Old 09-30-2012, 08:00 AM   #1
Alexotronic
Alexotronic's Avatar
My Ride: 2001 330Ci
Clip Clip Clop Clop Ticking Noise *Video*
Hello, does anyone have any idea on what could be causing this strange noise in my engine? It sounds like a mix between a horse galloping and a blinker.
Alexotronic is offline   Reply With Quote
Old 09-30-2012, 08:11 AM   #2
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
Disa valve rattles, so I hear...but haven't heard it 'live.' Check that.
Look at motor mounts...if you see the top of one of them, usually driver's side goes first I think, you might see fluid filling the top circle of it. That might be causing rocking that's translating to a clopping somewhere...if you have an auto trans, the fan can lightly hit the shroud as the engine rocks a bit. I don't 'think' it's that, but it's easy enough to look for.
Use a hose as stethoscope...or a stethoscope as stethoscope...and isolate the sound. Be careful around moving parts!
See me in NYC in May!
Comic Strip Live, May 12, 6 p.m. & Greenwich Village Comedy Club May 20, 6 p.m.
dmax on Facebook
Mangofy your E46!
dmax is online now   Reply With Quote
Old 09-30-2012, 08:20 AM   #3
emgee
My Ride: 3 pedal 2005 325xi
it could be because you used cheap gas. if not then it can be bad spark plugs or that you have deposits on the cylinder walls. time for a tune up
emgee is offline   Reply With Quote
Old 09-30-2012, 08:23 AM   #4
Alexotronic
My Ride: 2001 330Ci
I think that a DISA rattle would be localized at the DISA, this sound seems to be coming from everywhere.
Also, I have removed the disa/ICV/throttle body before and tested function.
Only 90+ octane gas. Replaced the spark plugs a couple of months ago.
Old 09-30-2012, 08:24 AM   #5
emgee
D i thought Disa valve rattles a bit more violent than this. i could be wrong though.
Old 09-30-2012, 08:27 AM   #6
emgee
what brand spark plugs did you use?
Old 09-30-2012, 08:32 AM   #7
dmax
dmax's Avatar
...and spark plugs 'have' been known to come loose, having not been tightened enough...nothing personal!
I know the NGKs say down to 'stop' and 1/16th turn...then another 1/2-2/3rds turn.
I can never tell with vids of sound and think on the spot isolation of the sound is best. Try using a garden hose or something like that.
dmax on Facebook
Mangofy your E46!
Old 09-30-2012, 08:34 AM   #8
emgee
+1 with Dmax
Old 09-30-2012, 09:30 AM   #9
Alexotronic
My Ride: 2001 330Ci
I replaced spark plugs with "OEM" NGK (they had 4 prongs).
Time to murder a hose..... or maybe invest in a stethoscope.....
Re-seating spark plugs is also a good idea. (Hoping for some PFM)
Old 09-30-2012, 09:59 AM   #10
dirtbiker245
My Ride: 00 323ci, 02 325i
Originally Posted by emgee View Post
+1 with Dmax
Sounds to me like a loose spark plug. That happened on my wife's car a few months ago, I heard the sound and was stumped at first but was relieved to see that's all it was.
dirtbiker245 is offline   Reply With Quote
Old 09-30-2012, 10:53 AM   #11
Amhague
My Ride: 330xi
I have the same noise.. Ive put a new disa in, new plugs and recently checked to make sure they were seated correctly. Noise wont go away. Things ive done to try and get rid of the noise/random rough idle.
Disa
CCV
Spark Plugs
Vanos (valve cover too)
Pulleys
Cooling system overhaul
Belts
Ignition coils
Cleaned TB/ICV
intake boots
Camshaft sensors (intake and exhaust)
If i just knew what the damn problem was i could fix it..
Amhague is offline   Reply With Quote
Old 09-30-2012, 11:54 AM   #12
BimmersGarage
My Ride: E46 330i
OP,
Partial VANOS and DISA.
It's distinctly VANOS that's making that random hard tick at :03, :09, :14.
DISA is making that droning sound.
Not sure what's making that galloping noise.
BimmersGarage is offline   Reply With Quote
