Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 03-03-2014, 12:56 PM   #561
XX7
My Ride: All
Solved!
I get advice from reseller for Germany that I need to disconnect power more then 5 min. And all working ok now.
So if anybody have same problem that is solution.
Anyway it will be nice to have sokutio for update winCe.
So request for that is still stay.
Thx for all.
Br
XX7 is offline   Reply With Quote
Old 03-12-2014, 11:42 AM   #562
Waygone
My Ride: 2003's 325XiT, 330Ci
Obd
Just finishing the first install in my 2003 325XiT and was wondering about OBD info. I've done a few searches in the Dynavin posts but didn't see what I was looking for. In the OBD screen, I only see 5 or 6 values displayed. I guess I could understand not having certain ones...oil temp or such....but it seems strange that one of the missing values is voltage, that should be an easy one. Am I missing something?
Waygone is offline   Reply With Quote
Old 03-12-2014, 02:02 PM   #563
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
it will display whatever the car has available to it on the ibus, this varies by vehicle, model, year, equipment level, software version, etc... So no, you cannot make any assumptions about what will or will not display.
jeffb325@NavigationSolutions is online now   Reply With Quote
Old 03-12-2014, 02:48 PM   #564
Waygone
Well that's a bummer. Well, at least now we know. Thanks
Old 03-19-2014, 06:27 PM   #565
J&T Distributing
My Ride: BMW
well....keep in mind no other stereo in existence displays any info from the ibus....so whether the dynavin displays 1 value or 8 in your particular car, its all a bonus. But frankly its a VERY minor feature.....most people dont even know its there, and those that do, take a look at it once or twice, and rarely again.
Old 03-26-2014, 08:56 AM   #566
alanwt1949
My Ride: 130i
Just installed the DVN-E8X D99+ Android. Everything works fine except when switching from Windows CE to Android, the volume is a lot louder than Windows CE even tuning to minimum sound.
Any idea?
alanwt1949 is offline   Reply With Quote
Old 03-26-2014, 09:20 AM   #567
J&T Distributing
My Ride: BMW
There are volume icons in the status bar, use them to set the relative volume of android to the radio functions.
Old 03-27-2014, 10:10 AM   #568
alanwt1949
My Ride: 130i
From the WinCE control, the normal sound volume is around 15. Under android, I tried to setup the media volume to minimium through the status bar icon. But the sound is very loud under the android.
Old 03-27-2014, 12:16 PM   #569
J&T Distributing
My Ride: BMW
is the android volume being controlled by the volume knob? If not, change the "navi sound" setting in radio settings menu.
keep in mind there are also volume settings within the apps themselves, and the statusbar volume function changes depending on what app you are running.
Also, if 15 is "normal" volume, you might want to go into the factory settings menu and change the AMP setting to COMMON. That will shift your volume range a lot and might better match the output of the dynavin to the factory amp.
Old 03-30-2014, 11:03 PM   #570
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
My android side of D99+ unit has stopped working after I connected the battery on my car after storage. I put in the password after initial start up and the non-android side works fine.
The screen goes black when I press "Navi".
Any ideas?
AMG-ETR is offline   Reply With Quote
Old 03-31-2014, 01:40 PM   #571
BonesXX
My Ride: Vert
Apps Control
Maybe I missed this somewhere in this thread as I skimmed thru pretty fast but I would like to know if you can control apps installed on your phone via the touchscreen. In particular AHA radio and Pandora. I have a 2013 Ram truck that does this and it is awesome. The phone is not connected to the system except via BT and the data usage is from the phone. In other words once I signed on to my accounts thru the Truck's system then I could control them via my OEM touchscreen.
BonesXX is offline   Reply With Quote
Old 04-01-2014, 05:41 PM   #572
BonesXX
My Ride: Vert
Just so no one thinks Jeff didn't' reply we talked and he was very helpful. It's nice to be able to speak ear to ear. I am buying this unit and will report back on my impressions.
Old 04-03-2014, 11:48 AM   #573
J&T Distributing
My Ride: BMW
Any ideas?
Emailed, crib notes: reload android ROM.
Old 04-03-2014, 01:32 PM   #574
AMG-ETR
I tried but when I put the micro sd and turn on the unit, it goes to the root folder of the micro SD and nothing happens.
Any ideas?
Old 04-03-2014, 01:54 PM   #575
J&T Distributing
My Ride: BMW
sorry but Im not following....."it goes to the root folder of the micro SD and nothing happens".....that doesnt make sense. Are you putting it in the correct sd card slot? It should be going in the Nav slot.
Old 04-03-2014, 02:00 PM   #576
AMG-ETR
Stupid me, I was putting it into the right slot vs the Nav slot.
I will retry again shortly and let you know.
Old 04-05-2014, 01:36 AM   #577
AMG-ETR
I tried everything and it still keeps booting up per usual and doesn't update the software.
http://www.dynavin.com/android.php
This page only has the "update". Is this what i'm supposed to be extracting to the micro SD root? My android side is completely unusable.
Old 04-06-2014, 08:01 AM   #578
bl1tzk1213g
My Ride: E46 M3
Is there an upgrade to make it faster? Like overclock hehe.. Touchscreen is kinda trouble to work with, i always have to use my nails.
bl1tzk1213g is offline   Reply With Quote
Old 04-07-2014, 12:58 PM   #579
Moonshot
My Ride: E46
Hi Jeff I have one more question. I have iphone 5 and want to stream music from the phone on the dynavin. If I want to use the ipod interface on the dynavin, which cable should I buy? I notice the cable J&t offer is 30 pin while my iphone needs new lightning one so I need an adaptor? Will it work and charge simultaneously?
Thx dear in advance.
Regards,
Mo
E24 635 CSI 1989 Black/Black with 18'' BBS RS 285 90K Km
E46 330CI Convertible 2003 Silver/Black M-Tech II package 42K Km
Moonshot is offline   Reply With Quote
Old 04-07-2014, 01:08 PM   #580
J&T Distributing
My Ride: BMW
Yes, just use the apple lighting adapter, it will work and charge at the same time.
d99, d99+, dynavin, gps, navigation
