Old 10-18-2012, 09:14 AM   #1
johs02
My Ride: E53 X5 3.0i
Very strange noise at start up, take a look!
Listen to this recording of a cold start noise, with comments,
It's from a 2000 328i,
The owners comments:
About 3 weeks ago I start hearing a noise from underneath the engine area, only during cold start-ups. It was like a vibration / grinding noise, lasting a few seconds, which will not repeat on warm engine. In the meantime the noise got louder and longer, and it can be heard also when shifting from P to R or P to D (automatic tranny).
I went to a few mechanics and the answers I got were:
Grinding starter -- changed with no luck
Vibrating transmission -- changed one broken shock absorber
Vibrating exhaust -- straighten and tighten some fins
Noise from torque converter, flywheel or inside the transmission. I didn't commit on any yet as I don't know where to tell them to start. I am afraid of paying more by doing trial and error, than just replace the tranny with a rebuilt one.
There is no error code and no slippage or anything else other than this noise, again on cold engine only. BTW about 2 months ago I did a fluid and filter change but didn't use the oem products.
I made a clip by sliding my phone underneath the car. You can hear the noise at start-up and then again when I shift from P to R.
My comments:
This is not the typical belt/tensioner problem. Not the vanos rattle, not likely to be the alternator. It is not the secondary air pump because I have the same noise in my X5 here in Europe and we do not have pumps on our cars. It is maybe related to the not OEM transmission filter starving the torque converter, but why only when cold start after resting for hours. I also have a non OEM filter after a ATF fluid change some weeks ago, Anyone with experience around this strange sound.
Anyone?
Thanks.
johs02 is offline   Reply With Quote
Old 10-18-2012, 10:54 AM   #2
Zell
Zell's Avatar
My Ride: so turbo wow
When mine is cold, I occasionally hear a sort of "chirp chirp" noise. It's random, but tends to happen more when it is cold. Sometimes it's kind of audible, sometimes it's quiet.
It sounds very close to this, particularly at 0:18. It is much less loud than that, and lasts shorter, but the noise is very very similar.
Do you think it might be your starter doing something similar?
Old 10-18-2012, 11:15 AM   #3
johs02
Maybe your right but it is a different sound and shorter, I beleive it can be then "bendix" gear in you starter, the little gear engaging the flywheel during starter operation and when it releases after the engine starts it hangs up just little to long and you get a little "ping" "scurr" noise from it. It will occur when you let go of your key during startup. If it is the starter, it is very little you can do about it, either it disappers or the this noise continues until you need a new starter. Just a guess.
Make sure your battery is fully chraged and up to speed so starter has a normal function.
The problem we have is also present when we shift from P to R or P to D, so it can be transmission related and a much more serious/expensive problem. Just during cold start , only in the morning or after resting for several hours and definetly not a starter issue.
Old 10-22-2012, 09:17 AM   #4
johs02
Well found it!
See post at: http://www.xoutpost.com/bmw-sav-foru...-opinions.html
