Old 10-04-2012, 06:27 PM   #1
jpbutler1983
My Ride: 2001 325Ci
Rpm dips
Good evening.
Two things.
Is it normal for rpms to dip below 500 causing a slight shudder? If not, what causes that?
Second. Why is it that when I drive in the rain my car creaks and groans... Most notable if I drive over a bump... Like a speed bump?
Thanks all
Sent from my SPH-D710 using Bimmer App
A man will be the same with a title as he was without one
jpbutler1983 is offline   Reply With Quote
Old 10-04-2012, 06:48 PM   #2
MercForHire
Sh1tty Advisor
My Ride: 323Ci 5 Speed Black
strut mounts are worn out.
Add grease or replace
Oops! My Water Pump Broke Again .................... Coolant in a Bottle
Old 10-04-2012, 06:55 PM   #3
MercForHire
Sh1tty Advisor
Remove the black covering on the top of the strut mount(left pic), visible on the strut towers when you open the hood.
Squeeze lithium grease into the ball bearings
I had same problem few month ago, new mounts from 2009, added grease and now perfect
Old 10-06-2012, 08:09 AM   #4
jpbutler1983
My Ride: 2001 325Ci
It does it with the back as well... If there access to a point in the back that can be greased?
