Old 09-07-2012, 03:22 AM   #1
ToMuchFun
Banned User
My Ride: E46 325i
No power steering!?!
Hoppe in the car tonight and ran up to the gas station went in side came out started the car no power steering, the pump seems to be running and I can't find any hoses disconnected, no fluid under the car when I left, I'm quite puzzled from this anyone have any ideas?
ToMuchFun is offline   Reply With Quote
Old 09-07-2012, 10:15 AM   #2
jhaurimn
My Ride: 01' 330ci
Check your power steering fluid level first. If that's fine check to make sure your belts are still on the pulleys correctly. If those two are okay your ps pump is shot.
PAST
2001 330ci - 117xxx (sold)
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
jhaurimn is offline   Reply With Quote
Old 09-08-2012, 07:46 PM   #3
ToMuchFun
Banned User
My Ride: E46 325i
Fluid is full, all hoses connected and all belts on pulleys, damnit
Old 09-08-2012, 08:24 PM   #4
jhaurimn
My Ride: 01' 330ci
What's the Year model and mileage btw ?
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 09-08-2012, 09:01 PM   #5
ToMuchFun
Banned User
My Ride: E46 325i
01 325i, just hit 130000, I just can't believe the thing went from working perfect to not working at all when I was inside the gas station
Old 09-08-2012, 09:06 PM   #6
ToMuchFun
Banned User
My Ride: E46 325i
When I'm looking at them to purchase there is Lf-30 and Lf-20 is says they are not interchangeable, how do I know which one is right for my car?
Old 09-08-2012, 09:12 PM   #7
Steven747
My Ride: 05 330ci
maybe you should check which 1 is in your car right now
Old 09-08-2012, 09:21 PM   #8
jhaurimn
My Ride: 01' 330ci
Take your air filter out, shine a flash light and check. No other way to know for sure. And that mileage sounds right for the ps pump to go out. The pumps are known to have the shaft snap off from the pump itself which might cause sudden failure like what happened with you. I like that happened on lf20 pumps.
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 09-08-2012, 09:50 PM   #9
Sansho
My Ride: 2001 325i
If you have an LF-20 pump today, you can install an LF-30 pump, which is supposed to stronger, and with a little more boost. However, if you want to install an LF-30 in place of an LF-20, you need a new $100 OEM ($190 BMW) power steering pressure hose, as the connection to the LF-30 is different than the LF-20.
Sansho is offline   Reply With Quote
Old 09-08-2012, 10:02 PM   #10
ToMuchFun
Banned User
My Ride: E46 325i
That's some help... But how do I telllll
Old 09-09-2012, 08:08 AM   #11
Sansho
My Ride: 2001 325i
As jhaurimn said, you really need to look to ensure which you have. Have you looked at realoem.com to see what the catalog says? Here are some pictures that may help:
LF-30 looks like this:
LF-20 looks like this:
Old 09-09-2012, 08:08 AM   #12
jhaurimn
My Ride: 01' 330ci
Edit: ^ he beat me to it
We posted in the same minute... Weird lol
PAST
PRESENT
2001 M3 - 90xxx
1989 325i - 2??,???
Old 09-09-2012, 10:28 AM   #13
ToMuchFun
Banned User
My Ride: E46 325i
Thanks guys big help I have the Lf-20
Old 10-12-2012, 03:42 PM   #14
sneakingword
My Ride: e46 325i 03
I had that same problem i drove without it for sooo long till i got a new pump now everytime a turn not moving it makes LOUD sounds any help????
sneakingword is offline   Reply With Quote
Old 10-12-2012, 06:51 PM   #15
ToMuchFun
Banned User
My Ride: E46 325i
Hmmm I have no clue man, I'm thinking my steering rack made the pump go bad, it likes to stick on left hand turns, anyone think that could have caused it?
Old 10-12-2012, 09:07 PM   #16
sneakingword
From what i was told my pressure hose made it go bad i just change my pump now i have to change that i honestly dont think the rack would make it go baddd this is a common problem with these carss
