Old 09-29-2012, 03:14 PM   #1
2003silver330i
My Ride: 03 BMW 330i
Limp Mode with EML and SES light
Car went into limp mode today and all of the emergency lights came on.
F3 Misfire, Cylinder #6
E3 O2 Sensor adaptation limit, Cylinder #1-3
77 Throttle Position Sensor 2, plausibility, range, or performance
Any ideas?
2003silver330i is online now   Reply With Quote
Old 09-29-2012, 03:27 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
Clean the throttle body. Else replace it. Check for codes after that. The O2 sensors might be going bad, but you should rule out the TPS first.
Old 09-29-2012, 04:02 PM   #3
2003silver330i
I cleaned the throttle body two times about a month and a half days ago. I'm pretty sure that sucker is cleaned.
Old 09-29-2012, 04:42 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Suggest you start with the first link below in my signature.
Pay attention to the intake boots.
Could be a battery/charging issue, MAF, throttle body or a badly leaking intake boot?
Old 09-29-2012, 10:11 PM   #5
2003silver330i
Cleared the codes and drove around for five minutes and the SES and EML light is back on. Checked the codes and the only one showing is the 77 Throttle Position Sensor 2, plausibility, range, or performance. Intake boots are perfect and dash indicator says the battery voltage is correct.
Old 09-29-2012, 10:14 PM   #6
scarede46er
It is the throttle body most likely. Might have to bend over and get a new one.
Old 09-29-2012, 10:38 PM   #7
warriorpluto
My Ride: 2000 323i
Where is the best place to get a new one beside the dealership?
Sent from my Galaxy Nexus using Bimmer App
warriorpluto is offline   Reply With Quote
Old 09-29-2012, 10:49 PM   #8
scarede46er
I found a good price here: http://www.autohausaz.com/search/pro...er=13547502445
Old 09-29-2012, 11:15 PM   #9
2003silver330i
I cleared the code (77) several times and the freakin thing comes back within a minute with the car is in park and just idling. I also notice that the engine idle slightly moves up and down. Thanks scarede46er, I tend to agree. If that don't fix it then the only thing left to replace is the engine wiring harness.
Old 09-30-2012, 12:22 PM   #10
2003silver330i
Checked the manufacturer date on the EDK throttle body and it is dated 09-09-02 so it looks like I have the newest version according to, service bulletin SI B 12 10 02. I can't find any damage on the engine wiring harness so looks like a new TB is in order.
Old 09-30-2012, 01:24 PM   #11
jfoj
Has the lower intake boot been replaced or removed lately??
Many times the lower boot flap can get caught on the inside of the throttle body. Easy enough to check, just remove the upper intake boot and use a flashlight to look down lower intake boot.
Old 09-30-2012, 01:40 PM   #12
2003silver330i
Too late to check, I have the car torn apart including the rubber intake boot. I cleaned the TB again and did an adaptation test and the TB plate seems to be working fine. I'm just not sure how far the TB plate should open before closing when turning the key to the ON position. I also gave the EDK sensor a good whack with a screw driver (figure its worth a shot).
Old 09-30-2012, 03:54 PM   #13
2003silver330i
Everything put back together and let the car idle for like 10 minutes and no warning lights. Fingers crossed.
Old 10-04-2012, 09:24 AM   #14
2003silver330i
Well its back. Started the car this morning after sitting all night and the engine ran rough causing all the warning lights to kick on. Checked the codes and it was 73 again followed by code 87. Cleared them and ran the car for another minute and only 73 showed up. Warmed the car up and cleared the 73 code and drove it with no problems.
Old 10-04-2012, 11:54 AM   #15
tamb
My Ride: 323i se
this happind too me water got into electrics and blew sensors pointmeter was broke and something too doo with throtlle now its sorted and eml and engine manigment light is of just bit noizy from injecters and pedal is a bit stiff
tamb is offline   Reply With Quote
Old 10-04-2012, 02:14 PM   #16
2003silver330i
tamb, so your throttle body went bad?
Old 10-06-2012, 08:33 PM   #17
2003silver330i
New codes today:
F0/F1 Misfire, Cylinder #3 & 4
E4 O2 Sensor adaptation limit, Cylinder #4-6
Just seems to be random misfires with no rhyme or reason and is starting to happen more frequently. On top of that I have codes for all 6 ignition coils misfiring that never go away even though I have 6 brand new coils and spark plugs. Car idles like shat cold after sitting over night until it warms up. WTF is wrong with this freakin car.
Old 10-08-2012, 03:48 PM   #18
2003silver330i
Codes 73/87 today so I decided to break down and order a brand new Semiens TB. Hopefully that solves my problem.
EDIT: I doubt that it solves my problem because of my shitty luck.
Old 10-10-2012, 03:23 PM   #19
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Gl!
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-10-2012, 03:32 PM   #20
My Ride: Lexus
buy mine for $80 and return yours. pocket money and use to replace camshaft position sensors (didn't fully read your post but you get my idea)
gl!
