E46 Xi Forum
The E46 XI was produced from 01-05 in sedan and touring body styles. Powered by either a 2.5L inline 6 in the 325xi or a 3.0L inline 6 330xi. Discuss all thing about BMW AWD E46 'Xi' here. |
#1 |
bought my first BMW
Hi guys my names Tyler Im 21 and just bought a 2002 bmw 330xi and decided to join this site. Alot of the car has been re done because it is highmiles 166k actually. It does have 2 small dents on the hood and some rock chips but over all a clean car with no rust anywhere. Coolent system ( water pump thermostat expansion tank) and clutch were done at 140k. At 160k axles and axle seals were done. lower control arms. Breaks were done and upgraded to slotted and drilled rotors. Shocks were done with billsteins. Wheel bearings as well. also has a full k&n cold air intake and strut bar brace on the front. The only thing I have to do is replace the oil filter housing gasket because it started leaking slightly. Well I think thats good for now. feel free to ask questions or comments. Thanks
[IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG][IMG] [/IMG] Last edited by Tstreets17; 09-30-2012 at 06:31 PM. |
#2 |
Nice looking ride!
#3 |
Thanks man she's pretty clean. Yeah I've hear they take a lot of maintenance I'm hoping most of the issues are takin care of though
#4 |
Looks good man
#5 |
Needs a lowering
#6 |
I agree. That will be happening after winter though. I got an m3 front bumper with fogs to put on after winter as well. Hood will get fixed a that time too
#7 |
Yupp most of the issues are taken care of but just check
Vanos seals Crank case ventilation (ccv) ATF fluid Valve cover gasket Rear trailing arm bushings and diff bushings But the main maintenance has been taken car of and good luck of owning it
![]() Need a bearing tool in Chicago-land ?http://forum.e46fanatics.com/showthread.php?t=964450 Find bmw wheel style here http://forum.e46fanatics.com/showthread.php?t=987999 |
#8 |
Yeah I believe it needs some bushings in the rear sometime soon too. Slight clicking noise over some bumps occasionally
#9 |
bro that car looks really nice! it does need some coilovers though
![]() whatd you pay for it?
![]() Long Nights and Sandy Beaches |
#10 |
6500 from a friend of mine
#11 |
Looks good, will look better without the Xi wheel gap. |
#12 |
How does it look with the yellow DRL's on?
#13 |
Not bad actually there still really bright just have a slight yellow glow to them. I usually just run with my halos and fogs on though
#14 |
Hmm. The reflector looks like it's yellow? Maybe it's a reflection? Just got my first too, 325xi touring. I'm thinking of running h7 yellow bulbs, could be good for fog and have a early 90's french look....enjoy!
#15 |
100% star stuff
Nice thumbs.
![]() Bilstein/Eibach B12 Pro-Plus Suspension System | DICE Mediabridge | Valentine One |
#16 |
Yes the reflector is painted yellow but still has the normal bulb in it so its only slightly yellow. Can still be used and are still really bright. Thanks man
