Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 3.67 average. Display Modes
Old 10-05-2012, 01:11 AM   #41
MJLavelle
My Ride: 2001 BMW 330ci
I am at 120k, and don't officially qualify because the ET did blow out 3 years ago. Otherwise, all original. But I am not proud of that like some, I am relatively nervous. I have all the parts for a complete system change (I mean every single o-ring, sensor, new hardware, hard lines, heater valve, plus the normal big items). I want to change it before something bad happens, but I am completely unable to do so right now.
Old 10-05-2012, 02:42 AM   #42
2003 325i
My Ride: '03 Orient Blue 325i
109K miles, all original. Not skerred.
Originally Posted by MTA330ci View Post
Does anyone have a recommendation on which is the best high performance valve stems?
Old 10-05-2012, 02:45 AM   #43
325inthe510
My Ride: 152ci of madness
110000 miles, original everything (I think) I replaced the pump about 6 months ago
325inthe510 is offline   Reply With Quote
Old 10-05-2012, 02:58 AM   #44
///MPR77
My Ride: 02 ///M3 Tri-Ped
293k miles and 2 weeks on the new
ET, WP, T stat, upper, and lower hoses, and sensor. I have the heater inlet pipe, and return hose on hand, and will get to them soon.
2nd Radiator
3rd Water pump
3rd ET
2nd set replacement Upper/Lower Hoses
2nd or first replacement Thermostat
Old 10-05-2012, 08:56 AM   #45
boostedisbetter
boostedisbetter's Avatar
My Ride: 2008 S2000, 2009 CBR
lol, sooo it's NOT original everything
2nd Radiator
3rd Water pump
3rd ET
Crazy! 293k, holy crap!
Originally Posted by Green_Shine View Post
(2/14/2017)Trump, by definition is a nitwit. He has every opportunity to make sound decisions, and he is incapable. I can't see this guy lasting 4 years without resigning or being impeached.
boostedisbetter is offline   Reply With Quote
Old 10-05-2012, 09:08 AM   #46
curca
My Ride: 2002 325i
I got 2002 325i with 185k miles, still got original radiator, changed Water pump, ET, hoses, and TS twice
curca is offline   Reply With Quote
Old 10-05-2012, 09:09 AM   #47
curca
My Ride: 2002 325i
is it original motor?
Old 10-05-2012, 09:18 AM   #48
lakedude90
My Ride: 03' 325i
71k miles all orginal except for the Tstat. I think Im going to it soon though. Just for a peace of mind. I know it needs to be done. just need to get some parts. Im debating on if I want to get rid of my clutch fan while im at it or not and do the Electric fan mod. Since it is getting colder soon, I could prolly take it off and it wouldnt hurt anything. My work commute is only like 15-20mins max.
_____________
Jacob
03' 325i
lakedude90 is offline   Reply With Quote
Old 10-05-2012, 11:35 AM   #49
hummer
My Ride: 2001 330CI
Just turned 180K! Thermostat went bad at 30K and the pump was leaking and the shaft was wobbling at 114K. So, a new thermostat and Stewart pump went in. Everything else is original!
Old 10-05-2012, 11:45 AM   #50
JohnIBarr01
My Ride: ZHP 6MT, Mk.6, Jeep
Original owner of my car replaced the entire system with OE parts at 75k as PM. I'm at 132k now, so I'm probably going to do it (via Mango's guide) again before summer hits. Ain't skeered, but I would rather deal with it when it is convenient for me to do so, rather than on the side of the interstate.
Pat Summitt Foundation | VWvortex | V2Lab | Twitter | Facebook
Originally Posted by TheGreenspanator
Let me guess: This doesn't happen in Germany
JohnIBarr01 is offline   Reply With Quote
Old 10-05-2012, 11:45 AM   #51
tock172
My Ride: '12 135i DCT
Lol. My original cooling system failed just under 75,000 miles. And that was almost 60,000 miles ago.
Past: 1999 Techno Violet Metallic M3
Present: 2012 135i DCT Dinan S2
Old 10-05-2012, 11:46 AM   #52
E46@46
My Ride: 2003 325xiT
Here is my radiator at 156k miles. I wonder what yours looks like? Have you used the OBC to see what temp yours runs at? Just curious. Thanks.
