Old 10-02-2012, 03:08 AM   #1
thedudebrah
My Ride: 2005 m3 6speed
What is wrong with my headlight?
05 m3, stock headlights. The DRL's are both fine, but the driver side light flickers a lot when the actual headlights are on. Recently, the driver side light will turn on and off, and then finally stay off and ill get the display on the dash telling me I have a headlight out. However, if I turn the car off and then turn it back on, the light comes on just fine. I mostly have a problem when moisture is present.
Bulb? Loose wire? Ballast? Help me out.
thedudebrah is offline   Reply With Quote
Old 10-02-2012, 03:10 AM   #2
thedudebrah
If this should be in the lighting section, feel free to move it.
Old 10-02-2012, 09:29 AM   #3
n3985
My Ride: E92 soon?
Probably a dying ballast or igniter, plenty of DIYs on the forum to guide you on how to change them out.
n3985 is offline   Reply With Quote
Old 10-02-2012, 04:27 PM   #4
BWOODM3
My Ride: 2002 M3 convertible
Bump the headlight with your hand, if it shuts off or flickers it could be the tab that holds the bulb in place. My passenger light does this when I am on a rough road. I took everything apart and the tab that holds the bulb in place is broken and it cuts out when it bounces around. Luckily, I don't drive my car at night, so it's something I have been putting off. If this is your problem, I think the whole bulb has to be replaced? and if you change one, you may as well change both so you don't color difference between the two bulbs. Or you can just figure a way to hold the bulb in place so it doesn't cut out when it bounces around.
BWOODM3 is offline   Reply With Quote
Old 10-02-2012, 05:10 PM   #5
thedudebrah
I just got to work, driving in the rain, and had my lights set on auto. I never got a dash indicator and in reflections on other cars, I could tell that both headlights were on and functioning. It's still fairly light here, but what part of the light senses darkness to turn the headlights on? Could that be what's causing my issue, since its only happening at night?
Old 10-02-2012, 05:12 PM   #6
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
When it dries up swap bulbs, see if the problem follows. If not check the wiring on the ignitor.
Old 10-02-2012, 05:14 PM   #7
thedudebrah
Ill give it a try. I was doing some googling and found these:
http://www.bimmian.com/XenoFlo-OEM-H...W-E46-3-Series
If its not my bulbs, I think I'm gonna go this route.
Old 07-12-2014, 07:03 PM   #8
alextrebek626
My Ride: 01 325i 5spd
Did you go this route? Or was it the bulbs? I have this problem with my drivers low beam.
alextrebek626 is offline   Reply With Quote
