Sponsored by BimmerWorld
Old 09-26-2012, 04:55 PM   #1
Lordray
My Ride: 2005 325Ci
Whirring noise and vibration when braking
I have the whirring wheel noise when turning and also vibration when semi braking heavily. The steering wheel doesn't shake. I have replaced the front lower control arm bushings and replaced pads and rotors all the way around.
Could it need new front control arms?
(Ball joints in the middle beingshot)
Or perhaps trailing arm bushings?
The back end doesn't feel loose at all tho.
Lordray is offline   Reply With Quote
Old 09-26-2012, 05:10 PM   #2
BimmersGarage
My Ride: E46 330i
Have you checked your hub/bearings?
BimmersGarage is offline   Reply With Quote
Old 09-26-2012, 06:34 PM   #3
Lordray
My Ride: 2005 325Ci
Yes the bearings don't make any noise at all hen you freely spin the wheel. That can cause a whirring noise. But would it cause a shake while braking?
