Old 09-30-2012, 05:56 PM   #1
Nafearus
My Ride: 325ci
e46 LED Tail light problem
I need someone's help. I have a 2004 325ci. I ordered some LED tail light to replace the ones that I had and the connector from the car is too small for the one the new LED tail lights came with.
Any suggestions what I can do?
Nafearus is offline   Reply With Quote
Old 09-30-2012, 07:19 PM   #2
illestminimike
My Ride: Project Drama
Did you get OEM or aftermarket? Where did you order them from?
Old 09-30-2012, 08:06 PM   #3
Nafearus
My Ride: 325ci
I am not sure. I got them from ebay.
Old 09-30-2012, 08:40 PM   #4
wildirish317
My Ride: 2004 325Ci vert
Did you have the part number, and verify that the ebay seller was providing the correct part number? Part numbers for BMWs can be obtained at www.realoem.com. You enter the last 7 digit of your VIN and browse the cataloge to find your part and corresponding part number.
Ebay is not my first choice for auto parts, but I would certainly verify the correct part number with the seller.
Now that you are stuck with the part, if the wires match up in number and color, you might try splicing your old connector into your new light assembly. Good luck.
wildirish317 is offline   Reply With Quote
Old 09-30-2012, 08:48 PM   #5
E46-Cabrio
My Ride: E46 330CI Cabrio
Oke wich connector do you have, see pic.
ID:	471826   Click image for larger version
E46-Cabrio is offline   Reply With Quote
