Sponsored by BAVSOUND
Thread Tools Search this Thread Rating: Thread Rating: 332 votes, 4.99 average. Display Modes
Old 05-23-2014, 12:33 PM   #601
jeffb325@NavigationSolutions
J&T Distributing
My Ride: BMW
Originally Posted by asb2106 View Post
could you provide some pics/details about what you did there? link?
He did a standard double din install....lots of info here about those, mulitple threads in the sticky at the top of the forum.
jeffb325@NavigationSolutions is offline   Reply With Quote
Old 05-24-2014, 02:06 AM   #602
ocellatus
My Ride: 325i 2005
Hi Jeff,
I have got a backup camera from you (indirectly!) and yesterday I installed it on my D99+.
I have a little problem, please let me know if you have any idea about this.
The camera is functioning fine but the the problem is that when the engine is running the camera's screen gets some kind of noisy ( horizontal bars wiggling vertically ).
I should mention that I had to cut the camera's cable in order to pass it through the elephant tube in the trunk. I was wrestling with it for several hours with no success and finally I got mad and cut it to remove the bulky part. I then twisted the 3 wires inside the cable together and insulated each one with electrical tape. I did not test the camera before this but poor screen quality seems fair to me regarding my action! However, I have no technical knowledge about this. Do you think this might have caused the noises on camera's picture? Can soldering and better insulating improve the picture quality?
The noises disappear and image gets clear when I test the reverse with engine off. The repaired part of the cable is in the trunk lid and I have not put back the trunk and battery covers and liners if it matters.
I would appreciate your input.
Edit:
Now I found out that not only starting the engine but also the vehicle lighting affects the camera's video quality. With engine off if I turn on the lights to the first position, some noises come to the screen and if I go further and turn on the low beam xenons it gets worse. The worst case is engine running with all exterior lights on.
ocellatus is offline   Reply With Quote
Old 05-29-2014, 02:59 AM   #603
ocellatus
My Ride: 325i 2005
I guess the battery is source of noises on the camera.
Could it be the proximity of the camera cable with the thick red battery cable in the trunk?
The cut and repaired part of the cable is inside the trunk lid.
Attached is pics of where I routed the cable behind the rear seat.
ID:	559958   Click image for larger version
ID:	559959   Click image for larger version
Old 05-30-2014, 03:50 PM   #604
longtallsally
My Ride: '02 325xi
OK, please do not beat up on me too much for this as I am WAY late to the game and although I've perused the thread off and on for a long time, I've not done a deep dive on the best choice.
So my wife wants to fall in love with her car again and would like to have BT and navigation. I'd like to do it correctly, and this seems like a strong unit and even though a bit pricey, it is still MUCH cheaper than a new car. She's got a Windows phone that I'm assuming will be able to connect to the Dynavin HU? I've read about firmware issues and the like, and what has kept me from getting one a couple years ago was just this; concern that the unit won't be more or less brainless like an OEM unit. My wife is no dunce, but I don't want to have to spend more time monkeying with the unit than using it. I work in the telematics industry, so I'm pretty astute to how all this stuff works, but still just want something only nominally more complicated than "plug and play".
Is this the unit for me/her?
longtallsally is offline   Reply With Quote
Old 05-30-2014, 04:09 PM   #605
J&T Distributing
My Ride: BMW
Answered on the other thread....
Yes, if you want something relatively simple and easy to use the dynavin is the way to go, PMed with details.
Old 06-01-2014, 06:52 PM   #606
ESTPerformance
My Ride: BMW 330CIC
Anyone who has a Dynavin and does not use a RCA out front/rear/sub cable that plugs behind a unit will you sell it to me? My unit came without and I'm using amp for all speakers so without it it's useless.
ESTPerformance is offline   Reply With Quote
Old 06-02-2014, 10:16 PM   #607
rjbarrington
My Ride: 320d
GPS improvement
Hey guys
I did a bit of experimentation and found a GPS hardware mod that helps with reception, accuracy, and fix time. Fitting a better antenna than stock means better GPS performance. Here's some before and after pics to give an idea of the difference. In practice it means I don't worry about GPS fix any more... I just drive and it's got a fix by the time I go looking for directions...
Before:
After:
Any yes, the car was in the same place for the test (my driveway). The after pic has a more accurate position.
PM me and I can hook you up with one (or lots...).
Cheers,
Richard
BTW, the screen protectors were part of another trial to find the best option for antiglare, antireflection, contrast, etc.
rjbarrington is offline   Reply With Quote
Old 06-09-2014, 02:04 PM   #608
J&T Distributing
My Ride: BMW
interesting experiments.....both of them.... Ive not tried different GPS antennas but I have tried different screen protectors. I dont know what results you are getting but I found that all of them make visibility worse...
Old 06-09-2014, 07:51 PM   #609
rjbarrington
My Ride: 320d
I tried a few different GPS antennas based on claims and specs. Some pick up different satellites better than others, some make no difference at all, but overall the Gilsson antenna did best, and like I said, it "just works" now where before it often didn't get reception if it was cloudy or in some parts of town.
With the screen protectors, there were a few criteria I used; glare, reflection, contrast, clarity, and touch/feel. I tried a lot of them (PhotoDon, NuShield, 3M, Clarivue), and my take is that the 3M AMR200 is the best balance, although the MXG provided better anti-glare/anti-reflection at the expense of clarity & contrast. NuShield DayVue was interesting but I found it too reflective in this car despite increasing contrast... Their AG film could be worth a try though... There's always going to be some image degradation with this much anti-glare wanted, and also a point where the glare causes white-out, but my subjective take is that it's better with the screen protector up until that point. Dragging menus and icons is better with the protector too - I always found it difficult to drag without clicking before.
