Sponsored by The Tire Rack
Old 10-03-2012, 12:22 AM   #1
zooswanko
My Ride: 328i
Send a message via AIM to zooswanko
Will these 19" wheels fit my sedan okay?
I'm looking into purchasing a set of wheels with tires on them. Will they fit onto my 2000 328i sedan without rubbing? If not, what would I have to do to make them work? My car is at stock level. here's the ad for the wheels: http://newyork.craigslist.org/lgi/pts/3307441406.html
Thanks a lot
Sent from my Transformer TF101 using Bimmer App
zooswanko is offline   Reply With Quote
Old 10-03-2012, 12:24 AM   #2
rcsummers
My Ride: M3
im not good with non-m's but it should work just fine.
"RICH"
My Build Thread
EURO.TECHNIKS
- Status Gruppe Tuning - Broadway Static - Recaro - DTM Fiberwerkz - AutoCouture Motoring -
Instagram: @summers_e46_m3
Twitter: @rcsummers0506
Xbox One: MisterMeisterM3
rcsummers is offline   Reply With Quote
Old 10-03-2012, 12:29 AM   #3
Bimmer4Lyfe
Location: 129 West 81st St. 5A, New York, New York 10024
My Ride: 02 325i
Jeez thats gonna require a fender roll. And maybe a different tire size on rear,
But it can work for sure, with a little dial in....
Fronts are fine
Bimmer4Lyfe is offline   Reply With Quote
Old 10-03-2012, 12:47 AM   #4
zooswanko
My Ride: 328i
If i get the fenders rolled do you think the tires would be okay?
Old 10-03-2012, 12:59 AM   #5
Bimmer4Lyfe
My Ride: 02 325i
At stock height you might get away with it, but those wheels & tires at stock height is probably not a great look.
I think you will rub for sure with those tires and that offset.
A more narrow tire and maybe camber work will be needed.
If lowered
Old 10-03-2012, 12:58 PM   #6
zooswanko
My Ride: 328i
I know with a stock body, 19" wouldn't look great but I am getting mtech bumpers and side skirts which should make it look for proportionate. Anybody have experience puting bigger wheels on a sedan?
Sent from my GT-N7000 using Bimmer App
Old 10-03-2012, 01:40 PM   #7
Bimmer4Lyfe
My Ride: 02 325i
i had the exact same setup
except my rear offset was 45mm with the same tire size and was lowered on HR sport suspension
i put 5mm spacers (effective offset 40mm) after i rolled the fenders, it still rubbed from time to time,
so, can you imagine 33mm offset?
like i said, you may get away with it on stock height, but big rims and narrow tires with a large wheel gap to fender will not look good, especially with the tire/rim out past the fender, so a narrower tire (stretched) and camber work will be necessary if you want to lower it.
Old 10-03-2012, 11:35 PM   #8
bluesona1234
My Ride: 2002 bmw 330i
I tried to put 19 in. on mine, but it wasted more gas and rubbed. Not worth compromising the ride quality. They look nice but not a fit for 3 Series.
bluesona1234 is offline   Reply With Quote
Old 10-04-2012, 05:03 PM   #9
zooswanko
My Ride: 328i
Thanks for the input everybody
