Old 09-29-2012, 01:24 PM   #1
Stutoyou
My Ride: 01 330ci
Remote Unlock / lock fail
My 2001 330ci developed these gripes, I believe, at the same time...
1. Remote key fob lock / unlock for doors and trunk does not function with either key - (works every time manually with key in exterior door lock, interior handle and also with the center switch – trunk release button under dash also works fine)
2. Windshield washer fail – (Wipers work fine including, I believe, rain sensors)
3. Cruise Control fail
4. Constant beeping when driver door is open and key not in ignition - headlights off - (as if key was in ignition or headlights on)
5. Red flashy light on rearview mirror / windshield fail
All windows work fine from the switches. The key remotes checked good at the local auto parts store – they have an IR / RF tester.
This kinda sounds like a GM5 gripe from what I’ve been reading, yet it seems to be different from the other complaints I have read. What do you think?
Scott, the General Module repair guy, excuse me, "engineer" at BMWGM5.com had this reply to the above information:
Your email is very confusing. Only tell me what DOESN'T work. If I need more information I will ask. Also key fob remote not doing anything is not a general module problem so that problem is out of the way so you don't need to mention that one again.
And then:
1 have you checked the pump motor.
2 cruise, has NOTHING to do with the general module
3 beeping has nothing to do with the general module
4. Fix 3 above and then lock/arm car with a working remote.
He might have missed the part where I said I tested the remotes...
Stutoyou is offline   Reply With Quote
Old 09-29-2012, 02:12 PM   #2
eneka
My Ride: 2003 325i
1. Have you tried re initializing the keys?
4. sounds like the ring is failing
5. the alarm light/clown nose? Has it ever flashed? If not then it's just not activated (you don't have an alarm)
edit: The beeping, it means that the car thinks that the key is still in the ignition therefore disables all the remote functions on the key. So I'm assuming it's you ignition ring for problem 1&4
eneka is offline   Reply With Quote
Old 10-01-2012, 12:00 PM   #3
Stutoyou
My Ride: 01 330ci
Okay. That makes sense. I unplugged the ring and the beeping stopped. I tried re-initializing the remote, but no joy there. The remote did not start working so I'm assuming (dangerous I know) that the ring must be functioning for the remotes to work?
However... I understand the Ring is just an inductive coil / antenna for the EWS and also to charge the key fob battery. If the coil was bad, wouldn't the car not start for not getting the signal from the key? Also, the car does not crank with the ring unplugged.
To reiterate, the car starts and runs fine - the remotes just dont work.
Does the tumbler itself mechanically sense when the key is inserted?
Old 10-01-2012, 01:25 PM   #4
Stutoyou
My Ride: 01 330ci
So this seems to get more confusing as I go... I have read posts which seem to point to the ignition switch as the source of many electrical gripes and gremlins. None, however, have indicated that is the cause of
1. The beeping.
2. The remotes not functioning (probably because the vehicle thinks the key is inserted and has disabled the remote functions)
Sooo... Who can tell me which part actually senses the "key in ignition" and thereby causes the beeps?
Old 10-01-2012, 06:53 PM   #5
scottjoh
Modded ///Member
My Ride: '99 323i & '02 540i
No I didn't miss the part about testing the remotes. I did reply with, "Also key fob remote not doing anything is not a general module problem so that problem is out of the way so you don't need to mention that one again."
I have no doubt that the key fob remote works fine. You said you tested it and I believe you so no need to discuss it anymore. You need to find out why the car seems to be sensing the key in the ignition even when it's been removed.
Yes, the EWS must detect and authenticate the key to begin the key sync process.
Correct, if the coil was bad it would not be able to read the key and the EWS would not authenticate and enable the fuel pump and unlock the DME.
No, it does not detect the key mechanically. As a test I wrapped the head of the key with aluminum foil so the EWS could not detect the transponder and no beeping.
A bad ignition switch can and does cause a lot of weird electrical problems
1. The beeping.
The EWS senses the key in the ignition. The beeping is from the instrument cluster and is a combination of the signal from the EWS key detect and the door ajar sensor. I don't know where the logic is performed to logic AND the two inputs together. Key sync can not be performed if the car thinks the key is in the ignition and remote functions (lock, unlock and trunk release) are all inhibited.
Hope that helps.
