E46 Convertible
Old 10-01-2012, 05:21 PM   #1
GirlBeemer
My Ride: 'vert 2002 BMW 330ci
Convertible top hangs halfway when opening
Hi!
I have a 2002 330ci and some of the time the convertible top hangs about halfway open and you have to push it to make it continue to open. It has no problem closing and doesn't hang all the time.
Any thoughts on what could be causing this? We've checked the wiring, lubed the hinges and checked hydraulic fluid and it's still getting hung halfway open. Open to suggestions.
GirlBeemer is offline   Reply With Quote
Old 10-01-2012, 08:07 PM   #2
johnrando
My Ride: '06 330 CIC ZHP
Wow, you checked everything I would have said to check. What about your battery? Are you doing this with the engine running sometimes and not running others? Have you looked at the bat wings just to make sure something isn't hanging and getting in the way at times? GL, and let us know what the problem was.
John '06 330 Cic ZHP
Southern California
ZHP, Cold Weather Pkg., Leather, Jet Black/Black/Black Cube, NAV
AA Tune, Sprint Booster, BMW Perf. Intake, Magnaflow Exhaust, Dinan STEP S/W & TB, TMS Pulleys, H&R Touring Cup Kit
BMW Perf. Strut Brace, Orion V2 Angel Eyes, No-holes License Plate, SMG Paddle Shift Mod, Besian VANOS, Gold DISA, Fan delete
Old 10-08-2012, 09:01 AM   #3
fmzip
My Ride: '08 328xi / '01 530i
Are you sure you closely checked the wires?
You could have a break inside the wire which is causing the intermittent issue. I would suggest re-splicing them all in the area of the hinging point as I did
http://forum.e46fanatics.com/showthread.php?t=790169
fmzip is offline   Reply With Quote
