Go Back   E46Fanatics > New Member Introductions
New members check-in, introduce yourselves, and post a picture of your BMW here!
Old 09-30-2012, 08:05 PM   #1
kevinne4601
My Ride: 2001 325i, carrera 2
e46 rookie
Hi everyone. Just got a used 2001 bmw 325i, black 60k. First time owning a e46. already service light on. camshaft position sensor a,b and thermostat. mechanic said fixing the cps would not turn off the service light. He recommend fixing the waterpump and the thermostat. A little confuse on the whole thing. nothing is leaking. the temp. is in the middle of the gauge. Drives fine. He just reset the light. please advise. Thanks
kevinne4601 is offline   Reply With Quote
Old 09-30-2012, 08:07 PM   #2
j_block
My Ride: 2003 325i
Depends on what is triggering the engine light. Go check it. Also welcome to the forums
Sent from my SPH-D700 using Bimmer App
j_block is offline   Reply With Quote
Old 10-04-2012, 10:21 AM   #3
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Give us the exact error code numbers.
Change the thermostat with a Behr or Wahler unit that will cost around 45-50.
As for the camshaft sensor give us the code so we can tell you if it's intake or exhaust. For those sensors you MUST get OEM.
Old 10-04-2012, 01:52 PM   #4
kevinne4601
Thank you so much!
Display Modes
