Old 09-25-2012, 11:21 PM   #1
mapleblunt46
My Ride: 2000 328i
qoute from bmw- wil it fix my problem
cponcerned this problem will not be fixed. also concerned about the price. DIY? can anyone advise me on what to do.
OPERATION: 3241351 Power Steering Intake & Return Hoses, r&r
328i Tank To Pump 99/00
LABOR HOURS: 1.10
QTY PART NUMBER PART DESCRIPTION PART PRICE EXT PRICE
1 BM32-41-1-095-526 INTAKE MANIFOLD 76.86 76.86
2 BM07-12-9-952-109 HOSE CLAMP 3.06 6.12
1 BM83-22-9-407-858 AUTOMATIC TRANSMISSI 16.50 16.50
1 BMWP EST BY WILL 0.01 0.01
MISC CODE MISC DESCRIPTION QUOTE MIN QUOTE MAX PRICE
SS SHOP SUPPLIES/ENVIRONMENTAL FEES 3.00 39.95 12.23
LABOR $: 152.90
PARTS $: 99.49
GOG $: 0.00
MISC. $: 12.23
SUBTOTAL $: 264.62
OPERATION: WB2 Replace Both Front Wiper Blades 99/06 Set
LABOR HOURS: 0.20
1 BM61-61-0-037-009 SET OF WIPER BLADES 73.16 73.16
SS SHOP SUPPLIES/ENVIRONMENTAL FEES 3.00 39.95 3.00
LABOR $: 14.00
PARTS $: 73.16
GOG $: 0.00
MISC. $: 3.00
SUBTOTAL $: 90.16
OPERATION: 3241250 Power Steering Reservoir, r&r 323i, 328i 99/00
LABOR HOURS: 1.00
1 BM32-11-1-131-345 HOSE CLAMP 8.42 8.42
1 BM16-12-1-180-242 HOSE CLAMP 4.28 4.28
1 BM32-41-6-851-217 OIL CARRIER 83.52 83.52
SS SHOP SUPPLIES/ENVIRONMENTAL FEES 3.00 39.95 11.12
LABOR $: 139.00
PARTS $: 112.73
GOG $: 0.00
MISC. $: 11.12
SUBTOTAL $: 262.85
mapleblunt46 is offline   Reply With Quote
Old 09-25-2012, 11:22 PM   #2
mapleblunt46
My Ride: 2000 328i
this is the problem - listen for the sound
Old 09-25-2012, 11:26 PM   #3
Usmc1028
My Ride: 1999 BMW 328i
$90.00 for wiper blades o.o
Usmc1028 is offline   Reply With Quote
Old 09-25-2012, 11:32 PM   #4
adaseb
My Ride: 2002 BMW 320i
Dude
Go to Canadian tire and buy the Motomaster wiper blades for $7-8 a piece. They fit perfectly. If they are a little loose then just bend the wiper arm to hold it on tighter.
I don't recall the sizes, so search the forum for that.
adaseb is offline   Reply With Quote
Old 09-26-2012, 12:02 AM   #5
choxor
My Ride: JDM
Did you check the vacuum line like was suggested in your last thread.
Old 09-26-2012, 12:08 AM   #6
scarede46er
My Ride: 2001 BMW 325i ZSP
The power steering reservoir will take 10 minutes tops. Buy it aftermarket, get 10 clamps for 4 dollars from walmart and keep 8 as spare. Jeez.
Old 09-26-2012, 12:32 AM   #7
mapleblunt46
My Ride: 2000 328i
wasnt concrened about the wiper blades... forgot to delete it . however i dont think it is the vaccum line the description of the sound is different. im am not framiliar with fixing the power steering reservoir is there a DIY link you can send me
Old 09-26-2012, 12:40 AM   #8
scarede46er
http://forum.e46fanatics.com/showthread.php?t=788513
Make sure you get screw on clamps. The ones that come with the car are terrible,
Old 09-26-2012, 05:51 AM   #9
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
I'm really not hearing anything and aren't sure what your issue is. If it's related to the mpg gauge, I'm not sure how PS is involved.
It sounds like you have some PS fluid leaking to me based on the bmw repair estimate, but that is diyable.
Can you use words to describe the issue as you described it to the dealer?
Facebook.com/DMAXstandup
Mangofy your E46!
Old 09-26-2012, 06:26 AM   #10
HiHoBrian
My Ride: 05 M3
I don't see anything on your quote that matches the issue in the vid. I would ask the service rep to actually diagnose the problem with the mpg gauge. It is likely just a vaccume hose. The rest is just typical Dealor add ons. If your PS is leaking somewhere and you are comfortable with paying that price,go ahead,but the gauge problem is likely a $5 vaccume hose.
sent from my ATARI sc1224
HiHoBrian is offline   Reply With Quote
Old 09-26-2012, 08:33 AM   #11
Viktimize
My Ride: 2002 325i,2003 330ci
I can't believe the pricks want to double charge you labor to remove the reservoir. You have to remove it anyway to do the hoses, so the labor is included in that, you should only be paying a little extra for the reservoir itself. Either way though, like it was mentioned, why are they changing PS hoses to fix your MPG gauge?
