Supercharge - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-26-2012, 10:23 AM   #1
Edgar3498
My Ride: 330CI
Supercharge
Hey guys hope your all well. I just finish installing my sc on my 330ci and i have a concern about a "F" shape fitting that my manual doent tell me what to do. I think its the vacuum for the fuel regulator.
Edgar3498 is offline   Reply With Quote
Old 09-26-2012, 10:29 AM   #2
Steven747
My Ride: 05 330ci
what brand supercharger ? i would love a ride if you ever came up to oc
Old 09-26-2012, 10:33 AM   #3
Edgar3498
My Ride: 330CI
Its a vf kit
If you guys have meets over there ill be there because here near Camp Pendleton nobody gets together.
Old 09-26-2012, 10:35 AM   #4
AMG-ETR
My Ride: S54B32 On Boost
Send a message via MSN to AMG-ETR
Check the install guide and that should tell you.
AMG-ETR is offline   Reply With Quote
Old 09-26-2012, 10:37 AM   #5
Edgar3498
My Ride: 330CI
Its says nothing about this F" fitting I've read over and over again
Old 09-27-2012, 04:42 AM   #6
bAby norAA
My Ride: 01 BMW 330i
post a picture of it. I installed my VF kit about 3 months ago, so i should still remember something about it
| VF Supercharged Stage 1.5| Southbend Stage 2 Clutch | ZHP Cams | Technik Headers |
bAby norAA is offline   Reply With Quote
Old 09-27-2012, 11:37 AM   #7
Edgar3498
My Ride: 330CI
Here is the "F" shape fitting that i don't know what to do with it
ID:	471274   Click image for larger version
Old 09-27-2012, 11:46 AM   #8
Weste46
My Ride: 2001 330ci
I believe the top is to the brake booster and bottom is to the fuel regulator? Not sure on a solution..
Corbeau FX1 Pro & CR1, Ultimo front coils, Rob43 9-click rear shocks, Swift 10k rear springs, Meyle FCA's, AKG 95a FCA, 75d rear subframe, Powerflex 95a RTA, 95a RCA, ECS 88a diff., ECS SS brake lines, LTW FW, M3 engine mounts, UUC 5sp black mounts, BMW Performance SSK, open-loop EU2 tune, CAI, headers, x-pipe, minus ~180lbs.
Weste46 is offline   Reply With Quote
Old 09-27-2012, 12:34 PM   #9
Edgar3498
My Ride: 330CI
The top one goes to the manifold an the other one goes to the FPR but should i drip a hole in the charge pipe an pug it there because factory wise thats were it was connected
Old 09-27-2012, 01:49 PM   #10
WALKD U
My Ride: Just Fast!
call VF all kits are different for the FPR...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 09-28-2012, 03:38 PM   #11
bAby norAA
your kit should have come with a vacuum cap. Cap it off.
Old 09-28-2012, 07:40 PM   #12
Edgar3498
My Ride: 330CI
That what i did. Hey has anyone run a BOV on this kit because i want to compare what my BOV does. Instead of discharging quickly its like a long discharge is this normal
Old 09-28-2012, 07:43 PM   #13
SweTurbo
Big Pimpin'
My Ride: 323i -98
Really cap the brake booster ?
What would happen is that under load there would be less and less vacuum in the brake booster , sure not many people drive with a foot on the throttle and one on the brake but imagine something going bad in the throttle or something like that.
Pushing a rockhard pedal while your car accelerates is not something id like to do.
Better soloution is to plug them into the manifolds vacuum ports.
If fpr is to see constant pressure then sure cap it off
Old 09-28-2012, 07:54 PM   #14
Edgar3498
My Ride: 330CI
But this fitting is not connected to the brake booster???
Old 09-28-2012, 08:30 PM   #15
WALKD U
My Ride: Just Fast!
Call vf
2005 AW/IR M3
MaximumPSI Stage4
NA Bolt-ons
1996 BLU/BLK M3
NA Bolt-ons
1988 SETA 325I
NA Bolt-ons
Old 09-28-2012, 09:33 PM   #16
johntrhodes81
My Ride: 2004 325i Wagon
Just did an ESS kit the fuel pressure regulator line should go to the boost side of your intake not the vacuum side of your s/c. So your fuel pressure goes up when you are on boost. The brake booster needs vacuum, connect it to the vacuum side.
Sent from my PC36100 using Bimmer App
John
DIY BMW Performance Style Extra Air Intake
http://forum.e46fanatics.com/showthr...6523&highlight
johntrhodes81 is offline   Reply With Quote
Old 09-29-2012, 06:36 AM   #17
bAby norAA
Originally Posted by TrippinBimmer View Post
Call vf
they were the ones who told me to cap it off. the vf kit comes with a vacuum cap for this reason
Old 09-29-2012, 06:38 AM   #18
bAby norAA
our cars are not meant to work well with a bov. with the maf sensor, your car will run super rich inbetween shifts. get a dv instead
Old 09-29-2012, 10:09 AM   #19
Edgar3498
My Ride: 330CI
I have the botch DV install to. The car runs great an the A/F hasn't change but the BOV stays open an extra second if you compared it to turbocharge why is that
Old 10-01-2012, 06:28 AM   #20
bAby norAA
First you said DV then you said BOV.
