Old 09-29-2012, 12:58 AM   #1
10bimmer
My Ride: 1999 323i
Help!? headlight out showing in dash don't know why.
I have a 1999 323i and it has both lights on that is showing that my headlights are out. However both work perfectly fine and the high lights as well with no problem. I'm a bit confused as to why the lights on. Help?:/
10bimmer is offline   Reply With Quote
Old 09-29-2012, 01:00 AM   #2
Lusticles
My Ride: 325Ci
Turn signal maybe.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 09-29-2012, 01:01 AM   #3
10bimmer
My Ride: 1999 323i
Idk what that is either ha
Old 09-29-2012, 01:08 AM   #4
cityjohn
My Ride: 2001 M3
The orange light. It's on whenever the headlights are one or whenever your turn signals are blinking. If the car's computer senses a voltage discrepancy in these bulbs it will show the same red light on the dashboard as the headlights.
1. Take out the bulbs in the orange lights.
2. Clean the contacts on the bulb.
3. Bend the contacts in the socket so they push harder against the bulb.
cityjohn is offline   Reply With Quote
Old 09-29-2012, 05:11 AM   #5
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
OP, yes...see if either your turn signal (you know what that is, right?)...or fog lights...are off. Check your low and high beam headlights both.
Some light isn't working.
It could, you know, just be the bulb has burned out...but City is right that the turn signal can fail just because the lower tab in the socket has been pushed down too far to hold bulb firmly. Pull it up a little from the bottom--disconnect it first though before playing around with it.
See me in June!
dmax on Facebook
Mangofy your E46!
dmax is online now   Reply With Quote
Old 09-29-2012, 08:47 AM   #6
THECLEANERBEAMER
My Ride: 2002 325i
You don't happen to have led bulbs upfront do you? It could show that if you don't of resistors for LEDs
Instagram:thecleanerbeamer
THECLEANERBEAMER is offline   Reply With Quote
