opinions of smg drivers - Page 2 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 10-07-2012, 02:12 AM   #21
DeclanM3
My Ride: 332Ci
Originally Posted by davide330 View Post
Don't forget the bucking bronco it can become if in 1st/2nd and going around a bumpy intersection. Your hit the bump and your foot lifts off and it goes into stop stall mode which then makes you jerk again, rinse and repeat and it can get quite embarrassing if you don't get it under control.
Or if you try and drive while the car is cold, always had to let mine go two lights out on the warm up dial before trying to drive off, I always would forget at work when going home. The driveway was a steep ramp with speed humps and it just gets a mind of it's own as you slow and hit the hump and it starts bucking, usually a quick stab of the accelerator would fix it but with the speed humps it wasn't an option :-)
I've only got the bucking bill effect a couple of times whilst coming out of my car park in 1st gear. I found that having the tiniest bit of constant throttle solved that problem.
Not sure what you mean about being cold. I generally don't go above 3,000rpm until I'm above 70 degs for oil.
DeclanM3 is offline   Reply With Quote
Old 10-07-2012, 02:14 AM   #22
Shonky
My Ride: 2004 E46 M3
Bucking bronco happens on manuals too. Very light throttle (by wire). So sudden movement, car bucks, foot moves, so it bucks again. Process repeats. Take foot off accelerator is the solution for me. Happens mostly when cold for me.
edit: and also happens on E9x M3s in both manual and DCT variants.
Shonky is offline   Reply With Quote
Old 10-07-2012, 02:20 AM   #23
ating
My Ride: 2004 M3
^ Yeah I've had this a few times since I've owned the car, but once it's warm it's perfectly fine. It does take a little while to get used to the drive-by-wire though, wished it was cable.
Evolve CSL airbox w/Alpha-N tune | KW v2 | Vorshlag Camber Plates | WORK Equip 18x10/12 | Dixis Ti exhaust
ating is offline   Reply With Quote
Old 10-07-2012, 02:25 AM   #24
DesiredM
My Ride: E46 M3
It's true when the smg is cold it is more prone to bucking and being relatively jerky through 1-2. It usually does shift more smoothly after its warmed up just a little but off a cold start is a little rough.
Only been driving it for about 2 weeks but gotten used to it, not bad considering I haven't driven a manual in about 5 years. It's pretty simple to learn even if you don't know how to drive a manual. However nothing worse then slowing down, and right as you try to accelerate the car decides its going to shift down into first and bucks...that s**ts me up the wall but only happened twice so can't really complain. Just need to learn to downshift it myself sooner or keep up the throttle to prevent it from downshifting by itself
DesiredM is offline   Reply With Quote
Old 10-07-2012, 03:06 AM   #25
MickeyB
My Ride: Nissan Stagea
Interesting and informative thread: It makes me actually willing to consider the SMG (I'm on the lookout for a E46 M3). Funny about the "bucking": My Steptronic E39 540i would downshift by itself when braking: on a cold engine, down my hill, it used to freak me out until I got used to it: you had to anticipate it as it was quite violent at times...
MickeyB is offline   Reply With Quote
Old 10-07-2012, 04:34 AM   #26
DeclanM3
My Ride: 332Ci
I find if you move your foot right so you're pushing it up against the trim to the right of the accelerator pedal you are far less jerky with the accelerator over bumps. I often do this on my way out of my car park as I have to go down 3 levels and over 4 speed bumps when my car is cold.
Old 10-07-2012, 09:50 AM   #27
Chewy
My Ride: '03 LSB M3 Vert SMG
Opinion change.
After some spirited driving at the SAM, which I've never done before in the M, I have a new view on the smg gearbox. Normal driving it's not really that great but when spirited/tracked, it's like twice as good (for non professionals)
Chewy is offline   Reply With Quote
Old 10-07-2012, 04:42 PM   #28
DeclanM3
My Ride: 332Ci
Originally Posted by Chewy View Post
Opinion change.
If you think SMG is good on mountain runs wait until you get it to the track! The harder you push the car the better SMG becomes
Old 10-07-2012, 09:20 PM   #29
YGOAMG
My Ride: 325Ci ClubSport
Send a message via MSN to YGOAMG
A salesman once told me this about when i was interesting in an E36M3 (SMGI)
Find me on Instagram
@PeterMarquez346
Originally Posted by all4show View Post
who da F done that?
prestige warehouse or who?
YGOAMG is offline   Reply With Quote
Old 10-07-2012, 10:44 PM   #30
CortinaD
My Ride: lots
Manual e36 over smg1 but for the e46 smg2 over manual
CortinaD is offline   Reply With Quote
Old 10-07-2012, 11:22 PM   #31
DesiredM
My Ride: E46 M3
I agree but I think it depends on the driver....hopefully that comment though doesn't start a massive debate haha
Old 10-08-2012, 12:44 AM   #32
Miss325
My Ride: 05 325CiC Individual
I really want to give an SMG M3 a go. Ive only driven a couple of manual M3.
Do any of you guys left foot brake it and give it some throttle on the downshifts.?. i think thats what id do to make it a smooth shift ..
There's no need, it is completely smooth if you change down at the correct revs... Same as a manual in that respect.
Miss325 is offline   Reply With Quote
Old 10-08-2012, 01:00 AM   #33
M3 CS
Past Site Sponsor
My Ride: All sorts
AMEN.
Driven both. Owned both. Couldn't agree more.
M3 CS is offline   Reply With Quote
Old 10-08-2012, 02:11 AM   #34
YGOAMG
Define correct revs?
@PeterMarquez346
who da F done that?
Old 10-08-2012, 03:32 AM   #35
DeclanM3
My Ride: 332Ci
Hitting at least 6,000 every downshift
Old 10-08-2012, 03:50 AM   #36
Mitch E46
My Ride: M3 Convertible
But officer... 5,800 is my redline.
Mitch E46 is offline   Reply With Quote
Old 10-08-2012, 04:05 AM   #37
DeclanM3
My Ride: 332Ci
Just until you get an M car
Old 10-08-2012, 04:29 AM   #38
Chewy
engine revs matches road speed
Old 10-09-2012, 07:00 AM   #39
Honro
My Ride: M3 E46
Tip - To avoid the mini clutch dump, just hold the down shift paddle when comming to a stop. It engages the clutch enough so when you take off it doesnt dump it
This even works when your stopped on an uphill and it will engage the clutch so the car doesnt roll back
(its in your owners manual) hehe
SOLD - 2002 M3
- MOD LIST -
- ESS VT550 SUPERCHARGER @ 307rwkw | KW V2 Coil Overs | 20' Vertini Hennisy Wheels - 20x 8.5F & 20x10R -
Watch My S/C Install Vid Here: http://www.youtube.com/watch?v=guCnA...ature=g-user-u
Honro is offline   Reply With Quote
Old 10-09-2012, 07:29 AM   #40
DeclanM3
My Ride: 332Ci
Will try that but the issue I have is more when I try to take off mid way through the car changing from 2nd to 1st. Obviously the easiest way to overcome this is shift into first using the down paddle but on occasion I forget. It's pretty rare though.
