E46 Xi Forum
Old 09-30-2012, 01:50 PM   #1
White_Knuckles
My Ride: 2003 325xi
New Fuel Filter = better performance?
Okay, I may be crazy but...
My fuel pump left the party instantly when I went to leave a parking garage the other day. It would crank - start - die, crank - start - die. Then no start. I yanked the rear seat and had a helper turn the key where I could hear nothing with my ear on the pump location.
I got lazy and had it towed to my Indy who was closer then my house and thought whatever, let them deal with it. The diagnosis was a DOA pump but he suggested I should have the filter changed as well. Why not? I had neglected it now at 80K miles.
So $500 later I get her back. The strange thing is, I swear the car runs better now! The off idle and mid-range throttle response is clearly more responsive. I have driven it a week now and the same route I take every day is a great test with on ramps and long, steep hills. The car runs like I added a mini super charger.
Could the fuel filter actually make that much of a difference? I know it has a pressure regulator built in that may play into this. If this is plausible, I highly recommend you lazy guys (like me) jerk that old filter and possibly restore lost ponies. The stupid filter is around $100 so be prepared.
Old 09-30-2012, 02:31 PM   #2
zabalzae
My Ride: 01 330ci
Why jerk it? Why not just replace it? You want crap to go to the injectors? More expensive... the fuel filter makes a big difference when dirty because it doesnt allow enough fuel to the injectors. Imagine if one of ur heart Arteries clogged, then you wouldnt work..
Sent from my SAMSUNG-SGH-I747 using Bimmer App
zabalzae is offline   Reply With Quote
Old 09-30-2012, 02:45 PM   #3
White_Knuckles
My Ride: 2003 325xi
By "jerk", I meant replace it not bypass the filter/regulator. Sorry for the confusion.
Old 09-30-2012, 02:52 PM   #4
Foxtrot_Uniform
My Ride: 325Xi
Yup... I have one in the garage... I just need to install it.
Foxtrot_Uniform is offline   Reply With Quote
Old 10-01-2012, 11:49 AM   #5
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
I agree - I too have found a slight increase in pep/response after a filter change.
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 10-01-2012, 01:41 PM   #6
SamDoe1
My Ride: 4cyl of fury
I have one sitting on the shelf to install, just haven't had the time to put it in.
Old 10-02-2012, 03:31 PM   #7
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
The fuel filter will start to clod with age and miles, slightly reducing flow and pressure and the pressure regulator itself will start to weaken with age and miles. Best to replace as the maintenance schedule recommends for cleaner fuel, better performance and cleaner injectors.
tomoyer is offline   Reply With Quote
Old 10-02-2012, 03:38 PM   #8
VG1134
Old City Bimmer
My Ride: Classifieds
Yep- this is my next preventative maintanence on the list.
VG1134 is offline   Reply With Quote
Old 10-02-2012, 06:01 PM   #9
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Yea, filter does make a small difference but what you're feeling are the effects of a new fuel pump.
Old 10-02-2012, 06:04 PM   #10
TonyDiv
My Ride: 03 325Ci Convertible
Universal rule of thumb. If you notice a difference after changing a filter... you waited too long to change that filter.
TonyDiv is offline   Reply With Quote
Old 10-02-2012, 07:29 PM   #11
White_Knuckles
My Ride: 2003 325xi
Pump gas isn't exactly loaded with contaminants and debris. In the old days, metal tanks would scale and rust creating all kinds of nastys to get trapped in filters. I went crazy and chopped my filter in half to inspect the element. It was discolored, sort of gray but definitely not clogged with scary stuff. I'm leaning toward a weakened pressure regulator or as Soildjake mentions, a fresh pump pushing the juice harder.
May never know what performed the magic but nice to see others noticing an improvement as well.
Old 10-20-2012, 08:07 PM   #12
2002GreenBMW
My Ride: 2001 325xi
Damn son, 500 bucks? It took me 30 minutes to replace the fuel pump with a YouTube diy
2002GreenBMW is offline   Reply With Quote
Old 10-21-2012, 12:41 AM   #13
willkenni05
My Ride: '06 330xi
Exactly! Probably not the job to get lazy on! Cost of the pump + 30 min would have saved you quite a bit of cash...
willkenni05 is offline   Reply With Quote
Old 10-21-2012, 11:39 AM   #14
redbull 325is
My Ride: 325xit/6
Send a message via AIM to redbull 325is
Your fuel filter probably did help alot, but also if your fuel pump was getting weak it could have been delivering less than optimal fuel pressure.
redbull 325is is offline   Reply With Quote
