E46 Xi Forum
Old 05-02-2012, 08:52 PM   #1
Phoutsady4
My Ride: 2005 325xi
2005 325xi Car Starts Then Dies
Alright I just got done doing a coolant overhaul (thermostat, water pump, hoses, et, and sensors) and go to start my car and it dies within 2 seconds. I try this like 5x, same thing. It will rev if I give it gas but dies soon as I take my foot of the pedal. No ses light, no vacuum leaks, all sensors on tight, no tears in the intake. It does the same with or without maf pluged up. New battery and starter. I am stumped lol. Any help would be greatly appreciated.
Phoutsady4 is offline   Reply With Quote
Old 05-02-2012, 10:36 PM   #2
SamDoe1
My Ride: 2004 330xi, 3 pedals
Did you put the belts on right? Does it sound normal for the time it is running?
Old 05-02-2012, 11:14 PM   #3
euromade
My Ride: 325xiT
I had the same problem yesterday with my 03 325xi....had a bad ignition coil...also replaced the fuel filter. Runs good now....
euromade is offline   Reply With Quote
Old 05-03-2012, 04:48 AM   #4
Phoutsady4
My Ride: 2005 325xi
Everything is on right and the car doesn't have any codes so I doubt it the ignition coil
Old 05-03-2012, 05:44 AM   #5
jojo12
My Ride: 330xi
Pretty tricky, seems like the more you put into proper maintenance the more problems you'll have haha.
Soft fail of the fuel pump is a possibility. I'd try to find a local forum member w software to view live engine data. The absence of a check engine light doesn't necessarily mean your car isn't providing codes (aka clues!)
jojo12 is offline   Reply With Quote
Old 05-03-2012, 08:15 AM   #6
SamDoe1
If the engine is stalling, there should be a code of some kind (misfire, lean condition, etc). Check spark plugs for fowling and then the fuel pump for proper operation. Also, check the connector to the fuel pump. Mine worked its way loose one time and the car refused to start. Tightened up the connector and it was good to go.
Old 05-03-2012, 08:20 AM   #7
Phoutsady4
My Ride: 2005 325xi
I have an obd scanner and there is no codes stay running if I give it gas but dies if I take my foot off don't think it's the fuel pump
Old 05-03-2012, 08:22 AM   #8
jojo12
My Ride: 330xi
+1 on something as simple as a poor fuel pump connection. Take some electrical connection cleaner and give the terminals a well deserved cleaning.
Old 05-03-2012, 08:30 AM   #9
fastjasonbmw
My Ride: 330Xi
You'll get no codes when the idle valve starts to fail.
fastjasonbmw is offline   Reply With Quote
Old 05-03-2012, 09:29 AM   #10
jojo12
My Ride: 330xi
I don't really trust ODB readers, they can take forever to throw codes. I'd still try to find someone w PA Soft, INPA, etc who can see engine data in real time.
Old 05-03-2012, 09:29 AM   #11
Phoutsady4
My Ride: 2005 325xi
But if the icv starts to fail it should give some symptoms? The car had no problems prior to this and still doesn't through any codes. I am so lost. I guess it's time for new car.
Old 05-03-2012, 10:06 AM   #12
SamDoe1
Check the electrical connections on it. Can't hurt to pull it out and look at it. If it has failed, it'll be pretty obvious that it has.
Old 05-03-2012, 10:41 AM   #13
boongsin12
My Ride: none
My 2003 325xi does the very same thing except that it does that only once. It stalls at first when the car is started with cold engine. But if I start it after that first stall, it becomes fine. I am wondering if this is a similar problem? Or do you think it could be leaky sealing? like vanos?
boongsin12 is online now   Reply With Quote
Old 05-03-2012, 02:25 PM   #14
SamDoe1
^ That sounds like more of a fuel related issue. Pump is not delivering enough pressure right away.
Old 10-08-2012, 10:18 AM   #15
Alekm
My Ride: 323 E46 1999 AT 150k
Any resolution to this problem? I having the same issue.
Alekm is offline   Reply With Quote
Old 10-08-2012, 10:16 PM   #16
White_Knuckles
My Ride: 2003 325xi
Quick field test...
Lift the rear seat up and shove it partially out the passenger door. Pull back the rubber 8", fuel pump cover behind the drivers seat. Place your ear over the pump area. Listen to the pump as a helper rolls the key to position 2. Does the pump make any sound? Clicks or whirring?
Mine went DOA with no warning. Start-die-start-die. After 8 attempts finally - no start. No codes registered. Yours may sound labored or uneven as partially spinning. Mine made no sound whatsoever. Your results may vary.
Old 10-10-2012, 05:50 PM   #17
Mhnd
My Ride: 330XI
Same symptoms as my car (2004 330xi) last year, replaced fuel pump.
Mhnd is offline   Reply With Quote