Other experiments were software mods (new V6 SuperCharger on M3 ROM, and choice of apps) and a hardware supervisor (backup power with soft shutdown - think of a UPS) were other things I've messed with in an attempt to fix the "Force Close" issue.
Cheers,
Richard
Old 06-10-2014, 06:53 PM   #610
Augster
My Ride: 2008 335i Sport
Question Bluetooth Pairing Questions
1) How many phones can be paired to the D99+ for phone calls? The new owner finally got around to asking me to pair her phone to the Dynavin but we found out her son's iPhone was already paired, and even though we were eventually able to pair her phone as well, all phone call functions appeared to be attempting to go through her son's phone (who was not home at the time) and we couldn't figure out how to direct calls through her phone.
2) How do you delete/unpair a phone from the D99+?
The manual, IMO, is pretty horrible. For example, its instrux for pairing a phone state to go the main menu and select the "Bluetooth" icon. Well hello, we couldn't find any Bluetooth icon on the main menu screen. Argh! Getting no where, I Googled and found out that the Bluetooth is (always) active so simply enabling Bluetooth on the target phone and selecting "DYNAVIN" should initiate the pairing.
Augster is offline   Reply With Quote
Old 06-11-2014, 04:40 PM   #611
J&T Distributing
My Ride: BMW
One phone at a time can be connected. Not sure what all you were up to there but once paired the unit will remember multiple phones but if you switch phones you must manually tell the phone to connect.....in the phone menu it should see the dynavin and you should be able to select it to connect. Having the previously paired phone within range when you are doing this is also asking for trouble so make sure its far enough away.
If this does not work then the pairing was no good, delete the pairing from the phone and start over.
Old 06-19-2014, 07:05 PM   #612
illestminimike
My Ride: Project Drama
My dynavin went into theft mode and is asking for a code. Where do I find the code?
Old 06-19-2014, 10:52 PM   #613
illestminimike
Nevermind
Old 06-20-2014, 02:08 PM   #614
bl1tzk1213g
My Ride: E46 M3
Apps on my android side keeps on crashing, how can I reboot/reinstall the android side? I want to start fresh and install fresh. Can we overclock this thing?
bl1tzk1213g is offline   Reply With Quote
Old 08-27-2014, 11:00 PM   #615
JeroldLin
My Ride: Benz W211 E280
Hey guys
I hv a question abt the Dynavin d99+ installing on my benz w211 e280. The question is : I use the Iphone lighting adapter to let my iphone 5 can play the music. At first, it worked very well. But, it couldnt play music by iphone5 last month. I went to ask the distributor, they test by the iphone 4. It could work, but still couldnt play w/ iphone5. They said my lighting adapter were broken. Alright, i went to buy a new one. It still couldnt work. Any one kno how to solve my question?
Also, when i use the blueteeth pairing my mobile(iphoen5), when I change stalls. It cant contiuned in blueteeth mode, jumping another mode (ie cd,radio... etc)
thx alot
brgds.
JeroldLin is offline   Reply With Quote
Old 12-09-2014, 02:38 PM   #616
Bogdan S
My Ride: BMW E46 320D
Yes!, The PDC overlay works on the E46 as well
Bogdan S is offline   Reply With Quote
Old 12-09-2014, 02:52 PM   #617
Bogdan S
Hello Everyone,
I've had a D99+ (WinCE) unit for almost a year now. Everything worked fine until last month.
The problem is with the Navi menu (Press Button NAVI). The Unit goes into the menu but apart from displaying the screen with the 3 Icons (Navigation, Setup, Entertainment) nothing works there. I press on the icons and nothing happens.
I've also tried a HW reset. This did not help either.
Can anyone please help me with ideas on how to fix this problem? It's worht mentionning that the rest of the system works perfectly!
Have a great day and lots of fun on the road!
Bogdan
Old 12-09-2014, 03:09 PM   #618
Bogdan S
Hello jeffb325@NavigationSolutions,
Bogdan
Old 12-09-2014, 04:23 PM   #619
J&T Distributing
My Ride: BMW
Hard to say, not something I see but it basically sounds like the touchscreen is not responding only on the WinCE side of the unit??? It could just be that things are out of sync, maybe disconnect power for a couple days to see if that helps, if not contact your dealer and ask them to send you the appropriate winCE software to re-flash the WinCE part of your unit.
Old 01-13-2015, 03:28 PM   #620
325ci03
My Ride: 325ci coupe 2003
D99+ ///M3 Evolution Android OS & lots of EXTRAS for BMW e46 3-series
I found this on eBay and thought somebody might like it. Check it out. Dynavin D99+ ///M3 Evolution Android OS & lots of EXTRAS for BMW e46 3-series. FULL NAVIGATION & ENTERTAINMENT SYSTEM. OEM LOOK & FEEL
http://r.ebay.com/WFuxwS
Name:	Front Android LOGO.JPG
ID:	586842   Click image for larger version
ID:	586843   Click image for larger version
ID:	586844   Click image for larger version
Name:	IN car_2.jpg
ID:	586846   Click image for larger version
Name:	Right angle Radio.JPG
325ci03 is offline   Reply With Quote
d99, d99+, dynavin, gps, navigation
