///M3 Forum
Old 09-26-2012, 01:48 PM   #1
illestminimike
My Ride: Project Drama
10.5 up front?
Would it clear? I'm thinking about ordering some Varrstoen 2.2.2's
I want to run 11's in the rear. Here's a run down of the sizes I'm thinking
19x10.5 +22 (245/35)
19x11 +25 (255/35)
I'm running the same offset and tire size up front without any rubbing or a fender roll. My question is, will a 10.5 hit anything behind the wheel? Like struts or springs? Has anyone ran it?
Old 09-26-2012, 02:22 PM   #2
Active 2
My Ride: 02 E46 m3
I've definitely seen 10.5 in the front before, but you would have to change the camber for sure
This was his offset: 18x10.5 +25 F / 18x10.5 +20 R (5mm Spacer)
http://www.m3forum.net/m3forum/showthread.php?t=377613
02 ///M3 Jet Balck/ Imola
AA Headers | AA Exhaust | AA tune | Ground Control | AFE scoops | Apex EC-7
Active 2 is offline   Reply With Quote
Old 09-26-2012, 02:47 PM   #3
illestminimike
Seems like it fits nicely.
Old 09-26-2012, 02:50 PM   #4
illestminimike
The offsets won't be a problem. I shouldn't even have to roll my front fenders. I just need to make sure everything clears behind the the wheel.
Old 09-26-2012, 10:07 PM   #5
BWOODM3
My Ride: 2002 M3 convertible
Post pics when you get these on.
BWOODM3 is offline   Reply With Quote
Old 09-26-2012, 10:10 PM   #6
illestminimike
No. It'll be a secret.
Old 09-26-2012, 10:14 PM   #7
BWOODM3
Or maybe you can keep them in the closet, like your other secrets. Shhhh!!! :O!!!
Old 09-26-2012, 10:23 PM   #8
illestminimike
Lol I'll be sure to post pics.
Old 09-27-2012, 03:31 PM   #9
JiMMyM3
My Ride: e46 M3
I've seen it done as well, with a lot of neg camber and a 245 on a 10.5. I kinda don't see the point of having a 10.5f unless your running a square setup, and even then its overkill on the st.
JiMMyM3 is offline   Reply With Quote
Old 09-27-2012, 03:52 PM   #10
illestminimike
I'm going to run a 245/35. The offsets are higher then what I have right now. I don't rub at all and my fenders aren't rolled. Why would I need to run so much camber? I'm 9.5 +17 245/35 right now. With OE specs on my camber.
Old 09-27-2012, 07:21 PM   #11
wannasupra
My Ride: 2006 Hayabusa
i've got some 18x10 classics in front, not sure of the offset, but they clear the backside with plenty of space. no rubbing, no fender roll.
wannasupra is offline   Reply With Quote
Old 09-27-2012, 07:25 PM   #12
illestminimike
Perfect! Just what I needed to her. So your saying that you have at least another half inch of clearance behind the wheel? If you can post some pics of your front fitment that'll be really helpful.
Old 09-28-2012, 01:03 AM   #13
illestminimike
Also, what tire size you running?
Old 09-28-2012, 09:45 AM   #14
DSilk56
My Ride: M-3 Convertible
Why use 10.5 inch rims to mount 245 section tires that will easily fit on an 8.5 inch rim? Those rims seem awfully wide for the rubber you are proposing, and I would wonder whether or not the tire beads will effectively seat on the rim or whether you will be sacrificing handling for the look of a wide wheel.
DSilk56 is offline   Reply With Quote
Old 09-28-2012, 11:56 AM   #15
illestminimike
Because racecar.
Old 09-28-2012, 12:09 PM   #16
ModBargains II
ModBargains II's Avatar
My Ride: Evo 8GSR
Send a message via AIM to ModBargains II
Originally Posted by illestminimike View Post
Because racecar.
Hey miniMike you better bring your racecar with the new wheels to the ModBargains meet going down October 13th
I really want to see how awesome the M3 is going to look!
We Specialize In: BMW Parts | BMW Tuning | Avant Garde Wheels | VMR Wheels | BMW Headlights | Alufelgen Wheels
Sales
| Gilbert@ModBargains.com | (714) 582-3330 ext. 8004
Hours: Monday - Friday 8:00am-7:00pm | Saturday 8:00am - 5:00pm (PST)
ModBargains II is offline   Reply With Quote
Old 09-28-2012, 08:30 PM   #17
wannasupra
lemme try and get it up on a rack tonight. gonna try and help pull a motor from my buddy's e36M. after it's off, maybe i can pick mine up. there's clearance tho. not certain what my offsets are tho.
Old 09-28-2012, 08:58 PM   #18
illestminimike
Lol hopefully I can have them ready before then! But I will be at the meet for sure. I need Dogzilla!
Old 09-28-2012, 09:00 PM   #19
illestminimike
Thanks a lot for the pics you already sent me. Now I know what my stretch is going to look like. But if you can check the clearance behind the wheel that'll be awesome. I'm sure it fits but it's always a good idea to double check.
Old 09-28-2012, 09:05 PM   #20
wannasupra
i reached around behind the best i could, seems to be plenty of room behind it. still gonna try and check it out. i'm heading to my buddy's place now.
