Old 10-17-2012, 08:44 PM   #21
straight_beamin
My Ride: 2000 bmw 323i
Thanks for the help. I just need to find my win xp disc so i can install it
straight_beamin is offline   Reply With Quote
Old 10-18-2012, 10:55 AM   #22
Drewfus2101
My Ride: N/A
I did it with Win7, so I'm not sure why you think you need XP to do this.
All that I've needed XP for was NCS Expert.
Drewfus2101 is offline   Reply With Quote
Old 10-18-2012, 08:12 PM   #23
straight_beamin
Everything i try wont work so im getting xp and sending a member my stock tune with galletto software
Old 10-18-2012, 08:23 PM   #24
ZiMMie
My Ride: E36M3csl;E46 325i
ship ur ecu to me, I'm located in toronto and pay for shipping back. ill do it for you no charge.
Or drive down to get it done. only 2 hours away.
#E36S54 #CSLWannabe
ZiMMie is offline   Reply With Quote
Old 10-18-2012, 08:51 PM   #25
darksideracer69
My Ride: 01 325ci
Seems like a lot of hassle and time for you to try to get it done. I say set up xp and use the directions that dude posted. It'll work.
Sent from my SGH-T959 using Bimmer App
IMAG02051
Old 10-18-2012, 10:09 PM   #26
phubar
My Ride: 335is, HD
you can also download an integrated xp install disc, like "tinyxp". I just bought an old tablet off of craigslist for $50 and thats what I use for my car stuff.
also you can use windows 7 but you have to make sure you get a good working inpa install, windows 7 + inpa not very forgiving...
phubar is offline   Reply With Quote
Old 10-22-2012, 01:42 AM   #27
TerraPhantm
My Ride: M3 & ZHP
Installing it on Windows 7 is no harder than on XP. Just have to make sure you're running 32-bit.
If you can't do that, then just run XP in a VM. It'll work perfectly as long as your USB ports aren't USB 3.0
Old 12-11-2012, 02:24 AM   #28
veli510
My Ride: 2001 BMW 330i
were you able to get this done?
veli510 is offline   Reply With Quote
Old 12-11-2012, 10:49 PM   #29
straight_beamin
Havent had time
Old 12-12-2012, 02:05 PM   #30
karitammi
My Ride: 325 (E46) Cabrio
Hi. I bought Galletto, downloaded 64 kB and trie to upload it back into the ecu. Something went wrong and nothing works. Galletto software gives error -5. Anyone willing / able to help please? The car is Euro e46 325 cabrio, MY2001.
I was really stupid since I don't have the original file if it was corrupted during the first load. The target is to get car running again, collect some new courage and try to tune for e85 ethanol gas fuel.
karitammi is offline   Reply With Quote
Old 12-12-2012, 10:26 PM   #31
straight_beamin
Oh god wish i could help, look up try and pm terraphantom. He posted in this thread i believe and seems to know his stuff
Old 12-13-2012, 01:42 AM   #32
karitammi
Thanks! I tried to PM, his mailbox is full. Do you have suggestions? Would KWP be better than Galletto? How to retrieve the original file?
Old 12-13-2012, 11:58 AM   #33
phubar
My Ride: 335is, HD
something similar happened to me, u need to use INPA, when u get in the dme if u get VIN mismatched code u might be able to just do an ews resync more than likely tho u will need to use winkfp to flash the ecu with stock bmw software.
Old 12-15-2012, 05:29 PM   #34
straight_beamin
I gave up. I will be taking my car to a forum members house
Old 12-15-2012, 05:39 PM   #35
darksideracer69
My Ride: 01 325ci
:thumbdown:
Sent from my PC36100 using Bimmer App
IMAG02051
Old 01-07-2013, 03:32 PM   #36
karitammi
Thanks for you help phubar. I've tested the hardware now. I believe VIN should be updated first?
If a upload stock BMW software, does the VIN in the bin need to be matched? Or is EWS sync, with INPA I believe, sufficient?
Old 01-07-2013, 03:37 PM   #37
rjskalet
My Ride: TiAg M3
Where are you located? I'm on my phone phone and the app is being slow
rjskalet is offline   Reply With Quote
Old 01-07-2013, 03:41 PM   #38
karitammi
^ Espoo, Finland, Europe. Used to be N.C. for a while :-)
Old 01-07-2013, 10:50 PM   #39
phubar
My Ride: 335is, HD
you can follow these steps
1 Start WinKFP and select F3:- Update ZUSB
2 Select ECU type and the ECU will appear along with a list of part numbers.
3 Select ok and the main menu will re-appear
4 Select VIN and enter the cars VIN no. and select OK.
5 Select Done
6 Select Prog. ZB_update, you will be asked to confirm the update, Winkfp wil state the number of times the module can be re-programmed.
7 Sit back and wait.
That should bring ur dme back to life, then you can look into flashing the EU2 software.
Old 01-08-2013, 12:23 AM   #40
nuk1ear
My Ride: E46 M3
can that galleto software read and write to E46 M3 ecus?
nuk1ear is offline   Reply With Quote