E46@46 is offline   Reply With Quote
Old 10-05-2012, 12:30 PM   #53
Paulscustom
My Ride: 323i
Still stock with over 200,000 miles.
Paulscustom is offline   Reply With Quote
Old 10-05-2012, 12:41 PM   #54
boostedisbetter
Holy hell.
HOLY HELL
Are you the first owner?
Old 10-05-2012, 08:30 PM   #55
dknightd
My Ride: 2002 330 cic
Originally Posted by TerraPhantm View Post
Hmm... Honestly, I think you're both right. If a crack already exists, then a pressure test will reveal it - either by coolant showing through, or by the pressure slowly dropping. If a crack has not yet formed, then perhaps the mixture of heat and pressure will throw it over the edge.
But simply increasing the pressure slightly beyond what would be seen in a real-world scenario should stress it to a similar extent as heat.
I agree, I think they both might be right.
It is possible for a leak to start when a part gets hot and expands (it is also possible for a leak to seal when a part gets hot and expands).
Likewise for a part that cools, a leak could start, or seal, as the part contracts.
But any real leak almost always seems to show up in a pressure test. Hot or cold. It might not be a visible leak, it could be an internal leak. If the leak is slow it might take a few minutes to show up on the gauge (and then you always wonder, is it a real leak, or just a leak between the gauge and what you are testing - soapy water can help show this kind of leak). You might have a slow leak that the people doing the testing did not wait long enough to see on their gauge.
Did they also pressure test the cap? Maybe the cap is leaking. Or, maybe the cap does not seal well to the tank.
Probably the smart thing to do is replace both tank and cap - at least.
But before you do that, you might want to find out if you actually have a leak.
The light on the dashboard can be useful, but it can also be wrong. You do not say what the float tells you the fluid level is. You might want to add a little distilled water to bring the level between min and max. Shouldn't take much.
You want to keep it BETWEEN min and max - don't go under min, don't go over max. Be careful, at least on my BMW the float will not go above max, but, you could fill it above max if you wanted - don't do that, keep the level just a little below max.
I've read someplace that cooling level sensor and windscreen fluid level sensor are the same part on our cars. This could be useful information if you determine the problem is the sensor, and not the actual fluid level. Switch sensors to determine if it is a sensor problem or a wiring problem.
FWIW I bought my car used this summer. Service records show the thermostat was replaced at about 23K, or 28K can't remember right now. Presumably warranty replacement. Car has about 80Kmiles and 10 years on it. Belts were replaced about 10Kmiles ago. I hate to replace parts that seem to be working OK, but, think I will replace ET and cap since they seem to be common points of failure at about this age. I might do the whole mango thing on the cooling system just because it is easier and cheaper to deal with at home than it is to wait for it to fail. Duct tape and bailing wire will not get you home if the ET explodes.
dknightd is offline   Reply With Quote
Old 10-05-2012, 11:53 PM   #56
Euro604
My Ride: 2002 330Ci
I'm at 100k miles and I believe mines the Original unless the last owner replaced it. Going to do it soon as I can tho
Euro604 is offline   Reply With Quote
Old 10-06-2012, 12:56 AM   #57
Lemonsqr
My Ride: 2001 TiAg 330i
2001 around 78K, replaced thermostat and upgraded to Stewart water pump around 30 or 40K.....all other cooling system parts stock and original. I have an expansion tank on hand ready to go though.
Lemonsqr is offline   Reply With Quote
Old 09-17-2013, 12:57 AM   #58
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
I'm still 100% good. Debating just doing a coolant flush at the end of this season, so I can piss Mango off even more.
120k and counting, build date 10/98!
hi its me alec is offline   Reply With Quote
Old 09-17-2013, 01:00 AM   #59
My Ride: Lexus
I know lots of folks who have 150k on their original cooling system. Some on original pulleys. That doesn't mean it's ideal.
I have the ability to take a dump on your head, but doesn't mean I should do it.
I'll be nice and leave it at that.
Old 09-17-2013, 01:02 AM   #60
HBizzo88
My Ride: 2002 bmw 330ci
Who else still has the original cooling system?
Mine made it to 150k before the expansion tank sprung a leak. Just did the overhaul last month.
2002 330ci
Build date:10/01
HBizzo88 is offline   Reply With Quote
dmax furry convention, ghetto thread is ghetto, incur the wrath of mango, mango is watching you all, rustbucket thread
