Old 09-27-2012, 11:43 PM   #1
daimler55
My Ride: 2000 328i
vanos stud broken
i replaced my dual vanos on my 2000 328i, everything went good until one of the six mounting studs that hold the vanos assembly to the engine head snapped due an error on my part of over tightening it. can anyone tell me if this will have any negative impact on the car as far as performance or possibly a leak. ive done a bit of research it seems like taking it off to remove the broken stud is a hassle
daimler55 is offline   Reply With Quote
Old 09-28-2012, 12:01 AM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
Are you talking about the valve cover gasket?
I had a broken center front stud, just between the half moons for over 30k miles and never had a leak, I suppose it depends on which one broke though.
Old 09-28-2012, 12:08 AM   #3
daimler55
My Ride: 2000 328i
when removing the vanos, there are 6 nuts underneath the unit that holds it to the enging head. one of the studs broke when i was tightening the nut back after putting the new unit on
Old 09-28-2012, 12:09 AM   #4
daimler55
My Ride: 2000 328i
here is a pic of what im refering to
http://images.search.yahoo.com/image...mb=4hj8uQm5tZA
Old 09-28-2012, 12:26 AM   #5
Zell
Zell's Avatar
My Ride: so turbo wow
http://www.realoem.com/bmw/showparts...70&hg=11&fg=15
Part #13
You're good, dude. Just replace it.
Old 09-28-2012, 12:29 AM   #6
daimler55
My Ride: 2000 328i
hey thanks for the replies...if i dont replace it just for the sake of not wanting to open everything up and risk screwing up something else again...any problems if i just leave it alone
Old 09-28-2012, 08:43 AM   #7
ixtoxi
My Ride: 02 330xi, 88 325iX
There are six studs for a reason. With one missing, there will be less pressure on the gasket at that location, which will likely result in a leak eventually. Performance would not be affected unless the leak were severe. But, if it were me, I would pull the VANOS and replace the stud. Not doing it would drive me crazy!
ixtoxi is offline   Reply With Quote
Old 09-28-2012, 08:47 AM   #8
Hrvat
My Ride: 02 Imola Red M3
I agree with above. Pull the vanos and you should be able to grab that bolt with vice grips and get it out. Actually you might even be able to back it out with bare hand since there is no pressure on it
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
Old 09-28-2012, 11:18 AM   #9
Mctwist77
My Ride: '99' BMW 323i
Hey man read my thread
http://forum.e46fanatics.com/showthr...960&highlight=
Same thing happened to me, let me know if you need any help
Photobucket
BMW 323I 5 Speed
Mctwist77 is offline   Reply With Quote
