Cluth install issue - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 09-27-2012, 04:52 PM   #1
shakejuhn
My Ride: e46 325xi
Cluth install issue
I need you help guys. I let a mechanic do my clutch i had purchased the kit off ecs this is it here.
Brand: Genuine BMW
ES#: 40923
Mfg#: 21207531556
https://www.ecstuning.com/Cart/?utm_..._source=sbowen
Now he is telling me he needs special tools to do it. I had purchased a clutch allignment tool from pelican parts. http://www.pelicanparts.com/cgi-bin/...gh%202%2F03%29
he said that part is right but he is missing a piece.
This is the piece he says he is missing. .
What is it and where can i get it, or do i even need it. the guide on pelican parts wasn't to clear.
shakejuhn is offline   Reply With Quote
Old 09-27-2012, 09:11 PM   #2
325xittt
My Ride: 2003, 325 XIT
You should only needed the alignment tool from pelican parts. The clutch comes with a retaining cage clip that should not be removed until the clutch is installed. If the clip it is removed before the clutch is installed then a special tool like you show in your post will be required to reset the clutch self adjust feature prior to installation.
325xittt is offline   Reply With Quote
Old 09-27-2012, 09:22 PM   #3
phubar
My Ride: 335is, HD
He can also use a bearing puller and a BIG socket or something similar, I had an issue where I couldnt line up the input shaft due to clutch disk slightly off center, used a bearing puller and realigned the clutch disk, using the method here http://forum.e46fanatics.com/showthread.php?t=629140
phubar is offline   Reply With Quote
Old 09-28-2012, 07:45 AM   #4
shakejuhn
My Ride: e46 325xi
Ok thanks for your help guys. All the support i got on here make me never want to leave. Next car is def a bmw
