Old 10-04-2012, 12:31 PM   #1
ajay1982
My Ride: bmw e46 325i 2001 ms
help dont want to go to bmw
hi all im new on here
i have a bmw e46 325i msport i have my abs handbreak and asc lights on when put on computer code come as rear left sensor so i got a new one and fitted it had codes cleared as soon as i started to drive light come back on plug the computer back in same codes i also have no speedo or mpg on clocks
thanks for your time guys
ajay1982 is offline   Reply With Quote
Old 10-04-2012, 12:33 PM   #2
choxor
My Ride: JDM
I assume you mean speed sensor.
Old 10-04-2012, 12:34 PM   #3
ajay1982
yeah abs/speed sensor
Old 10-04-2012, 01:23 PM   #4
dmax
dmax's Avatar
My Ride: '99 328i 300K miles
also you have 'no speedo or mpg on clocks'? I assume you mean 'or' clocks...and by that little phrase, I wonder if your cluster is just unplugged or not plugged in well...had you been doing some of the cool sharpie mods?
Also, doublecheck your tire pressure...connections to speed sensor...wires coming forward.
And as will all electric issues, start by checking the battery condition also. (Small chance of this being your issue...could also be ignition switch too, I think)...but it sounds like just a loose cluster is why you don't have some lights/function in cluster.
You don't have a little flashing dot in the cluster by any chance, do you? The tamper dot?
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-04-2012, 01:33 PM   #5
ajay1982
hi dmax no other lights flashing when the abs light first come on the front break wear sensor was hanging out so i got a new one when the lights didnt go out thats when i put it on a computer and codes said rear left sensor the battery light was flashing on and off for about a week that was about a month ago and i get 1 rear bulb triping out
Old 10-04-2012, 01:40 PM   #6
dmax
dmax's Avatar
I think your battery has outlived its usefulness...or you don't drive the car far enough.
Your rear bulb could be bulb, socket, needing of dealer free retrofit, or you have a wire out in the elephant trunk.
Look under your battery clamp for the date on the battery...if 4-5 years old, consider a new 49DL from Autozone. Maybe just start by charging it or driving it further. You need about 20 mins. on highway to build up the battery. If you do a lot of short trips, you might not recover the power you lost by starting it, which is the largest draw of current.
You need not only voltage, but amperage. If you're starting okay, it sounds like you have the amperage, though ironically, I wonder if maybe you don't have the voltage? I don't understand batteries too much...so apologies if that's wrong!
Use cluster test to check voltage when car is off and on...use cluster test to test the cluster too (yes, I meant that if it sounded weird!).
HTH
See me in June!
dmax on Facebook
Mangofy your E46!
Old 10-04-2012, 01:46 PM   #7
ajay1982
i will have a look tomorrow when its light and will get back to you
Old 10-04-2012, 02:25 PM   #8
RayPooley
My Ride: 320i SE Coupe
Do you have the codes? That might help.
Old 10-05-2012, 02:32 AM   #9
ajay1982
Codes 32 and 34
Old 10-06-2012, 10:03 AM   #10
ajay1982
its all fixed it was the rear left abs ring
thanks for all your help guys
