Old 07-13-2012, 08:39 PM   #1
nightflex
My Ride: 05 BMW 330CI S+P+C
Picked up an 05 330ci... already need more $$
First bmw against all odds.
Picked up an 05 330ci with 75k miles on the dot.
Third owner now has premium + sport + winter pkg
Black on Black
$12500 CAD out the door with taxes and all in.
$147 hood insulator
$62 Bmw Oil + Filter
$45 DRL with Plate Leds
$70 Angel Eyes
$90 Dorman Control Arm Bushings
-Thinking about overhauling A/C, scary postings on the forum about catastrophic failures.
-Mtech 2 Bumper front/rear + skirts future purchase, bmw quited $2900 all the parts out the door, then pain, then install (not cheap)
-Oil Pressure light flickering under 1-2k Rpm sometimes until I give it gas..
-Steering wheel vibration is complete gone after control arm bushing install
-Revved the car repeatedly over a 110km(68 m) drive doing about 140-160 kms (100 miles) - engine light came on, brought it to my shop hooked it up some sensor was tripped has to do with exhaust - got it taken out will see if it pops up again would need a new sensor or something.
Only scary thing is the red Oil pressure light, couldn't find any solution on the internet. Anyone know any solutions?
is this normal in terms of upgrades and maintenance?
nightflex is offline   Reply With Quote
Old 07-13-2012, 08:49 PM   #2
Crespo5190
My Ride: 2001 325CI
Interested in a seibon carbon fiber hood?
-Tony
Crespo5190 is offline   Reply With Quote
Old 07-13-2012, 08:58 PM   #3
My Ride: Lexus
Interested in spun main/connecting rod bearings? That oil light is extremely serious. You sure the p/o wasn't trying to unload a bad car on you? Any weird noises?
Old 07-13-2012, 09:02 PM   #4
325guy
Banned User
My Ride: 2003 325i stick
That oil pressure light could easily be the sensor
325guy is offline   Reply With Quote
Old 07-13-2012, 09:09 PM   #5
pipo1123
My Ride: 2004 bmw 330ci
Yep yep, i have the same thing right now my red oil light flickers when im in idle. It doesent show on codes so im changing the senson on next oil change.
pipo1123 is offline   Reply With Quote
Old 07-13-2012, 09:12 PM   #6
My Ride: Lexus
You guys even know what sensor you're talking about?
Old 07-13-2012, 09:13 PM   #7
Vandyinc
My Ride: 2000 323 Cic
Why wait. Pressure sensor should be on the OFH.
Done:H&R Sport Springs Koni STR Shocks & Struts, Lower Control arms, FCABs, OFHG, CCV, Cooling Sytem refresh, Coolantsnitch. Yet to do:Transmission fluid & filter, VCG
Vandyinc is offline   Reply With Quote
Old 07-13-2012, 09:14 PM   #8
Steven747
My Ride: 05 330ci
oil level sensor causes yellow light. your bad blown up engine causes the red
Old 07-13-2012, 09:15 PM   #9
My Ride: Lexus
ding ding ding
Though why it would read "OK" once revs are up is odd. Any confirmed cases where a new oil pressure sensor fixed a red light at idle? You really don't hear about these failing.
Old 07-13-2012, 09:17 PM   #10
choxor
My Ride: JDM
I have to ask, did you even check the oil before revving the snot out of it.
Old 07-13-2012, 09:35 PM   #11
trive2
My Ride: 1989 BMW 535i
The moment that little red oil light turns on for even the briefest moment when it's not supposed to, you NEED to investigate seriously and immediately.
Red oil light means you're already doing engine damage. It's not a warning that the pressure is about to drop low enough that it could cause engine damage, it's telling you the pressure has already dropped far enough to be causing irreversible damage.
trive2 is offline   Reply With Quote
Old 07-13-2012, 10:31 PM   #12
budysr
My Ride: 330ci
I bought an 03 330ci a few weeks ago, and it also had a red oil light flicker show up on me a couple times, but only with the engine warm and at idle for extended time. It would immediately go away with the slightest tap on the gas pedal to raise rpm, and NEVER came on while driving. I think the car was idling a bit too low(just barely above 500) when this was happening. I have since had a refresh of some stuff under the hood including a new MAF, ICV, CVV, plugs, filters, and any vac leaks fixed. Car idles perfectly now around 650/700 or whatever it is supposed to idle at, and runs like a scalded dog! AND, I have not seen a trace of red oil light flicker. I think in my case it was from the rpm dropping too low. That red light is either the oil pressure sending unit sensor, or there is a legit problem with the oil pressure. If yours is coming on at higher rpm then idle, you need to try a new sensor ASAP, and make sure it's not the actual oil pressure
budysr is offline   Reply With Quote
Old 07-13-2012, 10:38 PM   #13
Lusticles
My Ride: 325Ci
For all you're about to spend, or have, you could have picked up a better one.
number one Audi Fan
Lusticles is offline   Reply With Quote
Old 07-14-2012, 01:08 AM   #14
nightflex
Car has no problems.
