Old 10-03-2012, 03:31 PM   #1
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
APEX | Stud Conversion Kits and Extended Lug Bolts/Free shipping to the U.S. 48!
APEX Wheel Hardware
Apex Stud Conversion kits
Try and find a BMW race car that hasn't converted to studs yet. They're stronger, safer, and improve pit stop times significantly. For non race cars, stud conversions make wheel install and removal much easier as you do not have to line up the holes in your wheels, spacers, and hubs before hand threading in a single lug bolt. Simply slide the wheel onto the studs, and let go. Your wheel will no longer spin around the hub, but will instead be lined up correctly.
APEX 75mm and 90mm Stud Kits with silver or black lug nuts
Extended length studs like these allow for a range of spacers to be used without any additional modification. You can easily use 3, 5, 10, 12mm with a 75mm kit or larger 15, 18, 20mm with the 90mm kit, or no spacer at all. When using lug bolts with spacers you are forced to purchase a different length lug for each width spacer. By remaining installed, the studs put less ware on the threads of your hubs. They guarantee there is enough thread engagement, as you can see how many threads were engaged during install. Wheel studs replace your OEM lug bolts by simply threading into your cars hub. Once installed they do not need to be removed when changing or removing wheels. Only the lug bolts are removed similar to many domestic vehicles.
  • APEX Wheel studs are 10.9 grade steel, and produced in Europe by a TUV approved OEM supplier
  • 75mm length allows for the use of spacers up to 12mm in thickness, or no spacer at all, without making any changes
  • 90mm length is recommended for spacers 15mm and larger
  • The studs have a bulletnose tip that makes lug nut install and removal easy, and prevents cross threading
  • The 75mm head has an integrated 5.5mm hex to make initial installation a breeze
  • The hardened studs are black zinc plated, while the nuts are available in both black and silver zinc plating
  • Studs and nuts are 12x1.5 thread with a 60 degree taper identical to OEM BMW hardware
  • These work on all 1, 3, Z series models, and every other BMW with a M12x1.5 lug. X5/X6, and newer 7 series use different sized hardware and cannot used this conversion
Available Sizes and Pricing:
Available Lug Nut Finishes
  • Black - +$10.00
  • Silver
Installation Kit Now Available! (Includes Red Threadlocker and 5.5mm Wrench)
Apex Extended Lug Bolts
Available in standard OEM length, and extended length version for use with 5, 12, 15, and 20mm spacers. APEX lug bolts can be purchased with either a silver or black zinc coating.
BMW extended lug bolts sold individually
Extended lugs are a must when using spacers, as the standard length lugs are not long enough to thread into the hub properly. If you want new lugs to go with your new wheels and spacers are not needed, then simply select "standard" length from the drop down menu above. If you are using spacers, then select the corresponding length extended lug bolts.
Lug Bolt Specifications:
  • M12x1.5
  • 17mm Hex head
  • 60 degree taper
  • 10.9 Grade
  • Black or Silver zinc finish
  • Made in Europe
Available Lug Bolt Finishes
Silver
Black - +$0.50
Ordering and Contact
  • Phone: Call (888) 499-9135 EXT. #1 for phone orders.
  • Payment: Credit and Debit Cards: Visa, Mastercard, AMEX, Discover, PayPal. Bank Wire Transfers are also available. Contact us to use a wire transfer for payment on your order.
  • Tax: California customers will be charged 8.75% CA sales tax.
  • Shipping: Free shipping only to domestic orders within the lower 48 states. Stud Kits will get free shipping. A full order of Extended Lug bolts with a quantity of 20x will also get free shipping.
  • APEX Hours:
    Monday thru Friday: 9AM to 6PM PST
    Saturday and Sunday: Closed
  • Warehouse and local pickup: The APEX warehouse is at 7888 Marathon Drive, Unit A, Livermore, CA, 94550 (Map It), (888) 499-9135 EXT. #2. This is where you pick up local orders.
  • Service and Installation: Apex Performance Services - Dublin: 6443 Golden Gate Drive, Dublin, CA 94568 (Map It), (888) 499-9135 EXT. #3
Joe@ApexRaceParts is offline   Reply With Quote
Old 10-05-2012, 02:17 PM   #2
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
Apex stud kits are in stock in 75mm and 90mm lengths. The stud kits make life much easier when installing wheels and tires!
Old 10-12-2012, 04:51 PM   #3
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
Life becomes much easier once a stud kit is installed on your car. No more worrying about lining up your lug bolt with the hub holes while fumbling holding a heavy wheel and tire!
Please call, email, or pm us with any questions you may have.
Old 10-24-2012, 06:02 PM   #4
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
Apex Stud Kits are in stock and ready to ship!
Old 10-31-2012, 04:53 PM   #5
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
Our stud kits are available with a stud install kit. The install kit includes an allen wrench and red loctite to make installation that much quicker and easier for you.
Old 11-12-2012, 07:09 PM   #6
Joe@ApexRaceParts
Past Site Sponsor
My Ride: E36 M3
Apex stud kits are in stock in 75 and 90mm lengths with either silver or black lug nuts! This car is using our 75mm kit with black lug nuts.
