Thread Tools Search this Thread Rating: Thread Rating: 6 votes, 3.67 average. Display Modes
Old 09-19-2013, 09:54 AM   #101
seigi009
My Ride: 03 325i
Originally Posted by GSherbs View Post
A flashing coolant light is like a gift.
this.
seigi009 is offline   Reply With Quote
Old 10-18-2013, 03:36 AM   #102
hi its me alec
hi its me alec's Avatar
My Ride: BMWs + 1988 Pathy
Send a message via AIM to hi its me alec Send a message via MSN to hi its me alec
My coolant light turned on again, level was a little low, no signs of leaking. So I'm happy to report that I replaced Thermostat, Water Pump, ET, and bleeder hose.
Mango wins.
hi its me alec is offline   Reply With Quote
Old 10-18-2013, 03:49 AM   #103
LD330XI
My Ride: '09 335i
Re: Who else still has the original cooling system?
Just shy of 150k and all I have done is the lower hose and temp sensor in it at 100k. Just got a code for the thermostat last week. So I have been monitoring it, and indeed it is running cool.. Time to replace that and the water pump.
LD330XI is offline   Reply With Quote
Old 10-18-2013, 03:57 AM   #104
jjp735i
My Ride: 05 545i & 03 325xi
cooling system
mine goes under the knife today for a slow coolant leak. Pretty sure it's just the expansion tank. 120,000 miles.
jjp735i is offline   Reply With Quote
Old 10-18-2013, 04:22 AM   #105
hi its me alec
Definitely do the expansion tank too, it's a more common failure point than the Thermostat. The thermostat might be throwing codes, but it won't cause your car to run out of coolant while driving.
I was driving my dad's e39 when his ET exploded, it was a terrible experience. I was at the U of MN (can't park inside anywhere) and it was one of those -20 degree days.
Old 10-18-2013, 09:27 AM   #106
My Ride: Lexus
Mango wins.
what's a bleeder hose? or do you mean upper hose?
Old 10-18-2013, 09:50 AM   #107
jjp735i
Well car is getting new front right drive axle because of boot being torn, left steering boot and new expanison tank.
Total kill is going to be $733.00. This is when I really wish I had a place to do work. But got to do what you got to do.
Old 10-18-2013, 12:48 PM   #108
Neight
My Ride: 2004 325i
I honestly don't even know if mine was overhauled or not I bought the car at 87.4k miles and I'm at 91.1k and my cooling system keeps my car just a tad under the halfway mark on the stock cluster. Is there way to tell if it's been overhauled or not?
1986 Mustang 5.0 hatchback- Stroked/blown/E85 No cage= No time slips
2004 325i sedan- Just looks
Neight is offline   Reply With Quote
Old 10-18-2013, 01:08 PM   #109
blantonator
My Ride: 90 325is
I'm at 130K miles(2004 ZHP) with original cooling system. Seems like something I should do soon. Is there any reason it would be less likely to go in the winter vs summer?
blantonator is offline   Reply With Quote
Old 10-18-2013, 01:20 PM   #110
pauly99
My Ride: 2002 325i
I'm in the same situation. Bought the car 2 weeks ago and although I see "Vehicle Serviced" plenty of times out of state per the Carfax, I'm clueless as to what exactly has been serviced. How do you find that out?
pauly99 is offline   Reply With Quote
Old 10-18-2013, 01:27 PM   #111
My Ride: Lexus
just assume it hasn't been done.
Old 10-18-2013, 02:44 PM   #112
Sedan Hussein
My Ride: e46
Thats good to hear. My ZHP is at 76k and I've been on the fence about doing the overhaul. 130k is impressive, but I'd def. keep the funds available if it does happen.
This is just my own opinion, but I feel like its more likely to occur in the summer with higher temps.
Sedan Hussein is offline   Reply With Quote
Old 10-18-2013, 07:34 PM   #113
hi its me alec
Yes
Old 10-18-2013, 07:39 PM   #114
Davconelectric
My Ride: 2 dog powered sled
Yes, I still have my original cooling system. It's all sitting under my work bench for emergency spares
Davconelectric is offline   Reply With Quote
Old 10-18-2013, 10:31 PM   #115
e46techtuner
My Ride: 2000 328i
I only have the original water pump at 126K.
e46techtuner is offline   Reply With Quote
Old 10-25-2013, 07:59 AM   #116
curca
My Ride: 2002 325i
still have original radiator with 198,000 miles, rest of cooling system has been changed
curca is offline   Reply With Quote
Old 10-25-2013, 08:32 AM   #117
325inthe510
My Ride: 152ci of madness
That's what I did, and everything sans the radiator were from 2010, OEM parts at that
325inthe510 is offline   Reply With Quote
Old 10-25-2013, 09:04 AM   #118
MiniXP
My Ride: 08 335i & 01 325xi
Temp gauge probably shouldn't be under half way with normal conditions. That could be a sign of a failed thermostat in the open position.
MiniXP is offline   Reply With Quote
Old 10-25-2013, 09:20 AM   #119
WDE46
My Ride: '13 128i, '04 330Ci
Originally Posted by MiniXP View Post
Temp gauge SHOULD NEVER be under half way with normal conditions. That IS a sign of a failed thermostat in the open position.
Fixed that for you.
I have a dream that one day our children will live in a
nation where they will not be judged by the color of
their skin but by the color of their coolant.
Old 10-25-2013, 09:38 AM   #120
LeMansteve
My Ride: '04 330i 6mt ZSP ZPP
A major contributor to cooling system failures is heat cycling of the "plastic"/composite components, such as the expansion tank. One might argue that the components are more likely to fail in the winter because the heat cycling occurs over a larger range of temperatures and the bottom of the range can be relatively cold.
For example, in the summer your cooling system components might reach a low of 70F once the car has cooled overnight, then heat to operating temperature of ~200F. During a Virginia winter I would imagine the lows could dip into the teens overnight. You are asking the components to get really cold then reach operating temperature within a couple of minutes. I imagine this is a much more stressful condition for your cooling system.
dmax furry convention, ghetto thread is ghetto, incur the wrath of mango, mango is watching you all, rustbucket thread
