread.
Thanks Jeff it would not be possible without your thread, if I lived in your country I would most certainly have bought it from you!!
The only thing I can't get any info on is setting it up to show obd info, please tell me what I need and how do I set it up.
Kind regards
Johan
Johancab is offline   Reply With Quote
Old 09-01-2013, 10:20 AM   #428
Johancab
My Ride: 330 Cic
I should have mentioned its the Win CE unit.
Old 09-01-2013, 10:43 AM   #429
trentcdrums
My Ride: BMW 323i Sedan
When I plug in my sd card and go to sd on the menu it says invalid.. I was hoping to play my music
Old 09-01-2013, 02:49 PM   #430
Johancab
My Ride: 330 Cic
Ok I found it.
I could not get the touch screen to scroll to the second page by clicking the arrow so I wasn't aware of it. I accidentally found it now I can scroll there by swiping my finger across the screen but still not by clicking on the arrow.
Old 09-03-2013, 04:32 PM   #431
J&T Distributing
My Ride: BMW
Originally Posted by Johancab View Post
Ok I found it.
yes, you swipe the screen, the arrows just indicate the two screens.
too many variables here..... card format, file format, physical card, directory structure, etc... start small, put a few mp3s on a card, build up from there.
Old 09-04-2013, 09:05 PM   #432
Remedydaw
My Ride: 330i
Hey Jeff,
Thank you so much for all your help and excellent information regarding the Dynavin D99+. And also thank you for the quick replies and fast and excellent delivery. I would highly suggest getting any dynavin parts from Jeff.
Regards
Remedydaw is offline   Reply With Quote
Old 09-11-2013, 06:58 AM   #433
georgekos
My Ride: E46
Dynavin d99
Hi
I can***900;t see this on my dynavin d99
what can i do?
thanks
ID:	526003   Click image for larger version
georgekos is offline   Reply With Quote
Old 09-13-2013, 09:51 AM   #434
Johancab
My Ride: 330 Cic
I suspect I have an antenna problem, I use to have perfect reception but since I installed the 99+ I have no radio reception at all. I have read that these cars has an antenna amplifier but I cannot find any detail or a diagram for it. I've been struggling with this for a week now with no progress at all. Please help.
Old 09-13-2013, 10:22 AM   #435
trentcdrums
SAME HERE
Old 09-13-2013, 10:33 AM   #436
J&T Distributing
My Ride: BMW
You either have a bad connection at the antenna plug behind the dynavin or you need a powered antenna adapter. Read the FAQ on my website, #10 if I recall.
Old 09-13-2013, 03:45 PM   #437
trentcdrums
Jeff, I cannot find that file you ran in the video with your winc. And going in my entertainment and choosing my music works fine. But I cannot control it from the wheel and my sub doesn't turn on..
Old 09-13-2013, 04:49 PM   #438
Johancab
My Ride: 330 Cic
According to your website the power antenna adaptor is only for pre 2002 cars, mine is a 2004 330Ci cabrio (facelift). I also checked an re-checked the connections they're all very firm?
Old 09-13-2013, 05:13 PM   #439
J&T Distributing
My Ride: BMW
Trent, I dont know what you are talking about.....are you using the windows part of the unit to play media? Thats not really how its intended to be used, it works I suppose, but not really how its intended...
In that case you could have a bad or damaged antenna adapter.
Old 09-13-2013, 05:32 PM   #440
trentcdrums
I actually have a few concerns, for some reason when I want to start my navigation, it makes me calibrate the screen. Then when I get to this page Chinese crap comes up.. Click image for larger version
So then I go to the settings and choose my file and this is what I get.
Then I open up the folder and go to storage card and this is what I get then. Click image for larger version
Then I hit Primo and then I get this.. Click image for larger version
ID:	526434 Then I run the Primo on the bottom and then I am able to start the navigation. But it seems like I have to do that every time I turn on the car. Just to get to my navigation. But that still does not fix why my language is Chinese when I hit the navigation, then when I follow all the steps I just showed you, everything else is English. Click image for larger version
ID:	526435 After I just did everything I showed you in the pictures, I finally load the navigation and everything is English. I just don't understand why everything is Chinese all of a sudden when I hit the button.
d99, d99+, dynavin, gps, navigation