Please call, pm, or email us with any questions you may have.
Old 07-10-2013, 10:26 PM   #7
dominicgrillo6
My Ride: E46 Sedan
Pm'ing you now.
Instagram
dominicgrillo6
Whoooty
For Sale
245/35/19 Tires - 255/35/18 Tires - Yamaha V Star 650
dominicgrillo6 is offline   Reply With Quote
Old 07-11-2013, 12:00 AM   #8
e46techtuner
My Ride: 2000 328i
I have these on my car. Easy to install and its a must for swapping wheels often.
e46techtuner is offline   Reply With Quote
Old 07-11-2013, 07:10 PM   #9
APEXraceparts
My Ride: E92 M3
Originally Posted by lowcaligrown View Post
Pm'ing you now.
PM replied!
Thank you very much for the positive feedback! Please let us know if you have questions about any of our other products as well.
Product Specialist | 925.245.0773 | info@apexraceparts.com | Facebook | Blog |
APEXraceparts is offline   Reply With Quote
Old 10-25-2013, 04:54 PM   #10
David@ApexRaceParts
David@ApexRaceParts's Avatar
My Ride: E46 M3
Tired of wasting time aligning the wheel to the hub? We have 75mm and 90mm stud conversion kits to eliminate that problem!
Feel free to contact us by phone, email, or PM and we'd love to help you out!
David@ApexRaceParts is offline   Reply With Quote
Old 04-22-2014, 07:38 PM   #11
APEXraceparts
My Ride: E92 M3
APEX is now offering RAD Extended Wheel Locks!
  • Available in multiple lengths, RAD wheel locks are a must if you're using spacers. OEM length wheel locks do not have the required length to thread into the hub with a spacer installed. These can cover 3, 5, 12, 15, 18, and 20mm spacers.
  • RAD Extended Wheel Locks allow for proper thread engagement. Using hardware that is too short can cause failure of lug bolts.
  • RAD Extended Wheel Locks are all made in Germany and Dacromet coated for protection against the natural elements.
  • 100% Quality inspection before delivery.
  • Extensive selection of unique wheel keys in multiple sizes, which makes it much more difficult to defeat compared to "one-size-fits-all" solutions from other manufactures.
  • Sold in sets of 4, RAD Extended Wheel Locks can provide protection for all of the wheels on your car.
  • NOTE: These are available in M12x1.5 thread pitch only and will not fit 2012+ BMW F30 3-Series, 2011+ BMW F10 5-Series & M5, 2012+ BMW F13 6-Series & M6, or 2009+ BMW F01 7-Series as these vehicles have use M14x1.25 thread pitch.
Please contact us if you have any questions!
Old 05-12-2014, 07:31 PM   #12
David@ApexRaceParts
My Ride: E46 M3
Swap wheels a lot? Make it easier by doing a stud conversion.
75mm stud conversion kit with black lug nuts
We've got plenty of kits in stock for the 75mm stud lengths, so feel free to give us a call if you need to order a set.
Old 05-16-2014, 06:14 PM   #13
David@ApexRaceParts
My Ride: E46 M3
90mm studs are back in stock, feel free to order them through our site here.
Old 06-25-2014, 06:15 PM   #14
APEXraceparts
My Ride: E92 M3
Switch up the look of your wheel setup by changing the color of your lug nuts (for those with a stud conversion kit) or lug bolts. We sell these items individually for your convenience!
Please let us know if you have any questions and we'd be glad to help you out!
Old 07-11-2014, 05:41 PM   #15
APEXraceparts
My Ride: E92 M3
Get your extended stud kit today! Available with silver or black lug nuts.
Old 07-15-2014, 04:52 PM   #16
oAllElseFailo
My Ride: LS3 C6
Do you have them for 90mm for the E46? I believe it's a 12mm bolt but i saw you had them for the 14mm but highest was 75 for the e46
oAllElseFailo is offline   Reply With Quote
Old 08-12-2014, 08:13 PM   #17
David@ApexRaceParts
My Ride: E46 M3
Stud conversion kits available with Black or Silver lug nuts.
Feel free to contact us if you have any questions or would like to order.
Old 08-29-2014, 06:00 PM   #18
APEXraceparts
My Ride: E92 M3
APEX black extended 75mm studs paired with 18x10 +25 ARC-8's. Contact us with any questions, we would be happy to walk you through the APEX hardware available for your BMW!
Old 09-08-2014, 05:21 PM   #19
APEXraceparts
My Ride: E92 M3
Our BMW lug bolts come in standard lengths for cars without spacers as well as extended lengths for cars running up to a 20mm spacer. They're available in all sizes in black or silver:
Give us a call to order your set of lug bolts today!
Old 09-09-2014, 05:16 PM   #20
APEXraceparts
My Ride: E92 M3
This e46 M3 is running an aggressive 18x10 et25 square setup with 265/35/18 RS3's. Suspension is AST4100's with camber dialed in at -3 front and -2 rear. To get everything bolted down just right, he's installed a APEX 75mm stud kit!
Give u a call today if you have any questions. Stud kits are in stock and ready to go!
