Old 09-26-2012, 11:59 PM   #1
E46er75
My Ride: 323i Vert, 330xi
Rough idle vibration when cold//No CEL
Tis the season. I remember towards the end of last year I started to notice a rough idle when it was getting cold. I notice it mostly when I'm sitting at a light or in a drive thru while in gear. Anyone else have this problem? I'm wondering it is the motor mounts?
E46er75 is offline   Reply With Quote
Old 09-27-2012, 05:14 AM   #2
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you check the first link below in my signature.
I would focus on the DISA, DISA O-ring & CCV lower oil return hose that connects to the dipstick tube.
There may be other areas or things to check, but the above are the most common culprits.
Old 09-27-2012, 09:40 AM   #3
E46er75
Yup, already read this. Great write up, but I have no CEL and for the most part all parts mentioned have been replace. The only piece not replaced was the intake boot, but it's still in good condition with no visible tears or holes.
Old 09-28-2012, 06:24 AM   #4
jfoj
No CEL does not mean you do not have vacuum leaks, maybe not be enough to trigger the CEL? Does the CEL work with a bulb check? Have you checked codes?
Could be soft fail fuel pump? Might want to perform wet & dry compression check and cylinder leakage test as well to rule out burnt valves?
Old 09-28-2012, 08:27 AM   #5
moiz21
My Ride: 1999 323i 5-SPD
May also want to look into the VANOS seals. My brother had some cold start issues and idling fluctuation before I changed it as well.
MODS
P46 Projectors + FX-R Retrofit + 6k D2S / 60 LED AE's / Smoked LED Tails / Smoked Turn and Side Markers / BSW 10" Sub /ZHP Knob / Matte Black Grills / DICE / Parrot + Connects2 / OEM Alternative Alarm Mod / Clutch Switch Delay Mod / M3 Rep Front Bumper / 3M Black CF Di-Noc Wrap / K&N Intake / 35% Tint All Around / Black Short Eurotray / 545i Shifter
moiz21 is offline   Reply With Quote
