Water problems - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-26-2012, 05:48 AM   #1
Wilba83
My Ride: Bmw323i
Water problems
hi all got a problem I hit a puddle last nite which killed my engine managed to get it running but it wnt rev over 2500 to 3000 rpm and wnt do over 10 mph any ideas what I have done. I've been told a blown air hose or a cat sensor. Any help would be great thanks
Wilba83 is offline   Reply With Quote
Old 09-26-2012, 05:55 AM   #2
TArse
My Ride: 03 330xi, 87 325is
Any codes?
TArse is offline   Reply With Quote
Old 09-26-2012, 05:57 AM   #3
Wilba83
My Ride: Bmw323i
What codes bud
Old 09-26-2012, 06:31 AM   #4
paraklas
My Ride: ESS TS2 320ci
Check engine light on?
Possibly ruined the MAF, easy fix, go read the fault codes if any
Or hydrolocked your engine, expensive fix
Old 09-26-2012, 07:06 AM   #5
deanthedude1977
My Ride: bmw e46 325i sport
Is the EML light on if so get the codes read--might pay you to take off maf sensor and clean then try again after refitting
deanthedude1977 is offline   Reply With Quote
Old 09-26-2012, 08:33 AM   #6
Wilba83
My Ride: Bmw323i
We're will I get these codes from coz eml light is on.
Old 09-26-2012, 08:40 AM   #7
deanthedude1977
You need a code reader or take car somewhere that will read the codes for you--i bought a code reader from ebay works fine.
Any bmw dealer will do 4u but cheaper to take to independant bmw specialist--they will charge u an hours albor probably--it only takes 5 min tho..
I will send you the link if u want it--that will only tell you whats wrong-it wont fix your problem.
Im guessing water has gone through ur intake and either broke or made ur Maf sensor dirty--lots of posts on here how to clean maf sensor--very easy and is what i would do first.
Old 09-26-2012, 08:46 AM   #8
Wilba83
My Ride: Bmw323i
Thanks bud
Old 09-26-2012, 08:47 AM   #9
rd5150
My Ride: 325i
most autoparts stores will read codes for free
rd5150 is offline   Reply With Quote
Old 09-26-2012, 08:56 AM   #10
deanthedude1977
not here in the Uk they dont
Old 09-26-2012, 09:19 AM   #11
dknightd
My Ride: 2002 330 cic
My guess would be you got water in an electrical connection that is making your car think something is wrong. When your car computer thinks something is wrong it goes into limp home mode. See if your air cleaner is wet - it if is you might just need to dry or replace it. Disconnect electrical connections to all sensors, see if there is water inside, if so dry and apply dielectric grease. Likely you problem will go away when the car gets dry. You can let it do that itself, or speed the process along if needed.
dknightd is offline   Reply With Quote
Old 09-27-2012, 12:09 AM   #12
TArse
Originally Posted by Wilba83 View Post
What codes bud
Like the others said. If you have a check engine light on, go to a dealership (unless you can find a code reader elsewhere) get the the codes read, then report back with the codes.
Old 09-28-2012, 04:38 AM   #13
Wilba83
My Ride: Bmw323i
Thanks lads got it running now all okay just got tapping noise now
