Old 09-27-2012, 11:45 PM   #1
NWEnglish
My Ride: 2006 325ci
Relay HIDs Or Not
My 2006 325ci came with projector lows so I installed a HID kit. Everything works fine (plug and play) but once in a while one or the other (but not both at the same time) lights goes out untill I work the headlight switch several times to get the dash warning to go out. I have searched the posts here and found a lot of opinions on relaying or not. Since the watage is close to the original should I have these lights going out without a relay???
NWEnglish is offline   Reply With Quote
Old 09-27-2012, 11:49 PM   #2
Hornung418
My Ride: '04 MB ZHP
OEM or bust...and you don't have Xenons if you had to add a kit. Get better light bulbs and avoid the problem altogether.
Sent from my DROIDX using Bimmer App
Hornung418 is offline   Reply With Quote
Old 09-28-2012, 12:46 AM   #3
MJLavelle
My Ride: 2001 BMW 330ci
The ballasts are not strong enough to light the bulbs, and it can take multiple tries to get them to fire. A better brand of bulb will definitely fix this.
Old 09-28-2012, 01:02 AM   #4
kleen'n'simple
My Ride: E90
you should be fine with a relay
kleen'n'simple is offline   Reply With Quote
Old 09-28-2012, 02:34 AM   #5
MJLavelle
It won't fix your problem, but you will be fine.
The resistance in the bulbs is too much for the ballasts to overcome. What brand of bulbs do you have? I had this issue with TheRetrofitSolutions bulbs, and older factory ballasts. When I swapped in a set of newer ballasts that I had for spares, the problem went away. But the old ballasts had no issues with the factory OEM bulbs (I forget the brand). So, either replace your ballasts, or go with factory bulbs.
