Go Back   E46Fanatics > Everything Else > The Off-Topic > Photography
Photography
Old 05-05-2013, 01:00 AM   #1
kuksul08
My Ride: M3
Question about polarizing filters
I'm a little confused about how the polarizing filters work for dSLRs. What I have in mind is a two polarized layers with individual rings. So you can first adjust the angle of polarization depending on the light source and object reflections, and then rotate another polarized layer relative to the first in order to adjust how much light can enter.
Does something like this exist? I think I saw something in a magazine like that once, but none of the "circular polarizing filters" look like they have any adjustability.
My goal is essentially to be able to keep shutter speed for movies at 1/60 and ISO 100 on very sunny days without having a blown out image. Also to take pictures with both sky and landscape without having the sky be blown out, or objects have too many reflections in direct sunlight.
Look at that subtle jet-black coloring. The tasteful thickness of it. Oh my God, it even has a 6mt.
S54 Valve Adjustment Spreadsheet & Info: http://dl.dropbox.com/u/28231781/S54...ent%20info.zip
S54 VANOS DIY Video: http://www.youtube.com/watch?v=9SkT2j3jsU0
kuksul08 is offline   Reply With Quote
Old 05-05-2013, 01:03 AM   #2
Andy2108
My Ride: SpecE46 & E46 M3
Why not just use a 5 stop neutral density filter? Polarizers cause weird things, especially with two.
EDIT: Try these in combinations:
http://www.amazon.com/Tiffen-58mm-Ne..._bxgy_p_text_y
http://www.amazon.com/Tiffen-58mm-Ne...=3+stop+filter
http://www.amazon.com/Tiffen-58mm-Ne..._bxgy_p_text_z
De gustibus non est disputandum.
Old 05-05-2013, 01:11 AM   #3
Andy2108
Article about polarizers:
http://www.bobatkins.com/photography...olarizers.html
Old 05-05-2013, 01:27 AM   #4
kuksul08
My Ride: M3
Very cool. Good article, thanks.
So would it be a wise choice to use a circular polarizing filter for general use, and then stack ND filters of various stops on top to get exposure in bright sunlight just right (mostly for video)?
Any recommendations for polarizing filter? My lens is 72mm, and I was looking at this: http://www.amazon.com/HOYA-72mm-Circ...ed+filter+72mm
Old 05-05-2013, 02:05 AM   #5
Andy2108
Yeah, the CP helps reduce bad reflections in direct sunlight and stuff. I feel like they could cause more issues than they fix for video. Think about how humans are used to seeing the world... it's definitely not thought a CP.
You said you wanted to take pics of the sky... well keep in mind that with a CP the sky will look weird because the sun hits it at different angles or something like that.
EDITed cause the forums thought the pic I found was spam
Old 05-05-2013, 02:15 AM   #6
kuksul08
My Ride: M3
Hmm interesting. That sky does look weird.
My main issue with video is trying to shoot video in broad daylight. I have had to go down to like f/20 1/60 ISO100 just to get it to look right, but then it reveals any oil or dust on the image sensor at that small aperture. I guess I can use the ND for that, and then the polarizing filter for general images.
Old 05-05-2013, 02:26 AM   #7
Andy2108
Nah, get the CP first and see how you like it
Old 05-05-2013, 02:59 AM   #8
kuksul08
My Ride: M3
I'll get...
ALL THE FILTERS!
Old 05-07-2013, 12:53 AM   #9
kuksul08
My Ride: M3
Any input on
http://www.amazon.com/72mm-Circular-...arizing+filter
vs
http://www.amazon.com/Tiffen-72CP-72...arizing+filter
Big price difference, similar reviews. Does it make a big difference?
Old 05-07-2013, 07:32 AM   #10
Old Rum
My Ride: 11 335i vert 6m
Check out maxsaver.net. They are in Hong Kong but the shipping is usually fast.
Old Rum is offline   Reply With Quote
Old 05-07-2013, 04:21 PM   #11
TayloMade[07]
My Ride: '12 Frontier Pro-4x
B&H photo video is also good..
I have a Hoya Polar filter and haven't had any issues with it. also have a Tiffen Vari-ND, but haven't used it enough to give an opinion on it.
Old 05-07-2013, 10:07 PM   #12
kuksul08
My Ride: M3
I did a bunch of research on Ken Rockwell. Looks like it doesnt REALLY matter between the upper level multi coated filters, but Hoya and B+W are top notch. I'll probably go with the Hoya HD multi coated.
Old 05-08-2013, 09:07 AM   #13
GlockMan
GlockMan's Avatar
My Ride: Suburban LT 4x4
look at Promaster Digital HGX too.
I have Promaster Digital HGX UV filters, they are very expensive, but amazing IMO.
!!! ROLL TIDE ROLL !!!
National Champs: 1925, 1926, 1930, 1934, 1941, 1961, 1964, 1965, 1973, 1978, 1979, 1992, 2009, 2011, 2012, 2015, 2017?
Ranting about Panny plasmas, Canon cameras, Glocks, BlueNile, and HDMI on a BMW board since 2005.
2016 Honda Accord Sedan V6 Touring (wife)
2007 Chevy Suburban LT 4x4 with Nav/Bose/DVD
1968 Ford Mustang with Polk/ADS (my first car)
2007 Lexus GS350
2000 BMW DINAN M5
2001 BMW 330ci
GlockMan is online now   Reply With Quote
Old 05-12-2013, 04:04 AM   #14
kuksul08
My Ride: M3
I ended up getting the B+W MRC filter due to many positive reviews.
Got it and it had some kind of oily film on the surface. Cleaned it off with eclipse but the MRC coating made the eclipse bead up insanely. What a weird coating...
Shooting with it was interesting and adds another level of complexity. It has to be constantly adjusted depending on where the light is, so not too good for very dynamic environments. Also I'm just an amateur at this.
Lastly, I noticed some vignetting with a uv filter stacked on top, so if I stack an ND4 on top I will expect the same. I went with 72mm for my 72mm lens so I can still use the hood, but maybe 77mm would have been better, since you can't rotate the ring easily with the hood on anyway! Still learning