Scott J.
scottjoh is offline   Reply With Quote
Old 10-01-2012, 07:40 PM   #6
Blind_Shooter
My Ride: is your sister
I have the same problems you described in 1 and 4. i cannot figure this out as sometimes when i lock/unlock the trunk they keypad will work. just bizzare, and ive reinitialized the keys like you did. Let me know if you ever solve this.
smells like crayons
Blind_Shooter is offline   Reply With Quote
Old 10-03-2012, 07:58 AM   #7
Stutoyou
My Ride: 01 330ci
Thank you Scott for the extremely cogent and relevant reply. Based on your (and others) input, I do not believe the GM is bad. I will first try replacing the ignition switch and post the result.
Old 10-03-2012, 04:04 PM   #8
scottjoh
Modded ///Member
I don't know what it is, but, it's not the GM.
Old 10-06-2012, 11:33 PM   #9
Kinger97531
My Ride: 2003 325 + NOS
Possible fix
Just had the same problem after trying to fix a different problem.
I had everything you described above, there is a TSB that describes it.
Basically make sure you have a good fuse or a fuse at all in spot f67 located in the glove box. It fixed all my trubs, you may also need to resync your keys if you tried that while troubleshooting. Hopefully you will be able to fix it with this and return the ign switch to the stealership.
Kinger97531 is offline   Reply With Quote
Old 10-27-2012, 10:13 AM   #10
Stutoyou
My Ride: 01 330ci
Replaced the ignition switch. No change. Re-checking fuses today (third time). Only real gripes are no remote lock / unlock, constant beeping with driver door open and key NOT in ignition (yes, the headlights are off for all the comodians out there), AND the cruise control does not work.
Old 10-31-2012, 04:08 PM   #11
Stutoyou
My Ride: 01 330ci
Okay, so get this... After replacing the ignition switch (no change) and re-checking all the fuses (all good) I did this:
With the driver door open and key NOT in ignition (still beeping) I removed the connector to the EWS Ring (still beeping)
Then I closed the drivers door, put the key in the ignition and turned the key as if to start the engine (Of course, it did not start) and turned it off.
I re-initialized the key and lo and behold the remote started working. I replaced the connector to the EWS Ring and it still worked - no beeps remote lock and unlock was good.
The thing is though, it only works for a short period of time (unknown amount).
This also had no effect on the cruise control gripe
Getting closer and stranger at the same time. Possible EWS gripe?
Old 11-15-2012, 10:37 AM   #12
M4TT
My Ride: 2007 BMW 328i
Any resolution to this?? I have the exact same problem with 2 of my cars.
One of them I did a 5 speed swap on and the other just started this problem last week. I did the same trick with the EWS ring and had the same results. It will work until you put the key back in the car then it stops and the beeping starts again.
M4TT is offline   Reply With Quote
Old 11-15-2012, 01:04 PM   #13
scottjoh
Modded ///Member
Stutoyou,
That's interesting. The EWS coil had to be working before because you could start the car just fine. But, the EWS does play a part in the beeping. The EWS seems to be the part that detects the key in the ignition (I tried wrapping the head of the key in aluminum foil and it no longer starts the engine, but, it also didn't beep when the door was open and unwrapping it started the beeping again). The EWS sends messages across the K-bus to some other module and one of the modules (instrument cluster perhaps) determines if beeping is appropriate based on other inputs like lights (from LSZ) and doors (from ZKE). What could be messed up I don't know.
Old 11-15-2012, 07:44 PM   #14
Stutoyou
My Ride: 01 330ci
Gonna look for an EWS Schematic. Anyone have one?
Old 11-15-2012, 09:13 PM   #15
scottjoh
Modded ///Member
Try putting an IBUS Analyzer on the K-bus and watch for the key detected and key removed messages from the EWS fly by.
Old 02-13-2013, 06:53 AM   #16
Blind_Shooter
check fuse 60 i believe. will solve your problem. its the immobilizer fuse.
smells like crayons
Old 02-14-2013, 11:36 AM   #17
scottjoh
Modded ///Member
Blind_Shooter, I think you mean fuse 67. The fuse card lists fuses 14 and 67 as Immobilizer. One indication of a blown fuse 67 is the car beeps at you when the door is open like the key is in the ignition when it's not.
beeping, cruise control, remote locking, remote unlock
