Old 06-25-2011, 10:41 PM   #1
summit56
My Ride: 328ci AA stage 1
Axle Shaft Broken
Had a left rear axle shaft snap during take off. Is there anyone that makes stronger rear shafts for a 328?
summit56 is offline   Reply With Quote
Old 06-25-2011, 10:50 PM   #2
TxZHP04
My Ride: ESS TS2+ ZHP
Where did it actually break? Drop clutch launch?
Not sure if anyone has an off the shelf offering for the non-M but would be interested to know too. My left half shaft has been clunking lately so I've got a stock replacement on order, hopefully I'm replacing mine before encountering such carnage.
Old 06-26-2011, 12:33 AM   #3
summit56
it was a burn out
Old 06-26-2011, 08:45 AM   #4
TxZHP04
Any pics of the damage?
If you haven't already, you might want to seriously consider reinforcing your rear subframe mounting points. FI + burnouts = snapped axles and torn mounts.
Old 06-26-2011, 08:59 PM   #5
summit56
i will get pics once the new shaft arrives and I remove the broken one. I plan to get the subframe reinforcments done during this winter/ coming spring. Already had BMW replace the rear pan due to it breaking, dont want to have to pay for it the second time around.
Old 06-26-2011, 10:22 PM   #6
summit56
thats my temporary fix to get the car back to the shop.
Old 06-26-2011, 10:36 PM   #7
eweis
My Ride: 1999 328i
You have *got* to let us know if that temp solution actually works and how far it got.
Sent from my EVO
eweis is offline   Reply With Quote
Old 06-26-2011, 10:44 PM   #8
s142s14a
My Ride: E46 M3
Is that tape holding the cvu together?
Sent from my EVO
s142s14a is offline   Reply With Quote
Old 06-26-2011, 11:09 PM   #9
summit56
that is duct tape and paper towels. the axle broke off and flopped around so I cleaned it up and wrapped paper around it so the tape would hold then wrapped with tape. this pry wont work with a open diff. but it worked to get me 60 miles to the shop.
Old 06-27-2011, 08:22 AM   #10
Jim Murphy
My Ride: 2006 E46 330Ci ZHP
Your garage says 165,000 miles on this car so you got good life out of the half shaft. Interesting to see if there is a stronger alternative - M3? Since one side broke the other side is not far behind, recommend replacing both of them.
Jim
Jim Murphy is offline   Reply With Quote
Old 06-27-2011, 08:28 AM   #11
alwaysbored786
My Ride: M3
you drove 60 miles on that thing, you crazy son of a bish!
*NO F-BOMBS IN SIGS*
How to refinish rims
2004 Noble M12 GTO 3R
1998 M3 Coupe
1996 BMW M3
2003 330I ZHP
1998 Honda Civic - Sister Totaled
2002 330CI - SOLD
2006 CBR 600RR - SOLD
1995 M3 Coupe - SOLD
1988 325E - SOLD
1996 Cherokee - SOLD
alwaysbored786 is offline   Reply With Quote
Old 06-27-2011, 01:22 PM   #12
mrshelley
My Ride: 2004 330i
For a 328:
One option is to buy:
2 used 330 trailing arms (2001-2005) - The 330 has a larger bearing (same as an M3), drive flange and axle splines.
2 Used output flanges for the diff (2003-2005) - You need these for the bigger axles but the flanges just pop out of the diff (easy to change)
2 Rear ABS sensors from an early 330 (2001) - Really early 330's had a ABS sensor that is a magnetic pickup and not a Hall pickup. A 328 has a magnetic pickup ABS system.
2 brand new axles from BMW from a 330 (2003-2005) - Might as go with new if you are looking for reliability. As for the Chinese axles, you are just rolling the dice.
This is what it takes to get the biggest and strongest axles of an OEM solution, for a non-M e46.
Old 06-28-2011, 05:38 PM   #13
summit56
sounds like it would be about the same to do the rear m3 subframe swap. Just not a whole lot of used bmw parts up here in Alaska.
Old 07-01-2011, 12:41 PM   #14
NIVO
My Ride: 2004 330Ci ZHP
Send a message via AIM to NIVO
Heat temper/cryo treat the shaft, now the tripod cv joint is the next weak link.
www.E46Turbo330Ci.com
WARNING: This modification is known to the State of California to cause cancer and birth defects or other reproductive harm due to the extreme G forces once turbo kicks in. ~ Nivo
The rest of my signature is reserved for pointless modification bits like: Halos | window Tint | carbon fiber roundels | short shifter
NIVO is offline   Reply With Quote
Old 07-01-2011, 12:53 PM   #15
summit56
Old 09-28-2012, 09:44 PM   #16
summit56
http://i710.photobucket.com/albums/w...5D6018E5B4.jpg
Broke another one.
Old 09-28-2012, 09:49 PM   #17
WALKD U
My Ride: Just Fast!
You can get the shaft build with 300m chromoly...
2005 AW/IR M3
MaximumPSI Stage4
993whp/651wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 10-01-2012, 11:26 AM   #18
summit56
And another.....where can I get some built from? I have not found anything for a non-m e46
