Old 10-03-2012, 07:09 PM   #1
Mflara20
My Ride: 2002 330xi
Help with vanos rattle
Hey guys I'm going to change my vanos seals because of a rattle, my question it's..... by just replacing the seals would it resolve the famous rattle I hear or do I have to change something else?
Mflara20 is offline   Reply With Quote
Old 10-03-2012, 07:50 PM   #2
vilseck21
My Ride: B_Cryus's mother
http://www.drvanos.com/
vilseck21 is offline   Reply With Quote
Old 10-03-2012, 08:44 PM   #3
can0n4
My Ride: '04 330xi, '04 X3
Originally Posted by vilseck21 View Post
really the only fix is a $400 replacement system?
can0n4 is offline   Reply With Quote
Old 10-03-2012, 09:41 PM   #4
Mflara20
My Ride: 2002 330xi
I heard you only have to replace the seals with the beisan ones
Old 10-03-2012, 09:48 PM   #5
littlegti
My Ride: 2002 330ci conv
Send a message via Skype™ to littlegti
My 330 was rattling bad so I replaced the seals with the improved ones from Beisan Systems. I was planning on replacing the bearings as well but I couldn't get the old ones out without an impact wrench.
Just replacing the seals eliminated 99% of the rattles. I can't say 100% because every now and then I hear a little rattle.
Only $120 for the seals and bearings seems like a deal.
littlegti is offline   Reply With Quote
Old 10-03-2012, 09:49 PM   #6
RKiepper
My Ride: 1999 E46 328I x2
This is not the only fix :sigh:
Replacing jut the seals will not fix the rattle issue. Iirc is has something to do with bearings, or spacers.. Something to that effect.
Search the forum to find your answer.
Beisan systems sells the seals and the rattle kit so you can install them.
Seals = $65, rattle kit = $100, = DIY
Dr vanos sells the entire vanos unit with the Beisan seals already installed, rattle kit is also an option.
Dr. Vanos = $400, = Lazy.
RKiepper is offline   Reply With Quote
Old 10-04-2012, 07:06 AM   #7
Mflara20
My Ride: 2002 330xi
Where can I buy the rattle kit from?
Old 10-04-2012, 08:15 AM   #8
zwei e46
My Ride: '99 323i & '05 325xi
http://www.beisansystems.com/
zwei e46 is offline   Reply With Quote
Old 10-04-2012, 10:30 AM   #9
Mflara20
My Ride: 2002 330xi
My bad I was in a hurry and I was reading it fast. Thanks by the way
Old 10-20-2012, 12:56 PM   #10
DRE97
My Ride: 330CiC and 328 Xi
Originally Posted by smith323 View Post
I think the Dr. Vanos sells for $250. You forgot about the $150 core charge rebate.
DRE97 is offline   Reply With Quote
Old 10-21-2012, 10:49 AM   #11
Brobby87
My Ride: 2003 325i
Originally Posted by DRE97 View Post
I think the Dr. Vanos sells for $250. You for got about the $150 core charge rebate.
This is correct.
Brobby87 is offline   Reply With Quote
Old 10-21-2012, 01:00 PM   #12
vilseck21
Dr Vanos is a better deal, its only $250, and they do more than just the seals
The Stage II builds off of the Stage I kit and adds an additional level of performance upgrades that allows the vanos to work much more efficiently. This is done by improving another area of the factory design, by once again reducing friction.
On all models built after 4/95, a spring plate was used between the thrust washers on the intake cam which holds the cam gear tightly in place. Unfortunately it also creates a decent amount of friction on the intake cam gear.
As the intake cam gear is tightly held between two thrust plates by the spring plate, it is forced back and forth by the vanos as the engine goes through the RPM range, advancing and retarding the cam. As the gear rotates in each direction, it has to continually overcome the frictional forces being applied by the thrust plates. The Stage II kit incorporates REM polishing to reduce the friction between the intake gear and thrust plates, allowing the vanos to work with much less effort.
REM polishing is a proprietary 2 stage chemical and media abrasion process used in many levels of motorsports, which polishes the surfaces to a micro-smooth finish. The parts are then chemically treated with an agent that considerably reduces friction between mating surfaces. The stage II kit will completely eliminate any 'sticking' issues caused by excessive friction between the intake cam gear and thrust plates, greatly extending the life of the unit.
The Stage II vanos kit is designed for a daily driver while be able to withstand the abuse and stresses of a modified engine. Race cars, track cars, forced induction cars, or any other car that sees more abuse than a typical daily driver sees can benefit from Stage II kit. This is truly the ultimate vanos upgrade.