Engine is as smooth as cream.
No weird noises, steering wheel is a bit stiff but that's binmers.
the day I got an oil change done was the only day when the light flickered once.
It was like when the car was in motion as the oil slushed back and forth it tripped the light. It was momentarily but I haven't got it since.
I did some research and found out that many e46 owners have had the same red light issue with no remedy. Even some have gone as at as taking it back you he dealer 2- or 3 times and no one has figured out anything.
I am waiting to see if it comes back ill probably get ICV and pressure sensor changed as a precaution and then go from there.
Other than that the ride is sweet, the engine revvs strong no clunking or knocking sounds - HK sound system is a god send.
Very very pleased with the purchase ... Also the o-ring seal is another thing that I'll change as prescribed by another poster.
Let me know if anyone has a decent solution for that..
Old 07-14-2012, 01:18 AM   #15
My Ride: Lexus
I'd suggest changing your oil and filter for starters.
Old 07-14-2012, 02:41 AM   #16
nightflex
Genuine BMW + Oil filter was used 50kms before the light flickered.
Here are the other people with the same problem on the internet with no solution...
They have cleaned ICVs, changed sensors, used different oils - dealer has got them changing everything under the hood but nothing has fixed the problem.
A few people have had this problem fixed but increasing their rpm idle speed. They say that the idle speed is too low. Other than that no matter what they changed under the hood, the light still flickered - I am concerned but not overly as I haven't come across anyone with gasket blown, or pistons rings warped due to this although in the long term if it start to pop-up more often id just sell it as I cant find a solution and I can't go to sleep at night.
Found a video on youtube of someone else looking for a solution:
Other people with the same problem on their e46
http://www.bimmerfest.com/forums/sho...d.php?t=524573
http://www.bimmerfest.com/forums/sho...d.php?t=629311
http://www.bimmerfest.com/forums/sho...d.php?t=601031
http://forums.bimmerforums.com/forum....php?t=1752267
http://forums.bimmerforums.com/forum....php?t=1638548
http://forums.bimmerforums.com/forum....php?t=1479638
http://forums.bimmerforums.com/forum...7#post19702257
http://forums.bimmerforums.com/forum....php?t=1251020
http://www.e46fanatics.com/forum/sho...d.php?t=830842
http://www.e46fanatics.com/forum/sho...d.php?t=834225
http://www.e46fanatics.com/forum/sho...d.php?t=769289
http://www.e46fanatics.com/forum/sho...d.php?t=747012
http://forum.e46fanatics.com/showthread.php?t=713945
http://forum.e46fanatics.com/showthread.php?t=930140
http://www.e46zone.com/forum/topic/3...t-at-hot-idle/
http://bmwland.co.uk/forums/viewtopic.php?t=110978
http://www.bimmerforums.co.uk/forum/...ht-red-t86149/
http://www.e46fanatics.com/forum/sho...d.php?t=790607
http://forum.e46fanatics.com/showthread.php?t=867631
http://forum.e46fanatics.com/showthread.php?t=846304
http://forum.e46fanatics.com/showthread.php?t=791181
http://www.bimmerfest.com/forums/sho...d.php?t=595778
Old 07-14-2012, 07:20 AM   #17
NOVAbimmer
My Ride: E60M
Our cars have catastrophic a/c failures?
NOVAbimmer is offline   Reply With Quote
Old 07-14-2012, 08:01 AM   #18
Adamo99
My Ride: 2016 Wrangler 75thAE
I think OP might be thinking the A/C system, instead of the cooling system.
Adamo99 is offline   Reply With Quote
Old 07-14-2012, 08:19 AM   #19
MercForHire
My Ride: M235i 6MT
He obviously doesn't know the reasons why the car breaks down. Only from what he heard.
But it's a good start i guess.
Old 07-14-2012, 08:20 AM   #20
Solidjake
Zero. Leaks.
Solidjake's Avatar
My Ride: '02 330i 6MT
Fix that oil issue before anything else.
