Broken vacuum line idk what it is??? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-29-2012, 02:26 PM   #1
generic
My Ride: 2002 BMW 330ci
Just as the title says I have a dryrotted vacuum line that broke and I have no idea what it is. The line is located on the upper intake boot and I have included a pic, any references and answers are greatly appreciated. Cost to fix/ difficulty level bonus points thank you so much. The line in question is the bottom line on the fitting going into the upper intake boot.
generic is offline   Reply With Quote
Old 09-29-2012, 06:36 PM   #2
j_block
My Ride: 2003 325i
I think that goes to your secondary air pump. But I'm not sure
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 09-29-2012, 08:06 PM   #3
sfcjetjr
My Ride: 2002 BMW 325i
Goes to fuel pressure regulator on the fuel filter.
sfcjetjr is offline   Reply With Quote
Old 09-29-2012, 08:38 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
So proper would be to replace the line...and on yours, I'm not sure if it meets a hard vac line or not...but you could just splice in a new section of hose with some barbed nylon couplings you'll find in any hardware store and worry about the rest of the line later at your convenience. If it's just the end, snip it off and see if you have the room to just reconnect it ...there might be play in it...and then you'll have time, as I said, to repair it at your leisure.
I dabbed some rtv on one of my little cracks and it actually held for 2 years! LOL
Oh, realoem.com for PN for everything, but you could, if you needed to, just snip off or measure a section of hose and get something comparable at local auto store. It's just an air hose...and that one...the small one, does go to the FP regulator, which on yours is on the fuel filter...which in above a panel that's below your driver's seat...on bottom of car.
Laugh with me! Don't be lame! Broadway Comedy Club, NYC, July 14, 8 p.m. See Facebook for other shows and PM me if you can make one.
dmax on Facebook
Mangofy your E46!
Old 09-29-2012, 11:19 PM   #5
generic
Thank you so much will be taking a look at it tomorrow and see best option, will that line being broken give me any lean codes or affect my mpg?
Sent from my DROID3 using Bimmer App
Old 09-30-2012, 03:24 PM   #6
D.t
My Ride: 2002 325i
Goes to a plastic like line behind motor to a silver vacuum canister on pas side front
Sent from my DROIDX using Bimmer App
D.t is offline   Reply With Quote
Old 10-01-2012, 12:36 AM   #7
WALKD U
My Ride: Just Fast!
x2 Just remove the rubber vaccum line and install 2" of 6mm line to the fitting and plastic tubing...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
