///M3 Forum
Old 10-16-2012, 10:58 AM   #1
rainrcr32
My Ride: E46 M3
Salmon Relay
Hi Guys,
I wanted to ask if anyone who knows if this SMG RELAY is referred to as the "Salmon Relay"? also I keep hearing this from this site. SMG pump relay.
My car drives perfectly now and the only problem is the Light is on for the Transmission in the right corner of my gauge cluster. its the cirecle thing that kinda looks like a gear. its yellowish. I have no idea where the Salmon relay is, or the SMG Pump relay. Does anyone know which i need to change since my car still rive perfectly since my light is on?
Please help
Robert
rainrcr32 is offline   Reply With Quote
Old 10-16-2012, 11:09 AM   #2
Alan
Alan's Avatar
My Ride: 2006 M3
Its in the fuse box.
SMG relay = Salmon relay.
Alan is offline   Reply With Quote
Old 10-16-2012, 11:12 AM   #3
scca_ziptie
My Ride: 2006 M3 SMG Comp pkg
The 'salmon relay' is under the hood in the fuse box on the driver's side of the car close to the firewall. Make sure you have a torx driver as well ( T25 I think? ). The part # at one time was 12.63.1.742.690 (I'm not sure if BMW has superseded the #).. Salmon relay is the SMG relay.
"! First rule of Italian driving, that which is in your mirror is not important !"
scca_ziptie is offline   Reply With Quote
Old 10-16-2012, 12:25 PM   #4
illestminimike
My Ride: 2003 SMG Vert M3
Why don't you have someone read the codes to see why the light came on?
-2003 M3 Vert
-1967 Mini Cooper
Old 10-16-2012, 06:43 PM   #5
Mallee
My Ride: 2002 E46 M3
+1
Though interpreting the codes for this seems to be an art form.
But the relay is about $2250.00(?) cheaper than the pump, excluding the labour..
Mallee is offline   Reply With Quote
Old 10-16-2012, 07:17 PM   #6
scca_ziptie
Originally Posted by Mallee View Post
+1
Ummmm..... The salmon relay (SMG relay) is like $15-$20 ..... We must be talking about different relays.
Old 10-16-2012, 07:19 PM   #7
scca_ziptie
Just a thought OP - what is the ambient temperature when the light comes on? Does the light stay on constantly? I have heard that the cog/gear with exclamation point in the center can be illuminated if the transmission temperature passes a set parameter.
Old 10-16-2012, 07:20 PM   #8
Alan
Alan's Avatar
My Ride: 2006 M3
Originally Posted by scca_ziptie View Post
ummmm..... The salmon relay (smg relay) is like $15-$20 ..... We must be talking about different relays.
+1
Old 10-16-2012, 07:26 PM   #9
Mallee
or a failure to read..
"Salmon relay is, or the SMG Pump relay"
I missed the word "relay" after pump..
