///M3 Forum
Old 10-02-2012, 09:25 AM   #1
matthias2280
My Ride: 2005 m3 coupe
///m 19x9.5 et 33 245 35 19 ST Coilovers. Will it fit?
Hey...looking to run the above setup on the front using VMR VB3's. I'm sure this has been done before and I would love some pics or confirmation that this will indeed work. I will probably throw on a 5mm spacer to push the wheel out a bit if I have clearance issues on the back of the wheel. The progressive spring on the ST's is beehive shape so there may be some rubbing with the non-spaced et33. Also no camber plates, just the crash pin removed from the stock tophat.
Any insight dudes? Also FYI I will run 19x10 et 25 275 30 19 rears. No rubbing is expected there...
2005 ///M3 | Phoenix Yellow | Black Interior
Euro Tune.Headers.Cats | Borla | Dr. Vanos
6 MT | SSK | ZHP Shift Knob | Helios Angels
VMR VB3 | Hankook V12 | Hotchkis Sways | ST Coils
/// Deutschland \\\
matthias2280 is offline   Reply With Quote
Old 10-02-2012, 06:48 PM   #2
illestminimike
My Ride: Project Drama
You will be fine. If it hits the coil just measure how much of a spacer you need. I'm running a 245/35/19 up front and my offset is much lower than that with a 1.5 inch drop. No rubbing at all. And no fender work.
Old 10-03-2012, 09:27 AM   #3
matthias2280
Sick...thanks man.... I'll post some pics once I get the wheels on there. Should be tuesday or wed....
/// Deutschland \\\
Old 10-03-2012, 11:16 AM   #4
illestminimike
Sweet.
Old 10-16-2012, 01:55 PM   #5
matthias2280
It fit
Fronts needed at least 3mm spacer. I put a 5mm in there and its perfect. Tire is a little stretched on the rim but no worries. Car looks sick...
/// Deutschland \\\
Old 10-16-2012, 02:06 PM   #6
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
Pictures?
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