Viktimize is offline   Reply With Quote
Old 09-26-2012, 09:48 AM   #12
dknightd
My Ride: 2002 330 cic
I have no idea what you think your problem is. Are you trying to fix your mpg gauge? Are you trying to fix a steering problem? Are you trying to fix a leak.
What did you tell the dealer the problem was?????
They will no doubt fix what you tell them the problem is. If not the first time, eventually. Just keep giving them money and describing the problem and eventually they will fix the "problem".
I have not looked up the part numbers for the pieces they plan to replace. Have you?
That MPG gauge is a weird thing. I still haven't figured out how it works. It seems to use vacuum as one input (in the old days we used to just run a vacuum gauge, it can give you some indication of fuel use with a carberated car, and also with a fuel injected car, but it is a guide - not accurate) but clearly it is not just vacuum since it goes to infinite when not moving. It is also not a simple measure of fuel use (determined by speed divided by injector on time). Perhaps somebody at BMW knows how it works, or is supposed to work, but I have not run across that description (except for a short blurb in the manual). Apparently it uses vacuum from power steering vacuum reseviour. Not sure why.
Have you looked up the part number BMW wants to replace? I have not. But there might be two power steering reseviours - one for fluid, one for vacuum. Maybe bmw dealer is trying to fix two problems they see?
You appear to have an automatic transmission (wild guess based on your video), so the behavior of the mpg meter on my car might be useless. But I've found the guage useless, though fun to look at. I think having it peg at low speed with any throttle applied is normal. That is what mine does. It also reacts slowly
dknightd is offline   Reply With Quote
Old 09-26-2012, 10:42 AM   #13
Xeek
My Ride: 2000 328ci, 2010 328
Send a message via AIM to Xeek Send a message via Yahoo to Xeek
Don't let them do your wiper blades, just Woah! Bavauto.com has a really good set for $22 each, and they are easy to install. There are even cheaper blades if you look around, but the PIAA ones are very good. I think the Bosch ones are only $17 each.
2000 BMW 328Ci
2010 BMW 328i LCI
Xeek is offline   Reply With Quote
Old 09-26-2012, 12:00 PM   #14
Caden
My Ride: 2012 Genesis 5.0
Why do people get rid of their original blades? It's like 10 dollars for the inserts (like $14 from the dealer) and takes 5 minutes to cut and replace?
Caden is offline   Reply With Quote
Old 09-26-2012, 12:19 PM   #15
cvx5832
My Ride: 325Ci, 325Cic, C300
Eventually the pivot points get loose (starts to make noise when it changes direction plus it changes the blade alignment relative to the glass), the plastic wing gets brittle (and breaks off, like mine), surface rust for those in salted areas plus the black paint fades and makes the car look older than it is.
Granted it took my 325 8 years and 72k miles before it started to look like it needed replacement. They don't wear often, but I do recommend changing them every few years. New wiper assemblies wipe chatter-free and noise-free and it's a good feeling. Your experience may vary.
cvx5832 is offline   Reply With Quote
Old 09-26-2012, 03:53 PM   #16
Caden
Mine are still stock original. 12 years old, 149k miles. No paint missing, no streaking, blade alignment fine, no rust, still look new and no noise. It must have a big factor on where you live, just like all metal parts on car. My car has been a Texas car its whole life. Only a couple days of freezing temp. where I live.
Old 09-26-2012, 08:24 PM   #17
mapleblunt46
My Ride: 2000 328i
the qoutes above are for 1 power stering hose to be replaced ( tank to pump)
and the power steering resivoir is leeking aswell. i have not done this before, is it a quick DIY>
thiking bout saving 500 so give me your advice
Old 09-26-2012, 10:54 PM   #18
TurnersInOz
My Ride: 2004 325i
Where is the reservoir leaking from? A common thing is the o-ring in the cap leaks.
The LP hose from the reservoir down is an easy fix, too.
One consideration for replacing the reservoir itself (instead of just the o-ring) is there is a filter in the bottom of the reservoir.
Replacing these is a simple thing, and a lot cheaper than paying someone.
TurnersInOz is offline   Reply With Quote
Old 09-27-2012, 08:35 AM   #19
Viktimize
LOL, ya they don't even last a full year when you have to use your ice chipper to get them unstuck from the windhsield for 4 months a year in the winter. You lucky southern b@stards.
Old 09-27-2012, 08:42 AM   #20
Viktimize
It's like 3 bolts and some side cutters to do that job.
Pull the intake box off,
cut the top off an old winshield wash fluid bottle and stick it where the air box was,
take out the 2 (12mm I think) bolts holding the reservoir bracket in place,
tip it over and empty the fluid into the washer bottle,
use the sidecutter to cut the hose clamps off,
jam the washer fluid bottle under the thing best you can,
pull the reservoir off the hoses,
put your new hose clamps over the power steering lines,
put the new reservoir on,
tighten the clamps,
swap the bracket off the old reservoir,
now bolt the new one back in place and re install the airbox.
And don't forget to fill the reservoir with fluid.
Matter of fact here is a tube vid on how to do it.
