Old 09-28-2012, 02:38 AM   #1
zcchen
My Ride: Z3M/F80M3
KW V3 swift/hyperco spring conversion? Spring OD comparison?
Hi,
I am running KW V3s and having issues with inner clearance on the front, my tires are rubbing the springs.
I wonder if Swift or Hyperco springs have a smaller OD so that I can gain more clearance from switching over.
Thank you
zcchen is offline   Reply With Quote
Old 09-30-2012, 08:33 PM   #2
flipm3
My Ride: 02 M3, 97 328i
Send a message via AIM to flipm3
What is your wheel/tire size and offset?
Is it rubbing the spring perch or spring itself?
2002 E46 M3 6MT | Jet Black . Black Nappa | My Build Thread
Evolve Automotive CF Airbox & AlphaN . Supersprint V1 Stepped Headers & V1 SPipe
flipm3 is offline   Reply With Quote
Old 10-01-2012, 01:11 AM   #3
Bayerische E46
My Ride: -
Don't bother changing the springs as the KW shocks are made to work with the KW spring "rate." Get yourself some wheel spacers (with either extended wheel bolts or upgrade to studs) and you'll solve the problem. It's much cheaper and tons faster.
Bayerische E46 is offline   Reply With Quote
Old 10-09-2012, 03:23 PM   #4
ECSTuning
ECSTuning's Avatar
My Ride: BMW
A lot of guys end up needing a small spacer. 5mm is ofter enough to gain clearance for the coilover. If you have clearance between the wheel and fender/quarter panels you should be able to easily correct your problem. HERE is a link to my spacers of your E46 M3.
Old 10-09-2012, 03:29 PM   #5
ModBargains III
ModBargains III's Avatar
My Ride: E46
Depending on the wheel size, that might not work actually. Seeing that the OP has an M3, he's probably running something around a 18x10 I would imagine, probably a low offset. A spacer would do the trick, but to make up for how much wheel is sticking past the fender, you'll need to add camber, and then we're back to square one. Adding in a linear spring will help, and I've had multiple customers change to swift springs to avoid clearance issues on KW's due to their beehive shaped spring.
OP, If you need help, let me know, we're a Swift spring dealer
Sean S. | Sean@ModBargains.com |(714) 582-3330 ext 8009
We Specialize In: BMW Brakes | BMW Suspension | BMW Parts | BMW Exhaust Experts |
BMW Wheels In Stock | BMW Intake Experts
Hours
Check out our Blog for updates & discounts!
ModBargains III is offline   Reply With Quote
