Old 07-19-2013, 04:47 PM   #1
DOB2009
My Ride: 325i
Is this problem I am experienced the Vanos seal?
So let me just say the most noticeable symptom that just happened. When stopped to pull out today in my e46 (01 325i has about 83k miles) The RPM almost stalled out going to about 800rpm, then jumped up to about 1800, dipped back down, back up again, then leveled out around 800 and stayed.
The other really annoying problem I have is when going slow through my complex over speed bumps, when it's time to accelerate again the RPMs just inconsistently rev up/down until I give it a lot of gas.
It makes me look like an asshole to my neighbors every day like I keep tapping the gas pedal as I drive by to rev it up.
Is this the Vanos seal? If so what can I expect to pay to fix it trying to take the last expensive route as possible.
-Finally if anyone knows anyone in Southern Orange County, CA who can fix this for a fair price let me know. Thank you guys.
DOB2009 is offline   Reply With Quote
Old 07-19-2013, 04:50 PM   #2
VALMONT
The De46vil's Army
VALMONT's Avatar
My Ride: 325Ci, Passat
Send a message via AIM to VALMONT Send a message via MSN to VALMONT
when did/have you replaced the cam position sensors?
VALMONT is offline   Reply With Quote
Old 07-19-2013, 04:53 PM   #3
DOB2009
My Ride: 325i
I don't think I've had them replaced ever, but the car has had a lot of work done over the years extensive list. If it was done it was about 2 years ago. Is this the sensor you're speaking of: http://www.ebay.com/itm/BMW-E39-E46-...d39eec&vxp=mtr
Thanks for quick reply.
Old 07-19-2013, 05:24 PM   #4
VALMONT
The De46vil's Army
VALMONT's Avatar
there are 2.
one on the intake side and one on the exhaust side.
when my intake one went bad, I had issues like yours and they got progressively worse.
also check your plugs and coils, damn coils cause more problems than anything.
or... you could have a vacuum leak, usually the intake elbow?
Old 07-19-2013, 05:28 PM   #5
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
Vacuum leak possibly
Old 07-19-2013, 05:37 PM   #6
DOB2009
My Ride: 325i
there are 2.
Thanks actually I just did plugs/coils not long ago and it made a HUGE difference. I used to have a Gruppe M intake, then spent almost $1000 in smog related repair to pass I am back to OEM intake without the snorkel (does that make a difference)?
Also are these two sensors pretty straight forward to replace? I think I may order them, that would be awesome if thats all I had to do.
Old 07-19-2013, 07:13 PM   #7
peytonracer4
:D
My Ride: '00 328i
What difference did coils and plugs make?
Old 07-19-2013, 07:37 PM   #8
DOB2009
My Ride: 325i
For me the RPMs were just more consistent after, it felt more sluggish before with less power. Actually plugs I did twice in a row with little difference, it was the coils that really helped the next time I did them together.
Old 07-19-2013, 07:43 PM   #9
CharlzO
My Ride: 2000 328ci
Haven't done the exhaust side myself, but the intake was pretty simple. 15 mins or so if I remember right.
CharlzO is offline   Reply With Quote
