E46 Xi Forum
Old 10-01-2012, 12:14 PM   #1
SharkmanBMW
My Ride: 03 330xi, 4th bimmer
Send a message via MSN to SharkmanBMW
STRANGE Shock / shock mount problem - perplexed!
Hi all,
Bilstein M3 rear shocks seem to have a strange problem.
I have the Bilstein M3 shocks, on one side, there are more threads sticking out of the top nut than the other.
The mounts have been remoeved & reinstalled by different pros, always the same result. As if one shaft is longer than the other.
Bilstein tells me that is not likely at all.
So, what else could make one side tighten more on the shaft? It is always exactly the same - so I highly doubt they are not tightened equally every time - there has to be another cause.
On the Driver side I see about 7 threads above the nut and passenger side about 4 threads above the nut. Anyone have photos of their M3 shocks / top nut from inside the trunk?
Any ideas?!
THANKS
H&R Sport, Bilstein E46 Sport (Front), Bilstein E36 M3 Sport (Rear), Rogue Engineering RSMs
SharkmanBMW is offline   Reply With Quote
Old 11-04-2012, 10:47 AM   #2
SharkmanBMW
B b b bump!
Old 11-04-2012, 11:54 AM   #3
lovesm3s
My Ride: '03 330xi 5 speed
are there the same amount of threads on each shock?
lovesm3s is offline   Reply With Quote
Old 11-04-2012, 06:03 PM   #4
Gus330vrum
My Ride: 330ci
I have m3 1999 strut , did u upgrade shock mount to rogue RSM. ?
I'm having issue where my rear sway bar is touching the rear control arms cuz some how control arms bent and went car bounce up&down it touchs the control arm causing metal to metal noise.
Its not touching completely but the distance bettwen the sway and control arm is not long enough.
Sent from my LG-MS770 using Bimmer App
Gus330vrum is offline   Reply With Quote
Old 12-15-2012, 06:41 PM   #5
dambro24
My Ride: 330ci
what did you do for this?
dambro24 is offline   Reply With Quote
