E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 7 votes, 5.00 average. Display Modes
Old 09-30-2012, 02:35 PM   #1
grips03
My Ride: 2004 325XI
Peake codes 19 E3 E4
I got codes 19 E3 E4 for 2004 325xi from my Peake Research R5/FCX-3.
Table 19
E3 is O2 sensor adaptation limit Cyl # 1-3
E4 is O2 sensor adaptation limit Cyl # 4-6
and was going to replace O2 sensors, but saw threads concerning DISA. I used the two youtube videos below to find the DISA and confirm its bad.
This place is awesome!
grips03 is offline   Reply With Quote
Old 09-30-2012, 07:00 PM   #2
tomoyer
My Ride: 03 325xi, 01 325xi
Send a message via Yahoo to tomoyer
Were you only getting the E3 and E4 O2 Sensor adaptation codes? I'm also getting the following; CA and CB O2 Sensor control limit codes.
Prior to replacing the pre-cat O2 sensors, I was also getting a random misfire on all 6 cylinders. Replacing the pre-cat O2 sensors and clearing the codes, the new Bosch O2 sensors took care of the random misfire condition (the pre-cat O2 sensors will lean the mixture too much and can cause the random misfires. I was leaning towards the DISA being the last of my problem and watching those 2 videos seems to confirm my thoughts so I will be ordering a new one so that it is on hand when I remove and inspect the old one (my old DISA has been making some noise so I'm sure it isn't working correctly AND if I clear the 4 codes, I can drive several days until the same 4 codes light the service engine soon light.
tomoyer is offline   Reply With Quote
Old 09-30-2012, 07:04 PM   #3
grips03
My Ride: 2004 325XI
Take the DISA out as it takes 5 minutes and then compare to that guys new one. My flap did not spring back and the little connector thing didn't move either. That's all the code I got today. Going to replace and run the car to see if I get anymore codes. If I do I'll post here.
Old 09-30-2012, 07:12 PM   #4
tomoyer
May take it out tomorrow afternoon prior to ordering a new one, however, based on that 1 video and some other research I did, I'm pretty sure that my DISA is not functioning correctly and now is the last of my problem. If you do start throwing random misfire codes, if the plugs and coils are ok, then go for the pre-cat O2 sensors. I got mine via Amazon for less than $50.00 a piece for the Bosch units.
Old 10-01-2012, 10:15 AM   #5
PiZZaMaN2K
My Ride: 2004 BMW 325xi
Send a message via ICQ to PiZZaMaN2K Send a message via AIM to PiZZaMaN2K Send a message via MSN to PiZZaMaN2K Send a message via Yahoo to PiZZaMaN2K
Do you possibly think this could be related to my error codes?
6a exhaust camshaft VANOS over-retarded
E3 02 sensor adaptation limit cyl #1-3
E4 02 sensor adaptation limit cyl #4-6
EE misfire cyl #1
F2 misfire cyl #5
F0 misfire cyl #3
F3 misfire cyl #6
EF misfire cyl #2
F1 misfire cyl #4
Car runs very rough and smelling very very rich if that adds anything to your guess...
PiZZaMaN2K is offline   Reply With Quote
Old 10-03-2012, 10:50 PM   #6
grips03
My Ride: 2004 325XI
yes
Old 10-06-2012, 10:14 PM   #7
PiZZaMaN2K
okay, just got my disa in the mail today, will try and get it installed tomorrow and see what it does. wish me luck lol
Update:
Sorry it took so long, forgot to come back and update lol. I replaced my DISA and am glad to report that it cleared up all my issues. Running great now.
Old 10-07-2012, 06:35 AM   #8
tomoyer
Make sure you clear all the codes out once you install the new DISA. See if any show up again and read what they are and report all codes here (you should have stated them all with original post). You may well find that you will still have to replace both pre-cat O2 sensors, as faulty pre-cat O2 sensors can give you the adaptation limit codes and the random misfires of all cylinders due to a lean condition.
