Old 11-03-2012, 08:23 PM   #1
flickinswitches
My Ride: 2000 318i Executive
URGENT help water leak - coming from bottom of driver side door
hey all,
just appears to be problem after problem for me.
anyways, washed my 2000 318i sedan today, and noticed a water leak.
originally, it was pouring in from the top of the driver side door, because the outside plastic trim going along the top of the doors wasnt sealing right, so i sealed that now thats fine.
but now i have noticed water is coming in from the bottom, and as you can see the water line running down the carpet.
i am completely stumped how this can be getting in, when there is a door seal on the inside and outside, and they look like they are fine :S
can anyone help?
i have uploaded as many pics as i can to help.
help with exactly what i need to do, where to seal etc would be heaps helpful.
thanks guys want to fix this asap
the arrows show where i can see the water is running through then down the inside of the carpet.
flickinswitches is offline   Reply With Quote
Old 11-03-2012, 09:21 PM   #2
///MPR77
My Ride: 02 ///M3 Tri-Ped
There is a sunroof drain, and it can get stopped up.
I have only read about it, but I have no experience with it, so that's all I got.
Hope that helps your troubleshooting.
GL.
Old 11-03-2012, 09:23 PM   #3
stevenluczynski
My Ride: Is Steel Blue
It's your door vapor barrier, do a search on it, its common
stevenluczynski is offline   Reply With Quote
Old 11-03-2012, 09:51 PM   #4
flickinswitches
GL.
hey bud, i dont have a sunroof??
when that is the issue, do they leak from there though?
Old 11-03-2012, 09:52 PM   #5
stevenluczynski
yes
Old 11-03-2012, 10:14 PM   #6
flickinswitches
yes
So will leak usually from where you can see the water running down the carpet in the first pic?
Just don't want to rip the door trim off if it may not be it
Old 11-03-2012, 10:16 PM   #7
stevenluczynski
yup, thats exactly where mine dripped. Its an easy fix, just some rubber cement to adhere the vapor barrier
Old 11-03-2012, 10:48 PM   #8
flickinswitches
I'm hoping sikaflex works
It's sticky stuff !
Old 11-03-2012, 11:50 PM   #9
Sansho
My Ride: 2001 325i
3M windo-weld is what BMW recommends to seal between the vapor barrier and door.
Sansho is offline   Reply With Quote
Old 11-03-2012, 11:54 PM   #10
Nico16
My Ride: 2000 323i
You can check the whole shadow line trim, sometimes the clips are broken.
Nico16 is offline   Reply With Quote
Old 11-04-2012, 01:22 AM   #11
flickinswitches
What's the shadow line trim?
Old 11-04-2012, 01:24 AM   #12
flickinswitches
Did a bit of searching on the vapor barrier, it says if this is the issue it's common to sit under the dash....
For me appears to be going directly under the driver seat but not sure
Old 11-04-2012, 01:29 AM   #13
Nico16
My Ride: 2000 323i
http://www.ecstuning.com/Search/Shad..._Trim/ES77807/, check this one
Old 11-04-2012, 01:56 AM   #14
flickinswitches
Yeah that goes along the top of the doors, that was leaking originally pretty bad straight through the top of the door, but pretty confident I sealed it enough
Don't see how it could still be that if water is seeping from the bottom of the door
