Old 10-01-2012, 02:31 PM   #21
A4RingedONE8T
My Ride: Turbo ///M Roadster
The smaller line is for the FPR and the larger comes off the side of the suction jet pump, it increases vacuum to the brake booster when intake manifold vac is at a minimum. Both need to be connected to a charge pipe pre-throttle body. THEY CAN NOT BE CAPPED OFF!
A4RingedONE8T is offline   Reply With Quote
Old 10-01-2012, 02:34 PM   #22
A4RingedONE8T
Originally Posted by Edgar3498 View Post
I have the botch DV install to. The car runs great an the A/F hasn't change but the BOV stays open an extra second if you compared it to turbocharge why is that
A different spring rate is needed for a supercharged car. BOV's that can be used in both a turbo and SC application (Tial Q for example) have an option for a spring specifically for a blower.
Old 10-01-2012, 09:02 PM   #23
Edgar3498
My Ride: 330CI
Originally Posted by bAby norAA View Post
First you said DV then you said BOV.
Yes my friend i have both install because our cars need the DV and i wanted the ssq bov sound.
So i need to get a stronger spring thats what your saying.
Edgar3498 is offline   Reply With Quote
Old 10-02-2012, 07:42 AM   #24
A4RingedONE8T
If you're using a BOV on top of a DV, then any tuning based off the recirculated air is thrown out the window. No reason to have both. Wanting the "sound" is completely the wrong reason to have added a BOV but I won't go there for the sake of saving myself an endless conversation. If you want the sound, ditch the DV, however there was a reason the kit came with a DV. The car is tuned based on the vented air still being present in the system. Add a BOV which vents air out of the system, A/F changes (richer) on shifts and when the valve is open. You say your valve is staying open longer than necessary, that means it's going even richer. This is not something you will see on a wideband unless you're sampling/logging 30 f/s and viewing the data hours after it happened. Plan on replacing those nice expensive FI plugs about 3x as much just for your "sound"
Unless you understand all the aspects of FI, especially on a motor such as the S54, I would suggest not thinking you know better than the manufacturer and run the kit as intend, or take the necessary steps to retune it for the modifications you are adding
-Shawn-
Old 10-02-2012, 08:58 AM   #25
SweTurbo
Big Pimpin'
My Ride: 323i -98
I love how DV and BOV is not the same thing to you guys.
A BOV and a BPV is not thesame, just like how you think open dump sometimes means an wastegate withouth any muffler
Old 10-02-2012, 10:35 AM   #26
A4RingedONE8T
A DV is a diverter valve, AKA a recirculating valve. That most definitely is not the same as a BOV
Old 10-02-2012, 05:16 PM   #27
SweTurbo
Big Pimpin'
My Ride: 323i -98
Oh , new word to me
I still see people confuse the BPV/BOV and even the dumpvalve(bov) with the wastegate