Old 10-07-2012, 08:45 AM   #9
Rickna
My Ride: '01 330xi - '09 IS-F
I wasn't throwing any codes but I found that my DISA was shot. The cheapest price for a replacement was aboout $190. I found this repair kit. http://germanautosolutions.com/DISA_...epair_Kit.html It's supposed to make it better than new and for $82 shipped I decided to give it a try. I'll post up on the results when it's done.
2001 BMW 330xi
2009 Lexus IS-F
Rickna is offline   Reply With Quote
Old 10-07-2012, 11:29 AM   #10
grips03
My Ride: 2004 325XI
Replaced the broken DISA, then fule pump went, so now replace fuel pump and filter. Now I just have to fix the oil loss and white cloud from exhaust. Car has 171K miles on it.
Old 02-17-2013, 06:32 PM   #11
Jmhockey1920
My Ride: 2002 325i
I am getting this code. I bought the DISA kit and rebuilt it. But the code still came back :[
Jmhockey1920 is offline   Reply With Quote
Old 02-17-2013, 11:29 PM   #12
Lobstrosity
My Ride: 2003 325xi Touring
Glad this thread got bumped up! I've had those codes coming up and tried the oxygen sensors, but never thought to check the disa. Just pulled it out and it's shot. Now to research to see if the rebuild kits really work or if I should just replace the whole unit.
Lobstrosity is offline   Reply With Quote
Old 02-18-2013, 09:17 AM   #13
bmwbob89
My Ride: M-5 325 X3 528 740
The kit is great! I've used it and the price went up on the complete valve.
bmwbob89 is offline   Reply With Quote
Old 02-18-2013, 12:45 PM   #14
Rickna
Rebuilding the DISA with the GAS kit is easy, just follow the online directions. When finished the rebuild is superior to a new DISA and it will defienetly outlast an new one. And you can't beat the price.
2001 BMW 330xi
2009 Lexus IS-F
Old 04-04-2014, 02:52 PM   #15
Oz Striker
My Ride: '00 330Ci, '07 350Z
I thought I would post here rather than start a new thread as I have a very similar problem.
I've been getting the check engine light and P0171 and P0174 codes, over the last 20-30k miles, with it gradually coming on more frequently. The light comes on sooner, the colder the weather, if temps are above 15 degrees C although codes come up, the "check engine" light will not. The car appears to runs fine, except for in winter when temps go below 5-7 degrees C, and when until its fully warmed up, the idle bounces up and down a little when I come off the gas to a stop.
My peake tool gives me:
Table 19
Here's a video of my DISA, yes its long vid, but essentially the pin is fine, the flap doesn't rotate freely, and moves the piston towards the vacuum pot. BUT the vacuum pot doesn't appear to hold position at 45 degrees
I'm just surprised that all other aspects of my DISA after 122k miles appear fine and that its the vacuum pot that's the cause of my codes and rough idle in cold weather. Any other checks I can do?
Additionally:
MAF has been cleaned
CCV system completely overhauled (this actually decreased the frequency of the codes and engine light coming especially in the warmer weather last summer. And I've been through whole install again to make sure everything was connected up right)
Minor valve cover gasket leak (oil consumption well under 1 litre per 1000 miles)
My YouTube Channel incl Muffler delete vids: http://www.youtube.com/user/OzStryke...view_as=public
My blog on E46 DIYs & Mods http://lifewithabmw.blogspot.com/
Oz Striker is offline   Reply With Quote
Old 04-04-2014, 04:01 PM   #16
SamDoe1
My Ride: 4cyl of fury
You probably need new O2 sensors at that mileage.
Old 01-07-2016, 08:24 AM   #17
Hrvat
My Ride: 02 Imola Red M3
Does this sound like DISA? I had CEL come on, then went off on it's own
PM ME FOR FREE SAMPLES
Originally Posted by roronoah View Post
so 2004 bmw's dont come with a diff?
Hrvat is offline   Reply With Quote
