///M3 Forum
Old 09-28-2012, 10:54 AM   #1
necompressor
My Ride: 323ic
High mileage M3 vert
Looking at a 02 M3 vert with 174k, 6 speed. Body clean, no records, interior rough, new tires. Seems to run ok, a little ticky. Convertible top doesn't work. Is it worth 8k? thx
necompressor is offline   Reply With Quote
Old 09-28-2012, 11:02 AM   #2
E46_330i_Stud
My Ride: 2004 330ci ZHP 6MT
Records mean nothing. It's the stuff that was done. Ticking? Probably valves or vanos. Which means no. Assume the car needs $5k worth of work. Is the car worth $13k in perfect condition? Probably not.
1995 325i 5mt ArcticGrey/Dove - SOLD
2004 330ci ZHP 6MT SilberGrau/Black - SOLD
2001 330i M-Sport 5MT StaulGrau/Grey - SOLD
1992 Accord LX Sedan 275k miles all original - DAILY
2002 Chevy Suburban LT Autoride - TOY HAULER
2005 GMC Sierra 2500HD SLT - RACE TRUCK!
E46_330i_Stud is offline   Reply With Quote
Old 09-28-2012, 01:08 PM   #3
illestminimike
My Ride: Project Drama
Probably not.
Old 09-28-2012, 04:07 PM   #4
Mr. Din
My Ride: e46 M
if you going to do the work yourself to repair the issues then maybe. if not spend a little more money.
[/URL]
Mr. Din is offline   Reply With Quote
Old 09-28-2012, 04:15 PM   #5
ChrisRedmon
My Ride: 2002 PY ///M3
You have to understand the S54 is a noisy engine in general. Ticking in these cars isn't normal i would say.....but its not life threatening to the car... It probably needs a valve adjustment. Clean the fuel injectors. Make sure there's no exhaust/vacuum leak. Bushings. Fluids. Gaskets. It will need some work....do it yourself. Or you might as well buy a lower mileage one with the money you will spend on labor. And you should be good until the engine/trans really takes a dump. Which could be forever and ever if it was taken care of
2002 Phoenix Yellow E46 M3 l 6MT l Nappa l Nav l STG Coilovers 7k/8k l BMW Performance SSK l OEM ZCP's l Kirk Roll Bar l Motorsport Hardware l Besian Systems l CSL/GTR Carbon Fiber Hood, Trunk & Diffuser l Status Gruppe Sec. 3 l Custom Rear Brace l Rear Seat Delete l Coby Wheel Products
ChrisRedmon is offline   Reply With Quote
Old 09-28-2012, 04:21 PM   #6
choxor
My Ride: JDM
Nope.
And my car does not tick. Normal for you maybe.
choxor is online now   Reply With Quote
Old 09-28-2012, 04:23 PM   #7
ChrisRedmon
I never said it was normal. Every thread this man is a douche^^^^
If you want it, get it. Just be prepared to do some work to it. Good luck
Old 10-01-2012, 11:09 PM   #8
Beamer Creamer
My Ride: 2005 bmw m3
Agreed chris.
Beamer Creamer is offline   Reply With Quote
Old 10-02-2012, 05:12 PM   #9
necompressor
My Ride: 323ic
Whats the number making it worth a roll of the dice?
7k?
Old 10-02-2012, 06:31 PM   #10
illestminimike
I don't think choxor is a douche. He is actually very helpful.
Old 10-03-2012, 10:25 AM   #11
DSilk56
My Ride: M-3 Convertible
Fixing the convertible top could set you back thousands of dollars, depending upon what's wrong. Have a trusted mechanic look at the car thoroughly, give you a list of everything that needs to be done along with an idea of what it will all cost. Don't forget the interior pieces (which you will need to repair or replace). If the total (including your purchase price) exceeds $13K or $14K, look for another car. Keep in mind that an M3 with 174K miles may not be far from a complete engine rebuild (depending upon how it was driven and maintained), and that can mean big money.
DSilk56 is offline   Reply With Quote
