Old 10-01-2012, 03:06 PM   #1
RSteckhahn
My Ride: '02 M3
Help with codes - cylinder 1 misfire
I am throwing the following codes:
Table 20
2dc6 - fuel tank level plausibility
2742 - misfire cylinder 1
27CF - ignition cylinder 1
After doing my VANOS in the spring, I had the first two codes followed by some camshaft timing sensor codes. This turned out to be a sensor connection when I reassembled everything.
Now, the ignition cylinder 1, I have no idea where that is coming from. The car has been driving GREAT until this morning, I downshifted to second gear doing about 25 miles an hour to take a turn and when I went to accelerate out of the turn If felt like I was missing something and the car was shaking. At idle, I can feel my seat shake and the exhaust pipes visibly shake. There was also extra exhaust fumes this morning after it happened.
I am hoping this can be a simple fix, I have my first BMWCCA driver school on 10/14 so I need to get right on this.
Any advice??
RSteckhahn is offline   Reply With Quote
Old 10-01-2012, 03:16 PM   #2
scarede46er
My Ride: 2001 BMW 325i ZSP
maybe your fuel pump? The level sender is built onto it. You should change it if you haven't
Old 10-01-2012, 06:43 PM   #3
RSteckhahn
My Ride: '02 M3
I'll look into that. Any other ideas?
Old 10-01-2012, 07:12 PM   #4
Olddog521
My Ride: 2001 e46 325xi
Addressing the misfire issue...pull the spark plug and make sure it's not corroded...next swap #1 and #2 coil overs to rule out the coil...if the problem changes from 1 to 2 then the coil is the issue
Olddog521 is offline   Reply With Quote
Old 10-01-2012, 10:12 PM   #5
RSteckhahn
My Ride: '02 M3
That sounds like a good plan to try. Plugs are brand new bug checking the cool packs should be simple enough.
Old 10-01-2012, 10:30 PM   #6
scarede46er
A bad fuel pump can also cause misfires
Old 10-02-2012, 05:49 AM   #7
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
If plugs are brand new, it's also possible that #1 isn't tight enough...nothing personal...it's happened before.
Did you tighten down to 1/2-2/3rds turn after your initial 1/16th turn (as per the NGK box instructions)? Also, the coil boot itself can go bad...so you could just test for that by leaving coils where they are and just swapping coil boot ($10 vs. $80). And check the grounds under the engine cover for tightness too.
Of course, common things like air leaks plague us a lot and translate into misfires and lean codes.
Don't know your mileage, but a clogged fuel filter can stop the car at around 130K miles (from what I've read here)...but if fuel filter or pump, I'd think you'd show more than one cylinder misfiring.
Have you ever used Techron...never a bad idea.
The 'fuel tank plausibility' isn't a code I recall seeing, but you know we have a lot of issues with fuel pumps and the sending unit behind driver. If it's an issue with the latter, you could have fuel showing, but it's in the wrong lobe of tank. Fill up the tank and see if that eliminates the issue. You can also measure fuel pressure...s/b around 50 psi.
Check for air leaks--read jfoj's sig link on that--he runs the 'air leak department'!
Upcoming comedy shows: May 20, Greenwich Village Comedy Club. 6 p.m. See Facebook for other shows and PM me if you can make one...love to see you there!
Facebook.com/DMAXstandup
Mangofy your E46!
Old 10-02-2012, 06:11 AM   #8
RSteckhahn
My Ride: '02 M3
Car has 86k. Plugs, VCG, and vanos were done in the spring. fuel filter was done around 60k.
I need to find time to get to work on the car. I am nervous about the possibilities that bringing the car to a shop could bring ($$$).
Old 10-02-2012, 06:17 AM   #9
dmax
dmax's Avatar
Try a smoke test. Initially you can try the 'spray carb cleaner' method...or use a cigar.
I'm 'feeling' air leak, but that's mostly just playing the odds.
Mangofy your E46!
Old 10-09-2012, 03:55 PM   #10
RSteckhahn
My Ride: '02 M3
Ignition coil it was!
Old 10-12-2012, 04:57 PM   #11
Olddog521
Nice
